CustomUI
 1-14  …  395-414  415-434  435-454  455-474  475-494  …  515-522
6507.435 In reply to 6507.433
Worked like a charm MoI 4 now has a Shortcuts menue :)
Thank you again.
The Syntax error is still occuring on manual selection. :(
6507.436 In reply to 6507.435
Hi Maysky,
Update the Shortcuts.menu.htm file for v4 with the one from the other thread here to fix the error message that was happening with scripts containing any ' characters in them:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9891.5
The same fix for v3 should work for v4 as well.
6507.437 In reply to 6507.1
Hi Moi’ers
Excuse me for being a noob with PC (use only Mac) V3
I have installed the custom UI but I dont see any icons in command bar?
I need the full extension script icon to be visible.
Which location shall it be extracted to, c:/users/username/programs/moi3d...... or /appdata/roaming/moi3d
I also have a question about how to write file location in PC.
When using ’exporttoseparatefiles’ script I wish the fbx files to be saved in a folder on desktop ”FBX”.
Is the path correct using
C:\\users\\username\\desktop\\FBX\\
* Michael for Nobel Prize *
6507.438 In reply to 6507.437
Hi Stardust, for Moi version 3 on Windows you need to unzip the CustomUI.1.03.win.mac.zip file attached to the first message of this thread. There are 3 folders stored in the .zip file: objects, snapshots, and ui.
These need to be copied into the install folder at C:\Program Files (x86)\MoI 3.0
So copy the "objects" folder over so you then have C:\Program Files (x86)\MoI 3.0\objects
Do the same for the "snapshots" folder so you should then have C:\Program Files (x86)\MoI 3.0\snapshots
Then for UI it's slightly different because there is a ui folder already existing at C:\Program Files (x86)\MoI 3.0\ui . So you want to copy the contents of the .zip file ui folder into the existing ui folder. There will be one file (CommandBar.htm) that will be overwritten which you want to allow.
For v4 it's different - for v4 there is a different .zip file to use and it goes in appdata not the install folder.
6507.439 In reply to 6507.433
Hey Gang:
I could not get this to work.
It shows a menu stub, but no content; in spite of the fact that my Moi.ini is chock-full of ShortCuts.
Have I made a mistake in my ".\startup\82 Shortcuts.js" file, attached?
I used the ".\customui\Shortcuts.menu.htm" file downloaded from 9891.5.
Many thanks to all of you !!!
Mindset
EDITED: 11 Aug 2020 by IGNITER
Size: 294.9 KB, Downloaded: 146 times, Dimensions: 1279x748px
6507.440 In reply to 6507.439
Hi Mindset, if I remember right it only displays shortcuts that are marked in a certain way, I think with a ! character inside the script comment which is the /* */ part.
If you modify your shortcut keys so that it has it like: /*! */ do they then show up?
6507.441 In reply to 6507.440
Thank you Michael.
You are a superstar.
Seems that the operative phrase is:
title = line.match(/\/\*\!(.+)\*\//);
So, I tried this on "MoI 4.0 beta Jan-22-2020":
script: /*! TOGGLE CURVES HIDE*/ var allcurves = moi.geometryDatabase.<<...etc.>>
... albeit to no avail.
So, hmm, I don't know what else to do. ???
Mindset
6507.442 In reply to 6507.441
Hi Mindset, ok so the file "82 Shortcuts.js" should be in %appdata%\Moi\startup and Shortcuts.menu.htm should be in %appdata%\Moi\customui .
Is that what you have ? What happens when you push the button, is anything shown at all?
6507.443 In reply to 6507.442
After much confusion, I finally got customUI shortcut icon to work, as per Michael's instructions for the shortcut .js and .htm files.
Pressing the button on the task bar shows 5 shortcuts, (so far, prior to doing any /*! */ edits).
(I used "83 Shortcuts", because 82 is being used with Snapshots.)
(With Moi V4 beta)
One of the 5 shortcuts showing had this format: script:/*!Select edges v1.2 */ var gd = moi.geometryDatabase; func.....
After adding a new shortcut key to MoI (V4), close and reopen MoI.
I could not locate the script: script:/*! +TOGGLE CURVES HIDE*/..., in order to test it.
EDITED: 11 Aug 2020 by BEMFARMER
6507.444
I GENUINELY appreciate your time, attention ...and most especially your help.
When the button is clicked, it displays a stub, as shown:
However, as you suggest, once I moved "Shortcuts.menu.htm" from...
..\AppData\Roaming\Moi\ui\customui\
to
..\AppData\Roaming\Moi\customui\
it started working as expected !!!
Moi must be the greatest software in the world and a primary reason is how we, the user base, are treated and treat each other on this forum.
Thank you mightily !!!
6507.445
In the upcoming release of V4 have you considered building the custom UI into the release maybe in the installation process can you choose classic UI or custom UI - I think with modern screens and extra pixels the custom UI install is very useful in having those tools ready to go and provide a comfortable working environment that is still simple but extremely powerful.
Just a random thought.
Alex.
6507.446 In reply to 6507.445
Hi Alex, sorry no that's not something I've been planning. It doesn't really fit with the overall design of MoI which is focused on being streamlined and not showing a whole bunch of buttons at the top level all of the time.
But at some point I do want to make a mechanism for managing that area of the UI so you could promote some of your most frequently used commands there.
6507.447 In reply to 6507.446
I haven't tried any sort of custom UI but I did like the idea of a "library" button.
That would seem to be in keeping with the idea of streamlining things.
Granted it doesn't save a lot of steps but it would be pretty nice just the same.
Frederick
It would be nice if snapshot had a popup menu associated with it, for the different modes.
Maybe an html file could do this?
6507.449
Hi guys, a quick (and simple I guess) question: how can I install the Custom UI Beta 2 in MoI 4 (Beta Jan 22 2020)?
What I've done so far:
1) Downloaded MoI 4.0 Beta Jan-22-2020 from http://moi.maxsm.net
2) Unzipped directory and copied into C:\Program Files\MoI 4.0 beta Jan-22-2020
3) Started MoI.exe
After that, I cannot see the custom bar. Is there something I'm missing here? I've been reading the forum, but I cannot find what's wrong. Should be something obvious.
Thanks for your help.
6507.450 In reply to 6507.449
Hi Art.
For Windows 10, the %AppData% path should be used. (Type in %AppData% in the windows search box, lower left corner of Windows 10 screen.)
I would suggest first that your C:\Users\<yourUsername>)\AppData\Roaming\Moi folders be unhidden.
(Google "unhide appdata folder windows 10") ...show hidden folders.
Also helpful is to set up a Library "MoiAppData" in File Explorer, for this path to ...AppData\Roaming\Moi, for quick access.
My Library link usually does not show the \Moi text, but the subdirectory is there.
The contents of this ...AppData\Roaming\Moi directory may be:
Folders:
commands (my extra non stock moi _scripts)
customui
nodeeditor
objects
snapshots
startup
There may also be some misc. files there, like MoiColors, moi license keys, etc.
I scanned this topic back 2 years, and did not see comprehensive instructions for install in Moi v4 beta,
although a lot of issues were addressed.
I'd say follow Max's original instructions, but use %appdata%.
Mac link: https://moi3d.com/forum/index.php?webtag=MOI&msg=6507.404
EDITED: 22 Aug 2020 by BEMFARMER
6507.451 In reply to 6507.450
Wow Brian, thanks for this FAST and comprehensive answer.
It is working now. I think your post should be pinned.
Art
6507.452 In reply to 6507.449
Hi art, yes like Brian mentions above for v4 you should install it into the appdata folder, not into \Program Files.
Install instructions are here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
Try using Win+R to bring up the Windows "Run" dialog, and then type in:
%AppData%\Moi
and push Enter. That will open up the MoI appdata folder.
When you unzip CustomUI.2.0.beta2.zip there should be 3 folders that were inside the .zip . The folders are "customui", "objects", and "startup".
These should be copied over to the %AppData%\Moi folder.
So you should end up with:
%AppData%\Moi\customui
%AppData%\Moi\objects
and there will already be a %AppData%\Moi\startup folder, copy the contents of the startup folder in the .zip file into the %AppData%\Moi\startup folder.
6507.453 In reply to 6507.452
Thanks Michael, this is one of the many reasons why MoI is the best: incredible fast answers :-)
6507.454
The screen UI element for numeric input is missing.
This input widget doesn't appear.
Your suggestions will be appreciated.
MindSet
Size: 60.8 KB, Downloaded: 55 times, Dimensions: 161x178px
Show messages:  1-14  …  375-394  395-414  415-434  435-454  455-474  475-494  495-514  515-522
