CustomUI
 1-5  …  386-405  406-425  426-445  446-465  466-485  …  506-522
6507.426 In reply to 6507.425
I have these default objects in my folder. I can create new objects and they appear in my Objects Library in Moi and in %AppData folder. But when i create manually folder in appData it does not appear in Moi. And in Moi I do not know how to create folder and save in it some similar items like for example screws or smth...
Thank you
- Konni
Artstation Instagram V4 Beta Win 10
Size: 347.2 KB, Downloaded: 194 times, Dimensions: 1240x1541px
6507.427 In reply to 6507.424
Hi Konni,
> How to get folders in Object Library?
I don't think it supports sub-folders currently.
6507.428 In reply to 6507.1
Hello Master,
I am getting a script error and no object library, basically nothing happens. What am I doing wrong ?
Size: 24.6 KB, Downloaded: 165 times, Dimensions: 412x284px
6507.429 In reply to 6507.428
hi, michael told you already, that this message comes from using a cracked v3 beta version... spambot maybe?
quote:
Hi Brownie, that error comes from using an old v3 beta release (like a cracked version) which is missing some functions that are in the v3 final release version.
So to fix that make sure you're running the release version of v3 and not a cracked version. If you purchased MoI you can get a new download of the full version installer by putting in your license key at http://moi3d.com/reinstall.htm .
6507.430 In reply to 6507.427
Hi guys,
I have re-installed both (moi_v3_setup) and (moi_v4_beta_Jan-22-2020_setup)
Then extracted (CustomUI.1.03.win.mac) into MoI3 and extracted (CustomUI.2.0.beta2) into the Roaming\MoI directories.
I am able to get a list of SHORTCUTS in MOI3 but cannot get to the shortcuts in MoI4
When I had a look in the (...\AppData\Roaming\Moi\startup) There is a list of all the buttons that populate the bottom Bar.
But SHORTCUTS is not there.
I have had a search around on the Discussion Forum but could not find an answer
6507.431 In reply to 6507.430
Hi Maysky, yes it looks like the CustomUI for v4 does not have a shortcuts button like the one for v3 did.
6507.432 In reply to 6507.431
Ok, So what has to happen for a ShortCut-access-point to be created in the MOI4 customUI?
I guess this question is inappropriate. Sorry.
EDITED: 17 Jul 2020 by MAYSKY
6507.433 In reply to 6507.432
Hi Maysky,
First copy the HTML file for it from the v3 CustomUI which is at customui\mods\Shortcuts.menu.htm . Put that into the appdata\Moi\customui folder where there should be other .htm files like "Scripts.menu.htm" and "ObjLibrary.menu.htm".
Then inside the appdata\Moi\startup folder, make a copy of the "80 Scripts.js" file and name it "82 Shortcuts.js" . Edit the new file "82 Shortcuts.js" and change where it has:
var title = "Scripts";
to instead have
var title = "Shortcuts";
and also where it has:
var menu = "moi://appdata/customui/Scripts.menu.htm";
to instead have:
var menu = "moi://appdata/customui/Shortcuts.menu.htm";
Then you should have a Shortcuts button next to Scripts on the bottom toolbar that will work the same as it did in the V3 CustomUI. I think the way it is set up is it will show a menu of shortcut keys that have script code in them where there is a comment marked with a ! sign in it, like if you have a shortcut key set up like this:
script: /*!Invert selection*/ moi.geometryDatabase.invertSelection();
that will display as an "Invert selection" item on that Shortcuts menu.
6507.434 In reply to 6507.433
Wow! thank you Michael
I will give this a go.
I thought I was being rude
6507.435 In reply to 6507.433
Worked like a charm MoI 4 now has a Shortcuts menue :)
Thank you again.
The Syntax error is still occuring on manual selection. :(
6507.436 In reply to 6507.435
Hi Maysky,
Update the Shortcuts.menu.htm file for v4 with the one from the other thread here to fix the error message that was happening with scripts containing any ' characters in them:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9891.5
The same fix for v3 should work for v4 as well.
6507.437 In reply to 6507.1
Hi Moi’ers
Excuse me for being a noob with PC (use only Mac) V3
I have installed the custom UI but I dont see any icons in command bar?
I need the full extension script icon to be visible.
Which location shall it be extracted to, c:/users/username/programs/moi3d...... or /appdata/roaming/moi3d
I also have a question about how to write file location in PC.
When using ’exporttoseparatefiles’ script I wish the fbx files to be saved in a folder on desktop ”FBX”.
Is the path correct using
C:\\users\\username\\desktop\\FBX\\
* Michael for Nobel Prize *
6507.438 In reply to 6507.437
Hi Stardust, for Moi version 3 on Windows you need to unzip the CustomUI.1.03.win.mac.zip file attached to the first message of this thread. There are 3 folders stored in the .zip file: objects, snapshots, and ui.
These need to be copied into the install folder at C:\Program Files (x86)\MoI 3.0
So copy the "objects" folder over so you then have C:\Program Files (x86)\MoI 3.0\objects
Do the same for the "snapshots" folder so you should then have C:\Program Files (x86)\MoI 3.0\snapshots
Then for UI it's slightly different because there is a ui folder already existing at C:\Program Files (x86)\MoI 3.0\ui . So you want to copy the contents of the .zip file ui folder into the existing ui folder. There will be one file (CommandBar.htm) that will be overwritten which you want to allow.
For v4 it's different - for v4 there is a different .zip file to use and it goes in appdata not the install folder.
6507.439 In reply to 6507.433
Hey Gang:
I could not get this to work.
It shows a menu stub, but no content; in spite of the fact that my Moi.ini is chock-full of ShortCuts.
Have I made a mistake in my ".\startup\82 Shortcuts.js" file, attached?
I used the ".\customui\Shortcuts.menu.htm" file downloaded from 9891.5.
Many thanks to all of you !!!
Mindset
EDITED: 11 Aug 2020 by IGNITER
Size: 294.9 KB, Downloaded: 146 times, Dimensions: 1279x748px
6507.440 In reply to 6507.439
Hi Mindset, if I remember right it only displays shortcuts that are marked in a certain way, I think with a ! character inside the script comment which is the /* */ part.
If you modify your shortcut keys so that it has it like: /*! */ do they then show up?
6507.441 In reply to 6507.440
Thank you Michael.
You are a superstar.
Seems that the operative phrase is:
title = line.match(/\/\*\!(.+)\*\//);
So, I tried this on "MoI 4.0 beta Jan-22-2020":
script: /*! TOGGLE CURVES HIDE*/ var allcurves = moi.geometryDatabase.<<...etc.>>
... albeit to no avail.
So, hmm, I don't know what else to do. ???
Mindset
6507.442 In reply to 6507.441
Hi Mindset, ok so the file "82 Shortcuts.js" should be in %appdata%\Moi\startup and Shortcuts.menu.htm should be in %appdata%\Moi\customui .
Is that what you have ? What happens when you push the button, is anything shown at all?
6507.443 In reply to 6507.442
After much confusion, I finally got customUI shortcut icon to work, as per Michael's instructions for the shortcut .js and .htm files.
Pressing the button on the task bar shows 5 shortcuts, (so far, prior to doing any /*! */ edits).
(I used "83 Shortcuts", because 82 is being used with Snapshots.)
(With Moi V4 beta)
One of the 5 shortcuts showing had this format: script:/*!Select edges v1.2 */ var gd = moi.geometryDatabase; func.....
After adding a new shortcut key to MoI (V4), close and reopen MoI.
I could not locate the script: script:/*! +TOGGLE CURVES HIDE*/..., in order to test it.
EDITED: 11 Aug 2020 by BEMFARMER
6507.444
I GENUINELY appreciate your time, attention ...and most especially your help.
When the button is clicked, it displays a stub, as shown:
However, as you suggest, once I moved "Shortcuts.menu.htm" from...
..\AppData\Roaming\Moi\ui\customui\
to
..\AppData\Roaming\Moi\customui\
it started working as expected !!!
Moi must be the greatest software in the world and a primary reason is how we, the user base, are treated and treat each other on this forum.
Thank you mightily !!!
6507.445
In the upcoming release of V4 have you considered building the custom UI into the release maybe in the installation process can you choose classic UI or custom UI - I think with modern screens and extra pixels the custom UI install is very useful in having those tools ready to go and provide a comfortable working environment that is still simple but extremely powerful.
Just a random thought.
Alex.
Show messages:  1-5  …  366-385  386-405  406-425  426-445  446-465  466-485  486-505  506-522
