CustomUI
 1-6  …  367-386  387-406  407-426  427-446  447-466  …  507-522
6507.407 In reply to 6507.406
Hi Michael Gibson
ohh trust me i did buy moi v3 2 years ago for 300USD , i have been using it for a long time now , so dont assume that i cracked it , i do some times get cracked software but moi was worth it tho.
6507.408 In reply to 6507.407
Hi Semo, well the path you give above "C:\Program Files (x86)\MoI 3.0 beta Mar-17-2013" is definitely for a cracked version. That's an old v3 beta release which is not available anymore and has long since expired. The only way you could have that version and be running it now would be by using a cracked version.
So if you did purchase it make sure you're using the actual purchased version and not one that you downloaded from somewhere else. You wouldn't run into that particular error that you reported if you were using the real v3 final release instead of an older v3 beta release.
If you have somehow misplaced the real v3 installer, you can go here to get a new download: http://moi3d.com/reinstall.htm .
6507.409 In reply to 6507.408
Hi Michael Gibson
thank you for your replay , long story short , i bought MOI at work and i had a problem installing it with all the security they had , so in order to bypass the security i dragged and drop the moi file from another computer with no security , and it seems to work fine sense , i got fired from my job and couldn't get all my original files , all i left with is this file ''MoI 3.0 beta Mar-17-2013'' and i know it looks like i got a cracked version i already looked and searched for solutions but i was sure this error is because i don't have it installed the right way ,anyway thanks for your help and god bless .
6507.410
How do I change the colors for the icons from black as displayed, to white as I have a dark background and they don't show up very well. All my icons are already white so I assume the code in Max's HTML for the four icons in question has something to do with it?
Ron
6507.411 In reply to 6507.410
Hi Ron, the CustomUI scripts use a button image that is embedded in the script file itself so you'll need to edit the script so the button loads an image file instead of using the embedded image.
To do that go to your MoI appdata startup folder and edit the CustomUI files there like the file "70 ObjLibrary.js" is what adds the "Obj Library" button.
It will currently look like this:
var title = "Obj Library";
var menu = "moi://appdata/customui/ObjLibrary.menu.htm";
var icon = "data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAEAAAABACAYAAACqaXHeAAAAGX ...
moi.ui.commandBar.CommandBarCustomUI.insertAdjacentHTML( "beforeEnd", '<moi:Spacer/> ...
Comment out line #3 for the icon value by putting a // in front of it, and then add a new line for an image file like this:
//var icon = "data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAEAAAABACAYAAACqaXHeAAAAGX ...
var icon = "icons/YourIconFile.png";
That should then make it load a file named YourIconFile.png from the ui\icons folder.
The above description is for MoI v4. For MoI v3 you would edit the file "70 ObjLibrary.htm" located in your install directory under ui\customui and change it from this:
<moi:CommandMenuButton menu="customui/mods/ObjLibrary.menu.htm" icon="data:image/png; ...........">Obj Library</moi:CommandMenuButton>
to this:
<moi:CommandMenuButton menu="customui/mods/ObjLibrary.menu.htm" icon="icons/YourIconFile.png">Obj Library</moi:CommandMenuButton>
6507.412 In reply to 6507.411
Hi Michael. Thanks for your help. Just wondered why he would embed the image rather than just pointing to it?
Ron
6507.413 In reply to 6507.412
Hi Ron, no problem!
I'm not sure, maybe something like he wanted to reduce the number of files that had to be managed.
6507.414
Hi All,
Dose any one know how make the Z Axis on the grid visible on in the 3D view port?
6507.415 In reply to 6507.414
Hi Ogar,
Sorry no there isn't any way set up to show that currently.
6507.416 In reply to 6507.414
Not quite the z-axis request, but a line can be drawn at the position of the z-axis, even in Front or Right view,
or a construction line can be added.
6507.417 In reply to 6507.416
Hi, I suppose you could add a vertical polyline and colour it however you want then lock it. Save the scene as a template and load from that each time. Not perfect but I think it would work :)
Ron
6507.418
Hi again, could someone point me to the HTML than controls the colour of the panel divider for the 4 views ?
Ron
6507.419 In reply to 6507.418
Hi Ron, for the viewport borders that's one of the few remaining things that is controlled by a bitmap image rather than HTML. You can modify it by changing the bitmap ViewportForeground.png in the ui folder.
6507.420
Hello everyone :)
Newbie here, first post ^_^
Really glad to be part of Moment of Inspiration Family. Thank you for making such wonderful software Michael and HUGE thanks for everyone for making understandable, fast, easy to use, beautiful and most important FUN to work with :)
Have some questions about Custom UI. Some features does not working. Maybe some of you might know and can help me?
(I'm on Moi V3 Windows 10)
Downloaded CustomUI.1.03.win.mac 2015-08-29
1. Obj library - I can not save my objects to library. It lets me name the object, but after hit "OK" the new object did not appears in Obj library next to Max's Cube, Sphere, Plane already created (attached 1st picture)
2. Snapshot does not save my files, or maybe i was looking not in the right MOI "snapshot" folder :(
3. Lightening also does not working. Want to have some highlights on the surface. Maybe this because of lightening script. (attached image)
4. Tested some scripts. Working like a charm :) Not all tested, but happy so far.
So i was wondering is there any solution to fix all this or I should upgrade to V4 Beta?
Many thanks
Appreciate your help.
K.
Size: 156.7 KB, Downloaded: 171 times, Dimensions: 1049x846px
Size: 166 KB, Downloaded: 147 times, Dimensions: 1051x840px
6507.421 In reply to 6507.420
Hi Konni, welcome to MoI and to the forum!
So for #1 and #2 I think the problem is that by default Windows will prevent applications from writing into the "Program Files" directory as a security measure. If you run MoI at an elevated privilege that could solve this problem. To do that right-click on the shortcut icon you use to launch MoI and then I think it's the "compatibility" tab where you'll find a checkbox that says "Run as Administrator". Try enabling that.
for #3 Lighting options, I think that is expecting for a list of lights to have been written in the moi.ini file by a separate LightingOptions plugin. Try installing that other plugin from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.43
Hope that works!
6507.422 In reply to 6507.421
Thank you Michael for such full and informative answer.
Yep - #1 and #2 solved - Run as Admin and it worked. :)
#4 - Lightening Options also solved. Have them in Options ->View ->Lightening Options -> Lightening Presets. And also have these in custom ui bar :)
Thank you once again for making awesome software ^_^
(I'm in V4 Beta now).
EDITED: 26 Oct 2019 by KONNI
Size: 64.1 KB, Downloaded: 257 times, Dimensions: 732x556px
6507.423 In reply to 6507.303
Now I'm using the V4 Beta. Thank you.
6507.424
Hi all,
Sorry, again noob question here.
How to get folders in Object Library?
Appreciate ^_^
- Konni
Artstation Instagram V4 Beta Win 10
Size: 85.4 KB, Downloaded: 232 times, Dimensions: 844x504px
Size: 52 KB, Downloaded: 275 times, Dimensions: 745x319px
6507.425 In reply to 6507.424
You must have these objects yet in your folder!
6507.426 In reply to 6507.425
I have these default objects in my folder. I can create new objects and they appear in my Objects Library in Moi and in %AppData folder. But when i create manually folder in appData it does not appear in Moi. And in Moi I do not know how to create folder and save in it some similar items like for example screws or smth...
Thank you
- Konni
Size: 347.2 KB, Downloaded: 194 times, Dimensions: 1240x1541px
Show messages:  1-6  …  347-366  367-386  387-406  407-426  427-446  447-466  467-486  …  507-522
