CustomUI
 1-17  …  358-377  378-397  398-417  418-437  438-457  …  518-522
6507.398 In reply to 6507.396
Hi Yuri,
I changed a bunch of things, don't all remember the details.
(I didn't include "Select All" and "Deselect All", since that's just CTRL-A and a "click in empty screen space")
Your screen resolution should be at least 1900x1200 to make it work well, font size (in MoI's OPTIONS) should be 9.5
Drop this file into your user's ApData/moi/startup directory and it should work automatically.
In my case that is:
C:\Users\Jack\AppData\Roaming\Moi\startup (just replace "Jack" with whatever your user name is)
If you don't have a "startup" (no quotes and all lower case) directory, just make one and drop it in there. Alternatively you can use the Moi program directory and drop it into there (again, into the startup directory, if it doesn't exist, just create one).
It should then look like you see in the picture attached.
This will even work with the default MoI installation (and should work with any custom UI's, the 2nd screenshot attached uses the grey custom UI).
If you want your normal MoI panes back, just delete the file from the startup directory and MoI works as if nothing ever happened...
Jack
Size: 27.4 KB, Downloaded: 147 times, Dimensions: 225x1194px
Size: 63.3 KB, Downloaded: 215 times, Dimensions: 1024x768px
6507.399 In reply to 6507.397
Hi co3Darts,
where they usually do...
Size: 70.6 KB, Downloaded: 185 times, Dimensions: 726x906px
6507.400 In reply to 6507.399
Thanks! Looks like a nice mini setup :)
6507.401 In reply to 6507.319
How do you create folder branches in object libraries?
6507.402 In reply to 6507.401
Folders can be manually created, for example by file explorer under %appdata%/Objects (MoI4Beta), but the subfolders and their contents, do not seem to be accessible through the Object Library icon, so are of no use. (As far as I know.)
6507.403 In reply to 6507.398
Hello! My MAC user file directory is just Application Data, right? How to implement? Thank you very much!
6507.404 In reply to 6507.403
Hi jinyicool, on the Mac your appdata folder is in your home directory, under Library/Application Support/Moi.
So the full path is /Users/[your user name]/Library/Application Support/Moi (or ~/Library/Application Support/Moi).
Note that since OSX Lion Apple decided to hide the Library folder by default from Finder. You can use the "Go to folder" menu option and enter it, or use Cmd+Shift+. to temporarily show hidden files, or use one of the methods mentioned here:
http://osxdaily.com/2016/12/12/show-user-library-folder-macos-sierra/
- MIchael
6507.405
hello
i was looking everywhere for a step by step instruction to install the scrip but honestly, there is just random information flying around, like come on take it, easy guys. i have extracted the file to my fold of installation
C:\Program Files (x86)\MoI 3.0 beta Mar-17-2013
and when i lunch moi i get a Script error :
TypeError: Result of expression 'moi.fiIesystem.getUIDir• [undefined] is not a function.
please someone explain step by step
thank you
6507.406 In reply to 6507.405
Hi semo, that error will happen if you're running an older cracked v3 beta release. CustomUI requires a newer version than that, either the v3 final release or the v4 beta release.
If you are using a cracked version please don't ask for support on the official forum.
6507.407 In reply to 6507.406
Hi Michael Gibson
ohh trust me i did buy moi v3 2 years ago for 300USD , i have been using it for a long time now , so dont assume that i cracked it , i do some times get cracked software but moi was worth it tho.
6507.408 In reply to 6507.407
Hi Semo, well the path you give above "C:\Program Files (x86)\MoI 3.0 beta Mar-17-2013" is definitely for a cracked version. That's an old v3 beta release which is not available anymore and has long since expired. The only way you could have that version and be running it now would be by using a cracked version.
So if you did purchase it make sure you're using the actual purchased version and not one that you downloaded from somewhere else. You wouldn't run into that particular error that you reported if you were using the real v3 final release instead of an older v3 beta release.
If you have somehow misplaced the real v3 installer, you can go here to get a new download: http://moi3d.com/reinstall.htm .
6507.409 In reply to 6507.408
Hi Michael Gibson
thank you for your replay , long story short , i bought MOI at work and i had a problem installing it with all the security they had , so in order to bypass the security i dragged and drop the moi file from another computer with no security , and it seems to work fine sense , i got fired from my job and couldn't get all my original files , all i left with is this file ''MoI 3.0 beta Mar-17-2013'' and i know it looks like i got a cracked version i already looked and searched for solutions but i was sure this error is because i don't have it installed the right way ,anyway thanks for your help and god bless .
6507.410
How do I change the colors for the icons from black as displayed, to white as I have a dark background and they don't show up very well. All my icons are already white so I assume the code in Max's HTML for the four icons in question has something to do with it?
Ron
6507.411 In reply to 6507.410
Hi Ron, the CustomUI scripts use a button image that is embedded in the script file itself so you'll need to edit the script so the button loads an image file instead of using the embedded image.
To do that go to your MoI appdata startup folder and edit the CustomUI files there like the file "70 ObjLibrary.js" is what adds the "Obj Library" button.
It will currently look like this:
var title = "Obj Library";
var menu = "moi://appdata/customui/ObjLibrary.menu.htm";
var icon = "data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAEAAAABACAYAAACqaXHeAAAAGX ...
moi.ui.commandBar.CommandBarCustomUI.insertAdjacentHTML( "beforeEnd", '<moi:Spacer/> ...
Comment out line #3 for the icon value by putting a // in front of it, and then add a new line for an image file like this:
//var icon = "data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAEAAAABACAYAAACqaXHeAAAAGX ...
var icon = "icons/YourIconFile.png";
That should then make it load a file named YourIconFile.png from the ui\icons folder.
The above description is for MoI v4. For MoI v3 you would edit the file "70 ObjLibrary.htm" located in your install directory under ui\customui and change it from this:
<moi:CommandMenuButton menu="customui/mods/ObjLibrary.menu.htm" icon="data:image/png; ...........">Obj Library</moi:CommandMenuButton>
to this:
<moi:CommandMenuButton menu="customui/mods/ObjLibrary.menu.htm" icon="icons/YourIconFile.png">Obj Library</moi:CommandMenuButton>
6507.412 In reply to 6507.411
Hi Michael. Thanks for your help. Just wondered why he would embed the image rather than just pointing to it?
Ron
6507.413 In reply to 6507.412
Hi Ron, no problem!
I'm not sure, maybe something like he wanted to reduce the number of files that had to be managed.
6507.414
Hi All,
Dose any one know how make the Z Axis on the grid visible on in the 3D view port?
6507.415 In reply to 6507.414
Hi Ogar,
Sorry no there isn't any way set up to show that currently.
6507.416 In reply to 6507.414
Not quite the z-axis request, but a line can be drawn at the position of the z-axis, even in Front or Right view,
or a construction line can be added.
6507.417 In reply to 6507.416
Hi, I suppose you could add a vertical polyline and colour it however you want then lock it. Save the scene as a template and load from that each time. Not perfect but I think it would work :)
Ron
Show messages:  1-17  …  338-357  358-377  378-397  398-417  418-437  438-457  458-477  …  518-522
