CustomUI
 1-9  …  290-309  310-329  330-349  350-369  370-389  …  510-522
6507.330
Hey, Max Smirnov!
I've been having an issue with CustomUI that I haven't been able to wrap my head around solving. When I create a new library location that isn't the default object location within the appdata folder, the thumbnails/snapshots taken of the objects in question fail to draw in the UI, however the Object folder continues to work just fine.
I've attached a screenshot showing you the details of my problems. I'm already running MoI with administrator privileges, and I haven't altered the HTM files other than the addition of the a 2nd library location. I'll attach that file as well in case I've somehow entered the path incorrectly.
6507.331 In reply to 6507.330
Hi LocusDio, if I remember right the icons are displayed in the HTML UI using the moi://appdata protocol . So you probably need to have them located under the appdata folder for them to be loaded.
6507.332 In reply to 6507.331
Thank you so much, Michael. I was hoping to avoid having them be saved in the appdata folder, as i have this folder synced with my NAS so i have the ability to access the files anywhere. If this is my only solution, however, I'll gladly accept it.
Thank you so much for your reply, I appreciate the help.
6507.333 In reply to 6507.332
Hi LocusDio, you might try putting in a symlink inside of appdata that links to your other folder. See if this helps:
https://lifehacker.com/5496652/how-to-use-symlinks-in-windows
6507.334 In reply to 6507.333
I can't thank you enough for that information, Michael. Works flawlessly!
6507.335 In reply to 6507.268
C:\Users\<username>\AppData\Roaming\Moi\
I'm unable to find this folder with my usersame.
6507.336 In reply to 6507.335
Maybe you must enable "Show hidden files" ?
My Moi French Site My Gallery
6507.337 In reply to 6507.335
Hi Suzanne,
Try using Win+R to bring up the Windows "Run" dialog, and then put in:
%Appdata%\moi
That should then open up the MoI userdata folder. I think it may be in slightly different locations on different Windows versions but there is an environment variable named Appdata and if you put % % around it like above it will substitute it in.
6507.338 In reply to 6507.337
I've just started using your wonderful program and I'm wondering if you could help with getting CustomUI to work.
I'm using version 3 and I think I have narrowed down the issue to the commandbar.htm file.
The new version of CustomUI that I've downloaded doesn't seem to have the new version of Commandbar.htm, do you know where I could get this from? I believe the fact that I cannot write over this file is the reason that I can't get CustomUI.
Any help you could provide would be most welcome
6507.339 In reply to 6507.338
Hi TheSpur, the modified CommandBar.htm file for MoI v3 is contained inside the CustomUI.1.03.win.mac.zip which is an attachment on the first message of this thread, go to the bottom of the first message to find the attachments.
It's inside of the \ui subfolder inside that .zip . To install it, the contents of the .zip file are meant to be copied to MoI's main program directory, so there would be new sub-folders for objects and snapshots that are children of the main installation folder, and the contents of the .zip's ui directory should go into MoI's existing ui folder, overwriting the existing CommandBar.htm file.
6507.340 In reply to 6507.1
Hello Everyone,
I am new to using Moi and came across this awesome feature.
However I can’t seem to get the icons to appear in Moi. I am using version 3.0 can anyone help ?
The first instruction for installation is backup/ui/CommandBar ?
Really noob question but I have no idea what this means ?
Thank you in advance
6507.341 In reply to 6507.340
This means that you must maybe save your original folder ui/CommandBar in your favorite save place in case of problem with your future UI! ;)
6507.342 In reply to 6507.340
Hi Takeda, yes part of the installation of the CustomUI extension is that it overwrites one of MoI's files, it's a file named CommandBar.htm that is in the \ui sub-folder inside of MoI's main installation.
So the backup step means to save your original CommandBar.htm file somewhere else so if you have any problem you can restore the original back again without needing to do a full re-install.
Message 6507.343 deleted 28 Dec 2018 by THARSO
6507.344
Hi, Where can I find light options addon? I found one that didnt work with this plugin. Thx
6507.345 In reply to 6507.344
Hi Tharso,
Which version of CustomUI are you using - the one for MoI v3 or the one for MoI v4?
6507.346
Just tried to apply CustomUI to new beta, but it doesn't worl correctly - scripts, object and lighting options folders are empty. Anyone has CustomUI setup which works for last beta?
6507.347 In reply to 6507.346
Hi glmr,
The latest version of customUI works very well when installed properly in MoI4 beta.
Are you Mac or Windows?
6507.348 In reply to 6507.347
I am on Windows. MoI 4.0 beta Oct-17-2018
UPD: I'm an idiot who doesn't read instructions. Now it works.
EDITED: 13 Jan 2019 by GLMR
6507.349 In reply to 6507.348
UPD2: can't find snapshot button even with correct installation
Show messages:  1-9  …  270-289  290-309  310-329  330-349  350-369  370-389  390-409  …  510-522
