CustomUI
 1-7  …  228-247  248-267  268-287  288-307  308-327  …  508-522
6507.268
CustomUI v2.0 beta2
This version works with MoI v4 beta Feb-09-2018 only!!! (and with all later versions of course)
CustomUI should be stored in AppData directory. CustomInit loader has been removed. Now CustomUI uses appdata/startup directory.
Installation (Win):
Remove all previous versions of CustomUI
Extract CustomUI.2.0.beta2.zip to C:\Users\<username>\AppData\Roaming\Moi\
Installation (Mac):
Extract CustomUI.2.0.beta2.zip to /Users/<username>/Library/Application Support/Moi/
After installation remove all unneeded .js scripts from startup directory
P.S. I have some problems with Screenshot addon. I'll add it later.
UPD: I wrote a simple javascript injector which works good with the new MoI's loader. Screenshot and CamSwitch mods has been added.
EDIT 2/13/2023 - (Michael Gibson) Download link here: CustomUI.2.0.beta2.zip
EDITED: 13 Feb 2023 by MICHAEL GIBSON
6507.269 In reply to 6507.268
Hello Max!
Thank you very much for this update!!
I have only one problem, I don't have subdiv_beta_10 but only beta_09.
Where I can download it ?
Thanks a lot for support!
6507.270 In reply to 6507.269
Hi Marco,
It's my fault. subdiv_beta_10 is not released yet :)
I uploaded a fixed version of CustomUI archive.
6507.271 In reply to 6507.270
No problem Max!
Uploaded this new version and all works fine. Thanks :)
Ciao!
6507.272
Hi there,
Sorry ... but I really would like to ask you if it wouldn't be possible to make a little video tutorial on how to install the CustomUI.
I work with MoI3d v.3 and got the CustomUI v.1.03 but I wasn't able to get the desirable result.
Thank you.
6507.273 In reply to 6507.272
Hi jing,
What operating system are you using? Can you show a screenshot of where you've copied the files?
6507.274
Max - your latest CustomUI + MoI v4 beta Feb-09-2018 is now even easier to install and maintain - THANK YOU :)
One reminder suggestion/tip for CustomUI newbies - instead of:
I still prefer Max's initial suggestion from his first post (edit by me in square brackets for latest Win location):
>Go to the [Win: %APPDATA%\Moi\startup ] directory and select modules which you want to use. To disable module, just put "-" symbol at the beginning of a filename (most of modules are already disabled).
- Hamish
I put a subdirectory in the Startup directory, to save a copy of the removed file(s). (Saved a copy of Max's sidepane mod, in case I want to use it in the future.)
6507.276 In reply to 6507.268
Hi Max;
I Installed CustomUI per your instruction for MoI v4 beta Feb-09-2018, window version. I am getting error message when MOI starts. the *.js files in startup folder do not load.
Any idea what is the problem?
-sharif
Size: 59.4 KB, Downloaded: 546 times, Dimensions: 1336x406px
6507.277 In reply to 6507.276
Hi Sharif, the error looks like the CustomUI script code isn't able to access an element that it's expecting to find in the CommandBar.htm file.
Did you possibly copy an older version of CommandBar.htm into your current installation?
6507.278 In reply to 6507.277
Hi Michael;
I have customized the commandbar.htm. It works with CustomUIBeta1, But it doesn't work with CustomUIBeta2. I have attached the commandbar.htm file that I am using.
Thanks;
-sharif
6507.279 In reply to 6507.278
Hi Sharif - your customized version is based off of an old version of CommandBar.htm . You'll need to reapply your customization on the newer CommandBar.htm that's included with the Feb-9-2018 release in order for the latest CustomUI to work properly. If you just copy over your older file you end up losing changes in the regular install.
6507.280 In reply to 6507.279
Hi Michael;
I modified the new commandbar.htm and everything works now.
Thanks for help.
-sharif
6507.281 In reply to 6507.1
great thank you! i have just purchased moi 3d V3 and am trying to install the (SMIRNOV) custom ui its adding everything like alignments and scripts ok, but i cant seem to save my objects to the object library. the option to put in name comes up i type a name but when i click the library the new item not there just the default 3 objects cube, sphere and plane surface ....i cant find what im doing wrong in any forum could you offer any advise?
best regards Neil
6507.282 In reply to 6507.281
Windows or Mac?
6507.283 In reply to 6507.281
Hi Neil, re: saving to objects library not working - it's probably a permissions issue. Please see if this helps:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8824.15
6507.284 In reply to 6507.268
你好!
请问这个脚本如何安装?
我使用 moi3d v3版本的
按照您说的方式安装CustomUI v2.0 beta2,却无法使用,请问你可以提供详细教程吗?
谢谢!
6507.285
how is possible to change snapshot's view? I'm trying different views, but every time get only right view snapshot
6507.286 In reply to 6507.285
Hi glmr,
To set the focus on the desired view, first click on a shape in the view, then use snapshot.
Michel
6507.287 In reply to 6507.286
thank you! it works now
Show messages:  1-7  …  208-227  228-247  248-267  268-287  288-307  308-327  328-347  …  508-522
