CustomUI
 1-16  …  217-236  237-256  257-276  277-296  297-316  …  517-522
6507.257 In reply to 6507.254
You're welcome Max.
Have a nice day.
6507.258
Thanks Max.....awesome!
www.jameselliott.co.uk
6507.259
Hi Max,
I have installed all and everything is working perfectly, except for one thing..... I have copied the contents only of the object folder and pasted it into the new objects folder.....all is showing and present except the objects are not in sequential order, or infact any order that I can tell. Please see screenshot attached. Have you any idea how I can force them to be read in a sequential and Alphabetical order?
Thank you
James Elliott
Size: 499 KB, Downloaded: 328 times, Dimensions: 1440x1316px
6507.260 In reply to 6507.259
where u download all of that objects??
6507.261 In reply to 6507.260
I drew them!
6507.262 In reply to 6507.259
Hi James,
replace customui/mods/ObjLibrary.menu.htm file with this one
EDITED: 7 Mar 2022 by SMIRNOV
6507.263
Hi Max,
Thank you, works a treat!
<< sequential and Alphabetical order?
What is a sequential order ? by date ? by size ?...
6507.265
Max, many thanks for CustomUI v2.
I'm after some help setting up the ExtScripts directory on OSX with MoI v4 beta Dec-12-2017 please. I'm probably just missing something quite obvious.
In the ExtScripts.cfg.htm file, at the following location on OSX:
/Users/xxxx/Library/Application Support/Moi/customui/mods/ExtScripts.cfg.htm
I wrote:
I tried with and without the tilda and changing forward to back slashes - still nothing.
I can only access the scripts in MoI v4, if I actually copy them to the MoI commands directory - i.e. this one:
/Applications/MoI v4 beta Dec-12-2017.app/Contents/Resources/commands
Any suggestions much appreciated, thanks :)
6507.266 In reply to 6507.265
Hi hairykiwi,
at the moment MoI (and CustomUI) doesn't support an external script directory. To make ExtScripts work you need to remove ExtScripts.cfg.htm file.
EDITED: 31 Jan 2018 by SMIRNOV
6507.267 In reply to 6507.266
Hi Max,
Many thanks for your reply - that's great to know, but also adds to my confusion.
Are you saying it *did* work (under v3?), but under v4 currently doesn't, or the feature never did work?
Either way, it would be great if you could clarify the instructions you wrote about this feature in your initial post, copied below - or consider adding to that first post a link to later posts detailing significant changes. I appreciate what I'm suggesting is a bit of a hassle, but I thought I'd read all the 260+ posts to ensure I was up to speed on the latest install details, and don't recall reading anything saying the feature wasn't active.
quote:
By default this addon checks only /commands directory, but you can create /customui/mods/ExtScripts.cfg.htm with notepad to add any directory you want.
Example:
MOI\commands
MOI\commands\myscripts
MOI\myscripts2
D:\dir1\dir2\myscripts3
Much respect for all you've done,
Hamish
6507.268
CustomUI v2.0 beta2
This version works with MoI v4 beta Feb-09-2018 only!!! (and with all later versions of course)
CustomUI should be stored in AppData directory. CustomInit loader has been removed. Now CustomUI uses appdata/startup directory.
Installation (Win):
Remove all previous versions of CustomUI
Extract CustomUI.2.0.beta2.zip to C:\Users\<username>\AppData\Roaming\Moi\
Installation (Mac):
Extract CustomUI.2.0.beta2.zip to /Users/<username>/Library/Application Support/Moi/
After installation remove all unneeded .js scripts from startup directory
P.S. I have some problems with Screenshot addon. I'll add it later.
UPD: I wrote a simple javascript injector which works good with the new MoI's loader. Screenshot and CamSwitch mods has been added.
EDIT 2/13/2023 - (Michael Gibson) Download link here: CustomUI.2.0.beta2.zip
EDITED: 13 Feb 2023 by MICHAEL GIBSON
6507.269 In reply to 6507.268
Hello Max!
Thank you very much for this update!!
I have only one problem, I don't have subdiv_beta_10 but only beta_09.
Where I can download it ?
Thanks a lot for support!
6507.270 In reply to 6507.269
Hi Marco,
It's my fault. subdiv_beta_10 is not released yet :)
I uploaded a fixed version of CustomUI archive.
6507.271 In reply to 6507.270
No problem Max!
Uploaded this new version and all works fine. Thanks :)
Ciao!
6507.272
Hi there,
Sorry ... but I really would like to ask you if it wouldn't be possible to make a little video tutorial on how to install the CustomUI.
I work with MoI3d v.3 and got the CustomUI v.1.03 but I wasn't able to get the desirable result.
Thank you.
6507.273 In reply to 6507.272
Hi jing,
What operating system are you using? Can you show a screenshot of where you've copied the files?
6507.274
Max - your latest CustomUI + MoI v4 beta Feb-09-2018 is now even easier to install and maintain - THANK YOU :)
One reminder suggestion/tip for CustomUI newbies - instead of:
I still prefer Max's initial suggestion from his first post (edit by me in square brackets for latest Win location):
>Go to the [Win: %APPDATA%\Moi\startup ] directory and select modules which you want to use. To disable module, just put "-" symbol at the beginning of a filename (most of modules are already disabled).
- Hamish
I put a subdirectory in the Startup directory, to save a copy of the removed file(s). (Saved a copy of Max's sidepane mod, in case I want to use it in the future.)
6507.276 In reply to 6507.268
Hi Max;
I Installed CustomUI per your instruction for MoI v4 beta Feb-09-2018, window version. I am getting error message when MOI starts. the *.js files in startup folder do not load.
Any idea what is the problem?
-sharif
Size: 59.4 KB, Downloaded: 546 times, Dimensions: 1336x406px
Show messages:  1-16  …  197-216  217-236  237-256  257-276  277-296  297-316  317-336  …  517-522
