CustomUI
 1-19  …  200-219  220-239  240-259  260-279  280-299  …  520-522
6507.240
Thank you so much! :) I'm new to MoI and already got so good results quickly instead of modeling everything in Polygons! And your Addon makes it even better! :)
6507.241
Hi everybody! :)
CustomUI v2
http://moi.maxsm.net/media/files/CustomUI.2.0.beta1.zip
http://moi.maxsm.net/media/files/CustomUI.2.0.beta1.CommandBar.zip
This version works with MoI v4 beta Dec-12-2017 only!!! (and with all later versions of course)
Now CustomUI should be stored in AppData directory.
Installation (Win):
Extract CustomUI.2.0.beta1.zip to C:\Users\<username>\AppData\Roaming\Moi\
Make backup copy of existing C:\Program Files\MoI 4.0 beta Dec-12-2017\ui\CommandBar.htm
Extract CustomUI.2.0.beta1.CommandBar.zip to C:\Program Files\MoI 4.0 beta Dec-12-2017\ui\
Installation (Mac):
Extract CustomUI.2.0.beta1.zip to /Users/<username>/Library/Application Support/Moi/
Make backup copy of existing /Applications/MoI v4 beta Dec-12-2017.app/Contents/Resources/ui/CommandBar.htm
Extract CustomUI.2.0.beta1.CommandBar.zip to /Applications/MoI v4 beta Dec-12-2017.app/Contents/Resources/ui/
Cool adaptation!
Bravo!
EDITED: 8 Jan 2018 by PILOU
6507.243 In reply to 6507.241
Wanderful!!
Thanks a lot Max!!
It works :)
6507.244 In reply to 6507.241
Hi Max,
Outstanding work. Thanks a lot - it works fine.
-moritz
6507.245 In reply to 6507.241
Thanks for the update Max! That's great that it goes in AppData now.
I've been thinking that for the next beta how about if I have MoI look through some specific directory in AppData for any .js files and if any are found it will execute them. I'll also put in an empty named container element in CommandBar.htm by default that can be used as a target for where to insert controls. Then with that in place hopefully it wouldn't be needed to modify CommandBar.htm anymore and CustomUI would stay active between different releases.
A couple of issues are - what should the directory containing scripts to execute at startup be called, maybe just plain "startup" ? I guess there should also be a "commands" and "scripts" directory that you could make there as well. But then will having MoI look in 2 different commands directories for things cause problems since currently there's only one that is identified by moi.filesystem.getCommandsDir() ? And what should happen if there is a file with the same name in both places, which one should be actually loaded?
Also when should startup scripts run - probably just before the main window is shown?
6507.246 In reply to 6507.245
Hello Michael!
I'm not Max but I write here my thoughts about your questions :)
1) "what should the directory containing scripts to execute at startup be called, maybe just plain "startup" ? I guess there should also be a "commands" and "scripts" directory that you could make there as well."
I would call it "autostart"
2) "But then will having MoI look in 2 different commands directories for things cause problems since currently there's only one that is identified by moi.filesystem.getCommandsDir() ? And what should happen if there is a file with the same name in both places, which one should be actually loaded?"
I would make another API called "moi.filesystem.getAlternativeCommandsDir()"
If there is a command with the same name in both places I think that the priority should go to the "standard" command folder,
or you could use a sort of "prefix" to force a command to be searched into a specific path.
For example "#something" could be used to execute the "something" command contained into the AppData "commands" or "scripts" folders,
while simply writing "something" will run the command from the standard location.
3) "Also when should startup scripts run - probably just before the main window is shown?"
Hmm....I think that startup scripts should run just immediately after that all the UI objects are accessible, just like the "document ready" of standard JavaScript or jQuery.
Ciao!
6507.247 In reply to 6507.246
Hi Marco, thanks for your feedback!
I was thinking "startup" might have some chance at being more familiar since that's what Windows uses for a similar mechanism.
Hmmm, maybe. But if it's always in the same place in appdata it should be possible to get it by moi.filesystem.getAppDataDir() + 'commands\\' already.
I'm just not entirely sure what side effects having commands being a combination of 2 folders will have - stuff in CustomUI that builds the scripts menu by enumerating the files in the commands directory would need some adjustment. I'm trying to think of anything else that might be sensitive to it.
The good part about doing this is that when a standard command gets updated with something new, it will run that new one. So someone won't wonder why they aren't seeing the new feature that was just released. The bad part is that it won't be quite as easy to override built in commands but maybe that's for the best anyway. Having a special syntax to choose one over the other doesn't really help because it would only apply to a shortcut key and not buttons in the side pane for example.
Yeah when the UI is finished loading that's when the main window is shown so just before that would probably be good.
Thanks, - Michael
6507.248 In reply to 6507.247
You're welcome Michael.
Have a nice day.
6507.249
can Max's UI be installed in version 4 beta portable.
Barry
6507.250 In reply to 6507.249
Thanks a lot Max !
Just a little thing :
I have this error when i want to try Sudiv in the customUI2
ReferenceError: Can't find variable: _Subdiv_beta10
line 1
Thanks again...
edit :
i've replace _Subdiv_beta10 by _Subdiv_beta9 in 88 SubdivTools file and it's OK now.
EDITED: 9 Jan 2018 by FINEMA
6507.251
'CustomUI would stay active between different releases'
That would be great! Thanks Michael.
Thanks Max for the CustomUI update.
Carlos
Nodeedit is disabled in the new custom UI. (?)
Move nodeeditor directory to AppData/.../moi, beside customui directory, then doubleclick on customui and remove dash in front of -97NodeEdit.htm. (?)
6507.253
Hi Michael
It's a good idea. I thought about one file (something like autorun.js), but if you make a separate directory it will be much better. In this case the execution list should be sorted by name, so we can manage the order of execution.
You can give a name to <flex> container.
Yes. Startup is a good name.
>>I guess there should also be a "commands" and "scripts" directory that you could make there as well. But then will having MoI look in 2 different commands directories for things cause problems since currently there's only one that is identified by moi.filesystem.getCommandsDir()?
In my opinion the moi.filesystem.getCommandsDir() command should point to commands directory with MoI's built-in scripts.
For a user commands directory you can add another command. something like moi.filesystem.getUserCommandsDir()
But do we need it? I think moi.filesystem.getAppDataDir()+"commands\\" will be enough.
I think the current commands directory with MoI's built-in scripts should have higher priority.
Yes.
I don't remember, does MoI have a command which refreshes MoI UI? It can be useful in some cases.
6507.254
Finema
Yes, _Subdiv_beta10 is not released yet ;) It's an experimental version.
Brian
It disabled by default.
You're right, now Nodeeditor can be stored in AppData directory
Barry
It should work right now, but you need to edit icon paths.
I'll add support of portable version later.
Marco
moritz
Thank you! :)
6507.255 In reply to 6507.254
Thanks a lot max for your good job!
6507.256 In reply to 6507.253
Hi Max, so I'll set that up for the next beta.
There isn't a special MoI call for it but I think the built in HTML window.document.reload( true ); should work.
You can get all the things to reload by calling var panels = moi.ui.getUIPanels();
Or if there is a particular one you want var panel = moi.ui.getUIPanel( url );
6507.257 In reply to 6507.254
You're welcome Max.
Have a nice day.
6507.258
Thanks Max.....awesome!
www.jameselliott.co.uk
6507.259
Hi Max,
I have installed all and everything is working perfectly, except for one thing..... I have copied the contents only of the object folder and pasted it into the new objects folder.....all is showing and present except the objects are not in sequential order, or infact any order that I can tell. Please see screenshot attached. Have you any idea how I can force them to be read in a sequential and Alphabetical order?
Thank you
James Elliott
Size: 499 KB, Downloaded: 328 times, Dimensions: 1440x1316px
Show messages:  1-19  …  180-199  200-219  220-239  240-259  260-279  280-299  300-319  …  520-522
