CustomUI
 1-9  …  150-169  170-189  190-209  210-229  230-249  …  510-522
6507.190 In reply to 6507.1
Hello all,
It's been a while since I've visited the forum,
so I'm sorry if this has been covered before.
I couldn't find anything on it.
How does the snapshot option of the CustomUI work?
When I click on it, the screen blinks but doesn't put an image in the snapshot folder.
I have the snapshot folder located in MoI's main folder. Not sure what I am doing wrong.
I have a few other questions, but I thought I'd start out with this one 1st. :-)
Jesse
6507.191 In reply to 6507.190
what os?
6507.192 In reply to 6507.190
Hi Jesse, in recent versions of Windows, the operating system tries to prohibit programs from changing anything under c:\Program Files other than when it was installed, as a way to keep things from being messed with by viruses and things like that.
Since the CustomUI Snapshots directory is in there, that means that by default it won't be writable.
But if you give a program elevated privileges it will then allow it to write stuff there.
One way to give a program elevated privileges is to right-click it and choose "Run as administrator". If you do that, does the snapshot function start to work ok for you during that run? If so then you can set it to always run as administrator by right-clicking the shortcut, go to Properties, Compatibility tab and there's a checkbox at the bottom "Run this program as an administrator", if you set that the shortcut will always launch it with elevated privileges.
It would probably be better to have the snapshots folder located somewhere that was writable by default, like under %AppData%\Moi\snapshots, that way it would work without needing the program to have elevated privileges.
6507.193 In reply to 6507.190
Hi Jesse,
I agree with Michael with keeping your data out of the Programs directory and putting it somewhere else you can do that following these instructions earlier on this thread http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.53
Did the same thing with the objects.
6507.194 In reply to 6507.1
Hi, is customUI now valid for moi3D ?
thakx
6507.195 In reply to 6507.194
Yes. CustomUI works great with MoI 3.0
6507.196 In reply to 6507.195
Hi Max, I just installed the CustomUI on my Mac and really like it. Great work! Thank you.
Please can you advice regarding the lightning button, it currenly says no Options Add on found. Where can I find that add on and where would I need to copy it?
Thank you
Tarek
EDITED: 8 Nov 2014 by TAREK
6507.197 In reply to 6507.196
HI TAREK
I just had to figure this out again recently, when installing on my laptop.
Max and PILOU answered this question many posts back.
Dino's lightingoptions htm file needs to be copied to the Moi ui folder.
It is located at post 48 here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.48
Part of the answer is post 82, here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.82
(Open Moi and visit Options/View/LightingOption. Just visit, no need to do anything.)
EDITED: 8 Nov 2014 by BEMFARMER
6507.198 In reply to 6507.197
Thank you Brian,
All worked well after I followed the posts. Much appreciated.
Tarek
6507.199
i am new to moi. i installed the custom ui and it looks great, but i do not see gear or bearing under my objects tab. have i done something wrong? any help is appreciated. thanks
joe
oh...i forgot to mention i am still working off the trial version with intent to purchase. sort of trying to decide between moi and cubify
6507.200 In reply to 6507.199
Deleted due to incorrect statements :-)
EDITED: 17 Mar 2017 by BEMFARMER
6507.201 In reply to 6507.199
Hi joe,
No, you have done nothing wrong - that is normal. The Objects tab is primarily meant to hold objects that you yourself create, there are a couple ones in there as demos but the specific demo ones have changed from time to time and the current one just does not happen to have the gear or bearing included as part of the demo objects.
6507.202
Snapshot
Shift + click = resolution x 2
Ctrl + Shift + click = resolution x 3
Doesn't work with my Mac /OS.
6507.203 In reply to 6507.202
Hi Jay, I'm not sure where the snapshot script is coming from, is it on the scripts menu that pops up?
Is it a custom script that you have added in yourself or something like that?
6507.204
No, I just installed Max' CustomUI.
As in the first Post described:
"Snapshot
With this addon you can make a snapshot of last clicked viewport.
Resolution is fixed: 1600x1200
Left click - grid is visible
Right click - grid is hidden
Snapshots will be saved to "snapshots" directory."
LeftClick and RightClick on the button work fine.
Combination with Shift or Ctrl+Shift works not and my Backgroundcolor stays white.
6507.205 In reply to 6507.204
Hi Jay, I took a quick look and from what I can see the resolution is getting so high with the x2 and x3 options that the render mechanism would consume a quite large chunk of video memory in order to be able to function and that is failing for you.
What type of video card does your machine have, does it have a lot of video memory available on it?
It's also possible that the mechanism MoI uses for running on the Mac is not able to use the entire amount of your video memory and trying to use some unusually large giant block of it is failing.
When the render call fails, that probably generates a script exception and then the rest of the script that does the cleanup stuff for restoring background colors and such does not run, that's why your screen stays white.
6507.206 In reply to 6507.204
I tried out all 4 snapshots with a curve and points.
The first two looked very good.
The last two were huge files, and were badly faded. The points are tiny, and almost invisible.
(On Windows 7)
6507.207 In reply to 6507.206
Hi Brian, yeah currently there isn't any way to scale the display of points up dynamically like you would want with a very high resolution screen render.
The points are drawn based on bitmaps in the \ui sub-folder: Point.png, Point_selected.png, Point_transitionfromselected.png and Point_transitiontoselected.png .
You can modify the point size in a permanent way by changing those bitmaps, if you make a larger bitmap it will make the points larger too. But since they are not composed dynamically there isn't any way to just temporarily change them only for the render itself.
It can be possible to avoid the curve display from getting fainter by adjusting the script to make the setting for mio.view.lineWidth to be larger when doing a higher resolution capture, right now the script only seems to increase it up to 2 pixels in size, it probably needs to go more than that for the higher density ones.
6507.208 In reply to 6507.207
Thank you Michael.
No complaints here, just a new, for me, observation :-)
6507.209
I've got an iMac with a NVIDIA GeForce GTX 780M 4096 MB.
By the way, maybe there is a discussion somewhere:
If I got too many objects writing out a .pdf or .ai it is running out of memory.
Copy/Paste with a graphic-program (Sketch):
Sketch -> MoI = ok
MoI -> Sketch = false
Show messages:  1-9  …  130-149  150-169  170-189  190-209  210-229  230-249  250-269  …  510-522
