CustomUI
 1  …  122-141  142-161  162-181  182-201  202-221  …  522
The custom UI has not been working correctly for the Mar-24-2014 MoI beta, on my windows7 computer.
I could not figure out why a newly added script would not be updated in the custom UI. It did occasionally update,
after the new file was also added to the previous MoI beta command folder. So it is not a cache issue.
I finally edited the ini file, accessed from the MoI program, and found that the file directory was set for the prior MoI beta.
After editing the ini file to the correct C:\Program Files\Moi 3.0 beta Mar-24-2014, the custom UI is working correctly again.
I do not know how the problem originated. Maybe from importing a .3dm?
The previous MoI beta is now uninstalled and deleted.
So maybe it is best to uninstall old MoI betas?
6507.163
Brian, I had to do the same. Took a bit to figure out the issue. You have to love computers...
Ron
6507.164 In reply to 6507.162
Normally I'd recommend keeping an old beta around for at least a couple of weeks after a new beta is out, just in case there are any new bugs in the new beta that get in your way.
For the case of CustomUI in particular you will need to edit its path to go the new beta.
6507.165 In reply to 6507.164
Thank you Michael :-)
6507.166
All scripts have been rewritten using newest filesystem functions. Mac users now can rename and delete objects in the Object library.
Check the first post for update.
P.S. Added CustomUI version of the Dinos Script Palette script. http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=5993.1
EDITED: 28 Jun 2014 by SMIRNOV
6507.167 In reply to 6507.166
Cool :)
Does the manual of the first page is changed ?
6507.168 In reply to 6507.167
Hi Pilou
I changed scripts only.
6507.169 In reply to 6507.168
Thx for the info! So no new translation to make! :)
6507.170 In reply to 6507.168
Hi Max,
Can you help me with one edit I need to make?
For the path of a scripts directory has changed.
In the previous version, for the mods/ExtScripts.menu.htm there was a line like this to set a path to a folder:
var files = moi.filesystem.getFiles(moi.command.getOption('ExePath', false)+"\\commands", '*.js' ), scom = [];
Where "commands" is a folder to look in.....
The new version has this line:
var files = moi.filesystem.getFiles(moi.filesystem.getCommandsDir(), '*.js' ), scom = [];
How is this line modified to set a custom directory?
Thanks....
6507.171 In reply to 6507.170
Hi Burr, do you mean you want the custom directory to be one that's inside the installation folder like alongside "ui" and "commands" ?
If so you could do this:
var files = moi.filesystem.getFiles(moi.filesystem.getProcessDir()+"\\commands", '*.js' ), scom = [];
that should be the equivalent of the old one, it will get the location of the folder where MoI.exe is in, then stick \commands at the end of that, replace commands with what you need same as you did before.
6507.172 In reply to 6507.166
And thanks Max for updating this to work for Mac users too!
6507.173 In reply to 6507.171
Yes that was it... It was the difference between getCommandsDir and the getProcessDir you posted. I was trying a few variations with crashing, but was only changing the "+\\folder" part....
Thanks for responding in on that....
Burr
6507.174 In reply to 6507.170
Hi Burr,
now you can set any directory you want (check the first post).
Update mods/ExtScripts.menu.htm
Create mods/ExtScripts.cfg.htm file with the following content:
MOI\commands
MOI\commands\myscripts
6507.175
Thanks, works perfectly on new beta.
M.
6507.176 In reply to 6507.174
Thanks max... i will check out the cfg file too. It sounds handy. I needed the other one because i setup 2 extension scripts with 2 buttons in the commandbar....
6507.177
Thanks Michael for the latest Beta
In case anyone is interested , on the windows version to easily get my Moi beta back up and running with scripts and custom UI I do this
from the old beta version ( call it old ) I
Copy sidepane.htm from old UI into new UI (mine opens construct and transform at once).
Copy saveas.js and save.js from old commands into new commands overwrite the new ones (mine save a jpg also).
Copy all of the commands folder from old into the new commands folder but do not replace or overwrite anything in there.
This puts any commands you use like ringcircle etc in there
I copy the following so I know where they are.
Copy your moi.ini into the main moi directory of new
Copy your template file in there also
Copy your licience key into moi directory
Installation: of custumui.
- Backup /ui/CommandBar.htm (I just copy to the desktop)
- Extract CustomUI archive into the MoI directory
delete objects in new objects folder
Copy your objects from old objects file to new objects
copy snapshot.htm from old customui to new customui (mine is set to save as a jpg)
rename any parts of custom UI with a - in front that you don't want (I don't use the align buttons)
cheers
shayne
6507.178 In reply to 6507.177
Hi Shayne, apart from your sidepane.htm, saveas.js and save.js if you uninstall the previous beta all custom scripts and custom directories will be left behind then it's just a matter copy and paste, the only thing to replace is Max's CommandBar.htm
6507.179
Hi guys, I am getting this error. When it does load, there is nothing visually different about the UI?
Size: 43.3 KB, Downloaded: 203 times, Dimensions: 463x331px
6507.180 In reply to 6507.179
Hi yakas, that error probably means you are using an older beta release - that function that the error mentions is only in the most current v3 beta, the Jun-27-2014 version which you can get from here: http://moi3d.com/beta.htm
6507.181 In reply to 6507.180
Wow, that was fast. Works fine, woo hoo!
Show messages:  1  …  102-121  122-141  142-161  162-181  182-201  202-221  222-241  …  522
