CustomUI
 1-18  …  79-98  99-118  119-138  139-158  159-178  …  519-522
6507.119 In reply to 6507.118
I have placed the new CommandBar.htm (Aug 15,2013) 4KB into the Moi/ui folder. Still nothing.
Sorry for all this screwing around.
6507.120 In reply to 6507.119
Hi Mike,
check please, is Moi/ui/customui folder exists?
6507.121
customui folder (whole with contents) exists inside ui folder along with CommandBar.htm
Size: 61.5 KB, Downloaded: 335 times, Dimensions: 273x583px
Size: 90.3 KB, Downloaded: 289 times, Dimensions: 285x815px
6507.122 In reply to 6507.121
Also I get this (see image)
Size: 32 KB, Downloaded: 288 times, Dimensions: 374x264px
6507.123 In reply to 6507.122
Hi Mike, are you possibly using the older v2.52 version of MoI rather than the current v3 beta?
If so try getting the current v3 beta from here: http://moi3d.com/beta.htm - probably this stuff needs things that are only present in the v3 beta's infrastructure and are not in the older version.
6507.124 In reply to 6507.121
Everything is correct. It should work.
Check the CommandBar.htm. Is there "<script type="text/javascript" src="customui/CustomInit.js">" line?
Try to change it to
<script type="text/javascript" src="moi://ui/customui/CustomInit.js" />
EDITED: 24 Feb 2014 by SMIRNOV
6507.125 In reply to 6507.124
I opened CommandBar.htm in Text Wrangler and I don't see the line you are referring to. What line?
6507.126 In reply to 6507.125
Just saw the message about script error.
Yes, the script works with v3.0 only. Mike, you need to upgrade your software.
6507.127 In reply to 6507.126
Still no go here.
Size: 280.2 KB, Downloaded: 317 times, Dimensions: 1245x624px
6507.128 In reply to 6507.127
Hi Mike,
> Still no go here.
Are you still getting that script error or not any script error anymore?
If you could not find the lines that Max was referring to above inside your CommandBar.htm then it means you somehow did not get that one file updated - it's the one file that needs to be overwritten...
6507.129 In reply to 6507.128
I downloaded from this portion of the early thread. Was this were I need to be when I downloaded it?
Size: 142.1 KB, Downloaded: 224 times, Dimensions: 1049x815px
6507.130 In reply to 6507.129
Sorry I don't get that error message with the beta!
6507.131 In reply to 6507.129
Hi Mike,
I think Max said to get the one from the 1st message in this thread, which is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
I just tested this over here on my Mac and it seems to be working ok for me.
What I did was right-clicked on the v3 beta's app icon and picked "Show package contents". Then inside there go to drive_c/moi
Then download the mac version .zip file that's an attachment on that first message.
Safari automatically unzips the file, go inside the unzipped directory and drag/drop both the "objects" and "snapshots" directories into drive_c/moi so you now have drive_c/moi/objects and drive_c/moi/snapshots.
Then go down inside of drive_c/moi/ui and also go into the /ui subfolder inside the downloaded one too. Grab all of that stuff tha's down inside of /ui and drag/drop it over into drive_c/moi/ui, if you have placed it in the correct spot Finder will warn you that there is one file that is a duplicate name (that's CommandBar.htm) and whether you want to keep both or replace it - choose replace here. After doing these steps then I was able to see the changes in MoI's bottom command bar.
Make sure you do not have MoI running while doing all that stuff.
Hope this helps!
6507.132 In reply to 6507.131
Thank you I will give this a try again!!!
6507.133 In reply to 6507.132
Got the interface to show but when I elect objects icon the program crashes.
Size: 53.9 KB, Downloaded: 163 times, Dimensions: 463x273px
6507.134 In reply to 6507.133
Hi mike, I can repeat a crash over here but only if the /objects subdirectory has not been placed.
So my guess is that you don't have that directory in the proper place, maybe go over those previous directions again and double check that you have a directory drive_c/moi/objects, it should contain 6 files, 3 PNGs and 3 3DM files.
You will need both "objects" and "snapshots" directories copied into the right place (into drive_c/moi) in order for this to work.
Both of those should be under drive_c/moi - if you have placed those particular ones under drive_c/moi/ui that's not right.
6507.135 In reply to 6507.134
It seems to be working now. I don't see all the objects that were shown in the first thread, gear,nut, bearing etc..
Thanks for hanging with me on this.
6507.136 In reply to 6507.135
Hi mike, that's great that you've got it working!
That seems to be normal - there's only 3 included by default in this particular package.
I think the main idea is you can add your own objects in there. If you select an object you want to put in there, open that menu and move your mouse to that title text that says "Object library". A plus mark will appear and when you click there it will put up a dialog for you to put in a name and that will make a new entry in the menu.
If you want some objects like that gear and what not, you can get a bunch of stuff like that over at http://grabcad.com .
6507.137 In reply to 6507.136
Thank you for your extraordinary help with this.
6507.138 In reply to 6507.137
No problem Mike!
Show messages:  1-18  …  59-78  79-98  99-118  119-138  139-158  159-178  179-198  …  519-522
