CustomUI
 1-14  …  75-94  95-114  115-134  135-154  155-174  …  515-522
6507.115 In reply to 6507.114
Hi mike,
> do I replace current contents add to or what? Sorry
You need to add the contents of the zip there. There will be one file that will be overwritten, then rest are added files.
So inside the zip are 3 directories: "objects", "snapshots", and "ui".
The "objects" and "snapshots" directories will be new - MoI does not already have any directories there of those names, so just move both of those there under drive_c/moi so that you now have directories drive_c/moi/objects and drive_c/moi/snapshots.
MoI already has a /ui folder, and you want to merge the contents of this new one onto the existing ui folder, not just completely replace the entire ui folder.
There will be one file /ui/CommandBar.htm that should get overwritten by what is in the .zip - the other things in the .zip should just be added to the ui folder.
Hope that helps!
6507.116 In reply to 6507.115
Thanks Michael. Isn't it amazing how much we take installers for granted!
6507.117 In reply to 6507.116
I believe I have followed the instructions properly but I don't see the new interface add-on.
6507.118 In reply to 6507.117
Hi Mike,
It should show up as some new things on the bottom toolbar. Make sure that one particular file "CommandBar.htm" has been replaced by the one in the .zip file. If you see no difference in the bottom toolbar it probably means that file has not been updated.
6507.119 In reply to 6507.118
I have placed the new CommandBar.htm (Aug 15,2013) 4KB into the Moi/ui folder. Still nothing.
Sorry for all this screwing around.
6507.120 In reply to 6507.119
Hi Mike,
check please, is Moi/ui/customui folder exists?
6507.121
customui folder (whole with contents) exists inside ui folder along with CommandBar.htm
Size: 61.5 KB, Downloaded: 335 times, Dimensions: 273x583px
Size: 90.3 KB, Downloaded: 289 times, Dimensions: 285x815px
6507.122 In reply to 6507.121
Also I get this (see image)
Size: 32 KB, Downloaded: 288 times, Dimensions: 374x264px
6507.123 In reply to 6507.122
Hi Mike, are you possibly using the older v2.52 version of MoI rather than the current v3 beta?
If so try getting the current v3 beta from here: http://moi3d.com/beta.htm - probably this stuff needs things that are only present in the v3 beta's infrastructure and are not in the older version.
6507.124 In reply to 6507.121
Everything is correct. It should work.
Check the CommandBar.htm. Is there "<script type="text/javascript" src="customui/CustomInit.js">" line?
Try to change it to
<script type="text/javascript" src="moi://ui/customui/CustomInit.js" />
EDITED: 24 Feb 2014 by SMIRNOV
6507.125 In reply to 6507.124
I opened CommandBar.htm in Text Wrangler and I don't see the line you are referring to. What line?
6507.126 In reply to 6507.125
Just saw the message about script error.
Yes, the script works with v3.0 only. Mike, you need to upgrade your software.
6507.127 In reply to 6507.126
Still no go here.
Size: 280.2 KB, Downloaded: 317 times, Dimensions: 1245x624px
6507.128 In reply to 6507.127
Hi Mike,
> Still no go here.
Are you still getting that script error or not any script error anymore?
If you could not find the lines that Max was referring to above inside your CommandBar.htm then it means you somehow did not get that one file updated - it's the one file that needs to be overwritten...
6507.129 In reply to 6507.128
I downloaded from this portion of the early thread. Was this were I need to be when I downloaded it?
Size: 142.1 KB, Downloaded: 224 times, Dimensions: 1049x815px
6507.130 In reply to 6507.129
Sorry I don't get that error message with the beta!
6507.131 In reply to 6507.129
Hi Mike,
I think Max said to get the one from the 1st message in this thread, which is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
I just tested this over here on my Mac and it seems to be working ok for me.
What I did was right-clicked on the v3 beta's app icon and picked "Show package contents". Then inside there go to drive_c/moi
Then download the mac version .zip file that's an attachment on that first message.
Safari automatically unzips the file, go inside the unzipped directory and drag/drop both the "objects" and "snapshots" directories into drive_c/moi so you now have drive_c/moi/objects and drive_c/moi/snapshots.
Then go down inside of drive_c/moi/ui and also go into the /ui subfolder inside the downloaded one too. Grab all of that stuff tha's down inside of /ui and drag/drop it over into drive_c/moi/ui, if you have placed it in the correct spot Finder will warn you that there is one file that is a duplicate name (that's CommandBar.htm) and whether you want to keep both or replace it - choose replace here. After doing these steps then I was able to see the changes in MoI's bottom command bar.
Make sure you do not have MoI running while doing all that stuff.
Hope this helps!
6507.132 In reply to 6507.131
Thank you I will give this a try again!!!
6507.133 In reply to 6507.132
Got the interface to show but when I elect objects icon the program crashes.
Size: 53.9 KB, Downloaded: 163 times, Dimensions: 463x273px
6507.134 In reply to 6507.133
Hi mike, I can repeat a crash over here but only if the /objects subdirectory has not been placed.
So my guess is that you don't have that directory in the proper place, maybe go over those previous directions again and double check that you have a directory drive_c/moi/objects, it should contain 6 files, 3 PNGs and 3 3DM files.
You will need both "objects" and "snapshots" directories copied into the right place (into drive_c/moi) in order for this to work.
Both of those should be under drive_c/moi - if you have placed those particular ones under drive_c/moi/ui that's not right.
Show messages:  1-14  …  55-74  75-94  95-114  115-134  135-154  155-174  175-194  …  515-522
