Trim surface control points
All  1-4  5-9
6503.5
Michael sorry but I did not understand, I insert the key into the box and the box command button what should I write?
Can you show me the steps please? how to derive the terms of the script?
For the edges I meant to click an edge and a command to select adjacent at same time
Size: 92.8 KB, Downloaded: 74 times, Dimensions: 898x746px
Size: 72.3 KB, Downloaded: 20 times, Dimensions: 946x823px
6503.6 In reply to 6503.5
Hi Tony,
You should put the name:     ShrinkTrimmedSrf     on the right-hand side.
So add in a new shortcut key (push the Add button at the top), and on the left hand side put in the key you want to trigger it, such as: T
Then on the right-hand side, put in the command name or script that you want to be triggered. In this case you want a command name there, put in: ShrinkTrimmedSrf
Now when you push that key, it will call the ShrinkTrimmedSrf command on the selected objects.
For that one you also need to set up a shortcut key and this time it needs a script on it, the script you put is this (copy and paste this into the right-hand side):
script:/*Loop selection*/moi.geometryDatabase.selectLoop();
You need to select 2 consecutive edges first before triggering it, see here for some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.22
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.32
6503.7
Thank you Michael;
Where can I find a list of scripts from utilizare with shortcuts
thanks
6503.8 In reply to 6503.7
Hi Tony, there is a collection of scripts here:
http://kyticka.webzdarma.cz/3d/moi/
That and many other links are listed on the Resources section of the wiki: http://moi3d.com/Resources
6503.9
Thanks Michael ;)
Show messages: All  1-4  5-9
