Trim surface control points
All  1-3  4-9
6503.4 In reply to 6503.3
Hi Tony, you'll need to set up a keyboard shortcut with the command ShrinkTrimmedSrf on it, then use that keyboard shortcut for activating the command.
> The control points do I need to change the curvature of the middle surface and leave unchanged
> the curvature of the original surface and then make a connection between the two.
You'll probably want to use the Construct > Blend command for doing this, it's usually best if you cut away a zone of open area between the 2 pieces, something like this:
If you run into a problem with Blend, make sure you have edges selected, not just curves selected. If you have curves overlapping on the same spot as edges you have to hide or delete those curves so you can select the edges instead.
> How do you activate the command to toggle the edges concatenated.
Do you mean to join the pieces together at the end? That's the Edit > Join command.
6503.5
Michael sorry but I did not understand, I insert the key into the box and the box command button what should I write?
Can you show me the steps please? how to derive the terms of the script?
For the edges I meant to click an edge and a command to select adjacent at same time
Size: 92.8 KB, Downloaded: 74 times, Dimensions: 898x746px
Size: 72.3 KB, Downloaded: 20 times, Dimensions: 946x823px
6503.6 In reply to 6503.5
Hi Tony,
You should put the name:     ShrinkTrimmedSrf     on the right-hand side.
So add in a new shortcut key (push the Add button at the top), and on the left hand side put in the key you want to trigger it, such as: T
Then on the right-hand side, put in the command name or script that you want to be triggered. In this case you want a command name there, put in: ShrinkTrimmedSrf
Now when you push that key, it will call the ShrinkTrimmedSrf command on the selected objects.
For that one you also need to set up a shortcut key and this time it needs a script on it, the script you put is this (copy and paste this into the right-hand side):
script:/*Loop selection*/moi.geometryDatabase.selectLoop();
You need to select 2 consecutive edges first before triggering it, see here for some examples:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.22
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.32
6503.7
Thank you Michael;
Where can I find a list of scripts from utilizare with shortcuts
thanks
6503.8 In reply to 6503.7
Hi Tony, there is a collection of scripts here:
http://kyticka.webzdarma.cz/3d/moi/
That and many other links are listed on the Resources section of the wiki: http://moi3d.com/Resources
6503.9
Thanks Michael ;)
Show messages: All  1-3  4-9
