Script list button next to object snaps
 1-11  12-21
6502.12 In reply to 6502.10
Sharif,but is it any way to put here simple scripts I do no know how to saw correctly, scripts that is inserted into moi shortcut list, not the external js or htm.
My Portfolio: www.samardac.tumblr.com
A lot of my Tutorials!
6502.13 In reply to 6502.12
Hi Andrei, you should be able to put anything you put inside a shortcut key inside of a button, insert it into the command=" " part of the button.
The only thing to be aware of is if the script itself has any quote " characters in it, switch any of those to single quote ' characters instead so that they won't be taken as the end of the command=" " attribute itself.
6502.14
Hi
Is there a way to change the background of the popup window
since i an using this colors for UI in Moi
6502.15 In reply to 6502.14
Hi Hep;
Open the "Plugins.htm" file and modify the RGB value See attached image.
-sharif
Size: 58.4 KB, Downloaded: 69 times, Dimensions: 1431x796px
6502.16
Thanks, that work perfect ;-)
6502.17 In reply to 6502.4
Hi
It would be helpful to get the custom scripts in a list as per image with just shortcut key like the space bar to activate. I love the list but would prefer to keep Moi UI as it is, without adding any buttons
There are so may good scripts coming out , its getting harder to have to remember the name and type them in all the time.
Mark
Size: 84.2 KB, Downloaded: 61 times, Dimensions: 690x1101px
6502.18 In reply to 6502.17
Maybe you can make a little file text where you can copy past from it the name of the script after Pressing TAB ?
6502.19 In reply to 6502.18
"Maybe you can make a little text file where you can copy past from it the name of the script after Pressing TAB ?"
thats a very good idea, although still a bit long-winded
but it would be nice to see a list after pushing a shortcut key within Moi . With the great new subD tools , its becoming more important.
6502.20 In reply to 6502.17
Hi Mark,
You might try this other script menu here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5993.1
That one does not add any buttons to the main UI, it pops up a dialog when you push your shortcut key to activate it.
6502.21 In reply to 6502.20
Hi Michael
Thanks for the redirect and solution. This will be helpful.
kind regards
Mark
Show messages:  1-11  12-21
