some challenge!!
 1-5  6-23
6474.6 In reply to 6474.5
Frenchy,
When you first navigate to the file, look for the checkmark for "use our downloader" and uncheck that... Don't install their downloader.
6474.7 In reply to 6474.6
too late... that makes some disturb on my browser!
And difficulties to remove it! :)
6474.8 In reply to 6474.7
There goes the rest of your day!!!! :(
Never need a downloader... They are marketing tools.
6474.9
Thanks guys, Michael interesting idea with chamfer and undo, I made chamfer surface using isocurves in my example. Burrman good idea but looks a bit complicated for me, I use Flow very rarely, it seems to me a bit complicated :) Anyway thanks.
I found today another method that is very fast, you have to set CPlain from view and then cut it. Very simple method but you have to go to ortho view and find good angle to cut.
Pilou, did not know about that stuff, just looked at download page, yes you have to uncheck - use our download manager. There was no this thing in the past :)
6474.10 In reply to 6474.9
No problem but I am sure that a lot of people make the same error than me! :)
6474.11 In reply to 6474.10
Pilou, did not know about it) This is new link: http://we.tl/qrvg08iiMM
Portfolio: www.samardac.tumblr.com
6474.12 In reply to 6474.11
Thx! this one was more clear! :)
6474.13
Like seeing different methods, here's another.
6474.14 In reply to 6474.13
Bravo DannyT, very cool! thanks!
6474.15 In reply to 6474.14
But one thing! How to control angle of this?
6474.16 In reply to 6474.15
Just found, some how it can be controled via chamfer. May be there is onother way to control it?
EDITED: 29 Jan 2014 by ANDREI SAMARDAC
6474.17 In reply to 6474.16
Maybe with this ?
6474.18 In reply to 6474.15
Hi Andrei,
One possibility is if you shoot a 3 point plane coming straight off that chamfer segment edge, you can then select it and use Transform > Rotate > Rotate axis to pivot it by your specific desired angle.
The "rotate axis" transform allows you to pick any line as the rotation axis and your object will pivot about that line.
Just make the plane long enough so that it sticks all the way up through the object after it has been rotated.
6474.19 In reply to 6474.18
Thank you Michael good solution!
6474.20 In reply to 6474.19
Pilou Im not sure I understood your method.
6474.21 In reply to 6474.20
It's just for regulate the 2 extremities of the object to boolean Diff from the big one!
Cut Path with 2 extremities choosen and sweep!
But caps are perpendicular to the path!
I suppose you know the Transform Orient / Orient for Slide an object perpendiculary (or not) to a path! :)
EDITED: 30 Jan 2014 by PILOU
6474.23
People, check out my new tutor about this subject: http://moi3d.com/forum/index.php?webtag=MOI&msg=6058.17
Show messages:  1-5  6-23
