Match surface without MatchSrf
All  1  2-3
6456.2 In reply to 6456.1
Hi anto, it's pretty difficult to replicate MatchSrf in this kind of manual way.
It tends to be easier to use Blend to do the whole job of generating the in between surface, I guess I'm not sure right now why you don't want to do it that way?
I guess the easiest way to get the same thing that Blend would do would be to make a blend and look at the blend surface's control points and snap on to those points if needed. If you need to get the shape at a particular spot use Construct > Curve > Iso to extract an isoparm of the blend surface at a particular spot and then look at that curve's control points.
6456.3 In reply to 6456.1
Or also it kind of seems like you may save a lot of work in your particular case here by just taking that into Rhino and using MatchSrf over there...
Show messages: All  1  2-3
