Fillet
All  1-6  7-8
6454.7 In reply to 6454.6
You are correct !! I was picking the solid and then trying to pick an edge. The solid was still lit as was the edge and that's why I was getting fillets at both ends.
When I 'drilled in' to just a surface it worked as you said. PERFECT !!!
Eliminating some of the construction lines helps ALOT too !
Good stuff !!!
Thanks again.
6454.8 In reply to 6454.7
Great, I'm glad that one is solved up!
This particular thing of construction curves in the same spot preventing edges from being selected tends to trip people up fairly often. Once you know what to look out for then it's ok after that, but I haven't quite been able to figure out a good solution to make the process a bit smoother from the beginning. In the future I'll probably try to experiment with some different improvements to selection in these particular situations.
Show messages: All  1-6  7-8
