flow problem
All  1-2  3-6
6453.3 In reply to 6453.1
hi matt
your base surface seems somewhat mangled. i guess, that's the cause of your problems.
..i did a redraw with a 3pt surface..
EDITED: 23 Jan 2014 by MARCO
6453.4 In reply to 6453.3
Does exist a cool trick for "flow" this form on some differrent target surfaces in the same time?
6453.5
Thanks for all the help, it work now?
Still learning something everyday with MOI :-)
matt
6453.6 In reply to 6453.4
No, flow only works from one base surface to one target surface at a time. It would probably be difficult to do multiple surfaces since currently the pick locations for where you click on each surface is significant and controls which corner and side of the base surface is matched to the other.
Show messages: All  1-2  3-6
