[script] FxGraph - 2D/3D Function plotter
 1-18  19-38  39-58  59-78  79-91
6447.39 In reply to 6447.37
""""""""""" the way Brian shows above runs the _FxGraph3D command but also gives it command line parameters."""""""""""""""""
Yes. But can that work from a js file? Like is it just missing a "command execute" or something? How to make those parameters pass from the js file? (Without a big rewrite.)
6447.40 In reply to 6447.39
Hi Burr, from what other .js file, do you have something like a launcher dialog you're setting up? You should be able to use moi.command.execCommand(); to do the same thing, it should support command line parameters just make sure there is a space between the command name and the parameters in the string you send to moi.command.execCommand() same as in the pasted in text.
6447.41 In reply to 6447.40
Hi michael,
No, i have no file i was working on. I just put the scripts from the forum in js files as opposed to shortcuts. This particular "command" didnt work from a js file.
Can you give me a quick example of using the moi.command.execCommand()?
I was looking to just put these last fxgraph (with parameters) scripts into named js files so i can call them that way.
6447.42 In reply to 6447.41
Hi Burr, sure - so the first one that Brian had here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6447.31 (the one labeled sinhLeaf) would be like this:
moi.command.execCommand( '_FxGraph3D u;v;((exp(u) - exp((-1)*u))/2 + (exp(v) - exp((-1)*v))/2);-3.14159;3.14159;-3.14159;3.14159;15;15;0;0;0;UV' );
Does that do what you need? If not can you post your .js file and tell me how it's launched so I can better understand what you're trying to do.
6447.43 In reply to 6447.42
Well, i dont know if it can be any simpler!!! Lol :)
Just put that command argument in the brackets of the moi.commamd.execCommand()..
(Edit) and end it with a semi colon. (Edit)
Thank you kind sir.
Any image of what the formula above do ? :)
6447.45 In reply to 6447.44
@Burr - you're welcome!
@Pilou, that particular one makes this:
6447.46 In reply to 6447.45
Thx! :)
6447.47 In reply to 6447.42
Thank you Michael. (I was trying to do some .js with #include _FXGraph3d...)
To implement Michael's code shown in post above, what I did was to create a file called _LeafSinh.js, in notepad++, and copy Michael's code to said file.
Then the _LeafSinh.js file was copied to the MoI3Command folder.
Now the "Leaf" FXGraph3D script can be selected, in MoI, from Ext.Scripts, Max's custom UI.
I think that I recall Burr setting up separate External Scripts files, so I plan to make one for just FXGraph3D scripts (?)
I'll have to look up how to do that...
EDITED: 26 Jul 2017 by BEMFARMER
6447.48 In reply to 6447.47
Hi bem,
Well, in these earlier versions of MoI you can just make a folder named "scripts" in the installation root. The command field in MoI reads that folder too.
But things in that folder are for "inline scripts" and they run seperately than commands.
For max's customui, i added a page and directed it to that folder.
I think michael has been discussing that he is looking at changing that seperation.
6447.49 In reply to 6447.42
Worked like a charm! As far as me spelling it out, I left out another part.
"Putting the command. with line parameters into the brackets (), the command is also surrounded by 's. So ('command')
Anyway.....
6447.50
It's fascinating how mathematical formulas can result in interesting shapes.
Here's one that I found on MathMod: Stereosphere
Copy (Ctr-c) the following and then within Moi hit Tab and paste (Ctr-v)
_FxGraph3D 2.*u/(u*u+v*v+1.);2.*v/(u*u+v*v+1.);(u*u+v*v-1.)/(u*u+v*v+1.);-2;2;-2;2;15;15;1;1;1;UV
Or copy the following to the Commands folder and it will show up as Stereosphere in Max's UI ext scripts feature.
moi.command.execCommand( '_FxGraph3D 2.*u/(u*u+v*v+1.);2.*v/(u*u+v*v+1.);(u*u+v*v-1.)/(u*u+v*v+1.);-2;2;-2;2;15;15;1;1;1;UV' );
Note. If you have done what I apparently have foolishly done and omitted the leading underscore of _FxGraph3D in your set up then you will need to omit it from the preceding lines.
The resultant mesh will Network as it is.
It is quite small, so, to make a solid I first scaled up by a factor of 30, and then used Construct/Offset/Shell with a value of 2mm and Direction Normal.
Just in case you're wondering the formula does NOT produce the lettering shown in the attachment!
Size: 114.2 KB, Downloaded: 73 times, Dimensions: 637x508px
6447.51 In reply to 6447.50
Amazing indeed!
6447.52 In reply to 6447.50
Hi Mike
look this
Stereo Sphere-
link :https://www.mediafire.com/?xni7d1ima5h4aio
in Elephant Stereo Sphere Parametrized
best
al
6447.53 In reply to 6447.52
Thanks, Al.
I've not yet taken the plunge into node editor but you've given me another reason to do so.
Mike.
6447.54
A way to make a solid version a 'Trumpet'.
The method is based on Max's marvellous _FXGraph3D and uses parametric equations from the equally marvellous MathMod.
_FxGraph3D cos(u)*sin(v); sin(u)*sin(v); cos(v)+log(tan(1/2*v));0;6.283;0.03;1.5;50;50;1;1;1;UV
Note. If you have done what I apparently have foolishly done and omitted the leading underscore of _FxGraph3D in your set up then you will need to omit it from the preceding line.
In (bottom right of) the _FxGraph3D dialog change Mode from UV to U then click on done.
Now select all the curves and execute Construct/Loft using Loft Style: Normal and Profiles: Auto
Delete (or hide) the curves. This should give you 'Trumpet' shaped surface with a slice out of it.
Select the surface and execute Construct/Offset/Shell using Thickness: 0.02mm and Direction: Centerline.
This should result in a solid.
Select the 8 edges that form the gap in the Trumpet, then copy (Ctrl-c) and paste (Ctrl-v) them and execute Edit/Join.
Then execute Construct/Loft using Loft Style: Normal and Profiles: Auto.
This should result in a solid filling the gap.
Select both solids and Boolean Union them together.
Here's the result:
6447.55
Michael, I've being trying to use the idea of making a js file of the _FxGraph3D parameters but I'm having limited success.
Some work and some don't.
The following two work OK
Brian's leafsinh.js
moi.command.execCommand( 'FxGraph3D u;v;((exp(u) - exp((-1)*u))/2 + (exp(v) - exp((-1)*v))/2);-3.14159;3.14159;-3.14159;3.14159;15;15;0;0;0;UV' );
My MoebiusStripSolid.js
moi.command.execCommand( 'FxGraph3D cos(v)+u*cos(v/2)*cos(v);sin(v)+u*cos(v/2)*sin(v);u*sin(v/2);-0.4;0.4;0;6.20;15;15;1;1;1;UV' );
but this one (My TrumpetSolid.js) doesn't:
moi.command.execCommand( 'FxGraph3D cos(u)*sin(v);sin(u)*sin(v);cos(v)+log(tan(1/2*v));0;6.283;0.03;1.5;50;50;1;1;1;UV' );
For the life of me I can't see why.
When I try to run if from Max's Ext Scripts feature I get the following error:
6447.56 In reply to 6447.55
Hi Mike,
Can you please post the My TrumpetSolid.js file so I can test it over here and take a look?
> following error:
That error looks like it's trying to execute that string as direct script code rather than seeing it as a command and parameter for that command. That will happen if the command is not recognized. Do you possibly have some spaces in the front before FxGraph3D ?
6447.57 In reply to 6447.56
Thanks, Michael.
Don't think that I have spaces where they shouldn't be, but ...
Attached my two files,
The one that works, MoebiusStripSolid.js, and the one that doesn't TrumpetSolid.js
Note that neither have an underscore preceding FxGraph3D - you may need to add that for your set up.
I did observe the error with Trumpet.js, but after spending an inordinate amount of time, I managed to
fix the problem. I'm using _ before the _Trumpet.js, and also _ before _FxGraph3D.
Edit: It has been very confusing.
3rd party .js scripts without leading _ show up in Max's Ext.Scripts list at the tail end, after all the ones with leading _. (Which is alphabetical.)
The same script with a leading _ show up at the front side of the Ext.Scripts list, without the _.
I use _FxGraph3D. Some other people use FxGraph3D, without the leading _. (So a missing .js error can occur, due to alternate names, with/without leading _.
Also, a carriage return, or cr/lf, in the .js can cause the first "(" to not match up with the last ")", which also causes a parse error.
EDITED: 31 Jul 2017 by BEMFARMER
Show messages:  1-18  19-38  39-58  59-78  79-91
