[script] FxGraph - 2D/3D Function plotter
 1-5  6-25  26-45  46-65  66-85  86-91
Excellent!
The trick is run the Script then just take 2 curves from the result for make a Loft or a Sweep! ;)
EDITED: 7 Sep 2014 by PILOU
Heart (half)
(c of 2 makes a full heart, but with two hairpin curve regions.)
_FxGraph3D a*16*sin(c*v)*sin(c*v)*sin(c*v);a*(13*cos(c*v)-5*cos(2*c*v)-2*cos(3*c*v)-cos(4*c*v));0;0;1;0;3.141592653589793;0;50;1;1;1;UV
With the last beta "Cancel" don't works with these parameters and reasonnable time!
EDITED: 8 Sep 2014 by PILOU
6447.29 In reply to 6447.28
I think it is a tradeoff due to the speed of the htm code?
6447.30
While writing Math nodes for my nodeedit project, I found one significant bug in the FxGraph/3D code. The script incorrectly processes a square brackets and "rnd" command in some cases.
Updated scripts:
http://moi.maxsm.net/media/files/FxGraph3D.v.1.1.2016.04.17.zip
http://moi.maxsm.net/media/files/FxGraph.v.1.2e.2016.04.17.zip
While exploring Scherk2 minimal surface, and hyperbola, these shapes came up:
sinhLeaf:
_FxGraph3D u;v;((exp(u) - exp((-1)*u))/2 + (exp(v) - exp((-1)*v))/2);-3.14159;3.14159;-3.14159;3.14159;15;15;0;0;0;UV
sinhcoshScoop:
_FxGraph3D u;v;((exp(u) - exp((-1)*u))/2 + (exp(v) + exp((-1)*v))/2);-3.14159;3.14159;-3.14159;3.14159;15;15;;;;UV
coshBag:
_FxGraph3D u;v;((exp(u) + exp((-1)*u))/2 + (exp(v) + exp((-1)*v))/2);-3.14159;3.14159;-3.14159;3.14159;15;15;;;;UV
The scripts can be stored in a notepad++ text file.
To repeat how to view in MoI, with Max's _FXGraph3D script already installed, highlight one entire line, press Ctrl+C.
Open MoI, press TAB, press Ctrl+V, press Enter.
Network can be used to make a quick surface.
6447.32 In reply to 6447.31
Beautyful - did not know about that cpoy+paste function !
This script is called BowTie.
_FxGraph3D v*sin(u);v*cos(u);a * asin(((exp(u*sin(v)) - exp(-u*sin(v)))/2) * ((exp(u*cos(v)) + exp(-u*cos(v)))/2));-0.8;0.8;-3.14159;3.14159;15;15;1;;;UV
Selecting just the U iso curves, allows trim with a point at the origin.
Each bow will then network at the 15 curve density.
Each surface can be extruded slightly and the fillet applied.
6447.34 In reply to 6447.33
Nice - except I've not been able to make a surface.
Would you mind splitting this: "Selecting just the U iso curves, allows trim with a point at the origin." into a number of discrete steps?
My particular confusion is what to trim with what, and what to delete (or not).
Mike.
6447.35 In reply to 6447.34
Hi Mike,
Network does not always work on such complete structures, but may work with portions.
(Having a lot more U and V curves may prevent Network from working.)
After creating the UV curves,
1. Place a point at the origin. This is not essential, but helps locating the origin.
2. Select only the curves passing through the origin.
These are the U curves, and could have been identified by previously running a separate U mode. (It is not essential to run a separate U mode.)
3. Run Trim command
4. Press "add trim points"
5. Select origin point as place to put the added trim point.
6. Press Done. (Do not press "remove curves" button.)
7. Press Done again. The two "lobes" are now separate.
8. Select both U and V curves for one entire lobe.
9. Press Network, which creates one lobe surface in half a second or so.
(Network does not work if both lobes UV lines are selected at the same time.)
10. The second lobe can also be Networked separately.
EDITED: 24 Jul 2017 by BEMFARMER
With regard to these last "FXGraph" scripts posted here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6447.31
They work from entering the command in the command area. Is there a modification to it to call from a js file like a regular script? Or is a complete rewrite?
6447.37 In reply to 6447.36
Hi Burr,
That's just one option that it can be run from the command area - the way Brian shows above runs the _FxGraph3D command but also gives it command line parameters. I think the _FxGraph3D command can also be run without any command line parameters too, that's just one way for it to initialize its UI.
6447.38 In reply to 6447.35
Many thanks, Brian.
The bit that tripped me up (I am now embarrassed to admit) was to attempt to Network both halves in one operation.
6447.39 In reply to 6447.37
""""""""""" the way Brian shows above runs the _FxGraph3D command but also gives it command line parameters."""""""""""""""""
Yes. But can that work from a js file? Like is it just missing a "command execute" or something? How to make those parameters pass from the js file? (Without a big rewrite.)
6447.40 In reply to 6447.39
Hi Burr, from what other .js file, do you have something like a launcher dialog you're setting up? You should be able to use moi.command.execCommand(); to do the same thing, it should support command line parameters just make sure there is a space between the command name and the parameters in the string you send to moi.command.execCommand() same as in the pasted in text.
6447.41 In reply to 6447.40
Hi michael,
No, i have no file i was working on. I just put the scripts from the forum in js files as opposed to shortcuts. This particular "command" didnt work from a js file.
Can you give me a quick example of using the moi.command.execCommand()?
I was looking to just put these last fxgraph (with parameters) scripts into named js files so i can call them that way.
6447.42 In reply to 6447.41
Hi Burr, sure - so the first one that Brian had here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6447.31 (the one labeled sinhLeaf) would be like this:
moi.command.execCommand( '_FxGraph3D u;v;((exp(u) - exp((-1)*u))/2 + (exp(v) - exp((-1)*v))/2);-3.14159;3.14159;-3.14159;3.14159;15;15;0;0;0;UV' );
Does that do what you need? If not can you post your .js file and tell me how it's launched so I can better understand what you're trying to do.
6447.43 In reply to 6447.42
Well, i dont know if it can be any simpler!!! Lol :)
Just put that command argument in the brackets of the moi.commamd.execCommand()..
(Edit) and end it with a semi colon. (Edit)
Thank you kind sir.
Any image of what the formula above do ? :)
6447.45 In reply to 6447.44
@Burr - you're welcome!
@Pilou, that particular one makes this:
Show messages:  1-5  6-25  26-45  46-65  66-85  86-91
