Hilbert Curve, Koch Snowflake
 1-5  6-21
KochSnowflake
Seems very heavy in calculates!
cool cube Stephen.
There are so many calculations with the recursion. There is probably a better way with mirrors and rotations?
6441.8 In reply to 6441.7
i would think so, but i'm no programmer like you…
Best regards
EDITED: 19 Jan 2014 by STEFAN
I did some practicing in writing faster scripts, with mixed results.
These are perhaps not very important questions, but for whatever value they may have, I'll ask them. :-)
I'm having a problem, or problems, with a new Hilbert Curve script which uses some script in htm file to speed up performance.
I understand that "heavy" script in the htm file "hangs up" MoI, until it completes.
The script works very fast the first time.
The script uses recursion.
Level 8 takes over 3 minutes to work, and Done cleanup takes over 3 minutes to complete, so the level is limited to 7 which takes 3 seconds initially.
A small question is: Why does level 8 work so slow? Limits on: Javascript stack?, memory leak?, history?
The script also (needed?) to use ObjectList, var objList, as a global variable, due to the recursion.
The main question is: Why does the performance of the script deteriorate, especially at level 7, when the still open script has selection changed back and
forth, for example, between polylines and curves?
For Example:
Activate the script. Level 4 shows up instantly, as a polyline. Select level 7, which takes 3 seconds to show up.
Select curve. The curve takes about 15 seconds to show up.
Select polyline. The polyline takes about 60 seconds to show up.
Another question is how to "erase" or "zero out" global objList? Or maybe that is not the problem.
Thank you,
Ps: Another way to show points is to separate polyline and run MarkCurveStart.
Edit, deleted faulty script. Will re-do later. :-)
EDITED: 28 Jan 2014 by BEMFARMER
6441.10 In reply to 6441.9
Hi Brian, unfortunately it's difficult to answer your question with accuracy without a substantial amount of analysis work done to figure it out.
But it's not that unusual for algorithms with a high complexity level to blow up at a certain stage when the number of calculations becomes very high though.
Do you know what is the overall complexity of the algorithm you're using? http://en.wikipedia.org/wiki/Time_complexity
You could just create a brand new one and assign it to the global variable, that would then give you a cleared out one.
6441.11 In reply to 6441.10
Thank you Michael.
I just realized that switching between Polylines and Curves does not require point recalculation, which will help a lot.
So I will re-do the script again, and move on to other projects. It is unlikely that someone would be switching between levels much.
Edit, January 29, 2014. Deleted script due to poor programming. Calculate was done inside a loop, one point at a time,
instead of outside the loop, with all the points in a group...
Not a total waste, it was good for learning.
EDITED: 29 Jan 2014 by BEMFARMER
6441.13 In reply to 6441.12
Cool! :)
6441.14 In reply to 6441.9
Hi Brian!
Yes. It will give a noticeable performance boost.
Check this version.
P.S. Ops.. I'm late :)
EDITED: 7 Mar 2022 by SMIRNOV
6441.15 In reply to 6441.14
A quick report on Max's superior version, all times approximate:
Level 8 takes < 2 seconds. Switching curve type < 2 seconds.
Level 9 takes ~ 6 seconds. Switching curve type ~ 6 seconds.
Level 10 takes ~28 seconds. Switching curve type ~ 28 seconds. Done < 1 second.
Level 11, after some length of time, MoI seemed to time out(?), "ejected" the script,(?) or some such, and MoI will function again.
Did not observe a degradation of these times, when doing multiple switching between levels, or between curve type.
These levels have a ridiculously high number of bends.
So using calculate and objectList in the point creation recursion, (one point at a time), seems to be a poor programming practice.
Doing the calculate outside the recursion does so on all the points in one big group.
Here is a 3D HilbertCurve script.
It uses Max's fast htm type code.
The recursion is based upon the Thomas Diewald port of processing code. Note that he used array prototype.
http://mrdoob.github.io/three.js/examples/#webgl_lines_colors
The threejs code was removed, and MoI points and polyline/curve factory added.
The basic level 0 pattern of the 3D Hilbert shape consists of 8 points and 7 line segments, around a cube.
This is one of the 3 possible starting patterns. One cube becomes 8 sub_cubes...etc.
The maximum level is set to 4, since level 5 takes several seconds to appear.
Fillet of corners, and sweeps are possible.
Dec2,2017, Changed comma at end of line 62 to a semicolon. Now works with MoI4beta_11_28_17.
EDITED: 2 Dec 2017 by BEMFARMER
6441.17 In reply to 6441.16
Cool!
I recently created an interesting structure from your 2D Hilbert Script:
http://www.screendream.de
It's a loft between 5 different Levels...
Thank you very much for all those inspiring scripts you create!!!
Cheers,
Tom
6441.18 In reply to 6441.17
Thank you Thomas.
Your Loft is amazing. Looks like an exotic wood burl, statue, Rorschach, etc.
Does your Loft involve any other processing?
6441.19 In reply to 6441.18
No, it's pretty much a loft from Levels 1 > 2 > 3 > 4 > 5 > 4 > 3 > 2 > 1 with G3 filleted corners to get the round, organic shape.
It took more than an hour for MoI to build the loft and I can only save it if I set the display meshing to 180°, so that enough memory is remaining to save the mesh as obj for Thea Render.
I think we reached the limits for 32 Bit Software :-)
Cheers,
Tom
Note, the coordinates for the Koch snowflake01 script, are not the corners of an equilateral triangle, so it is not symmetric.
(If the triangle is pointed up, a different pattern occurs.).
Using coordinates of a 3 sided MoI polygon, mirrored to point down, will yield a symmetric snowflake.
For example, (7.5, 2.0096189...) (0, 15) (15,15), where 2.0096189 is 15 minus sqrt(3)*15 / 2.
EDITED: 25 Mar 2014 by BEMFARMER
Updated _HilbertCurve3D to work with MoI4betaNov28_2017, by changing comma to semicolon.
Show messages:  1-5  6-21
