Feature request
644.1
When selecting a point, to be positioned along an axis, it would be nice to have either the CTRL, ALT, or SHIFT keys to align the point to the nearest whole number, or nearest multiple of a whole number dependant on scale (so for example you could hold alt and move something exactly 10 units to the left.
Also when your scaled out and distant from the line, holding alt will snap it to 10 (as the nearest accurate point) so you could accurately move something 1000 units.
we have the ability to do this with the dialogue boxs of course, but being able to hold shift and control it with a tablet or mouse right from the get go so quickly would be something that everyone could appreciate.
Also in the help menu, you should throw in a quick little "Key help" image that pops up when you click it, giving the user the run down of the shortcut keys. Heck there may be keys in there not even somewhat long time users of moi have heard of.
Best of luck, ill probably buy when it comes out.
644.2 In reply to 644.1
One way to do this, is to move the object approx where you want it and then go down where the distance is and type 10<180 if you want it to the left, or 10<0 if you want it to the right.
***There is always a better way to do things... Just find your Moment of Inspiration***
644.3 In reply to 644.1
Hi Qjet, thanks for the feature request!
I'm really trying to wrap up version 1.0 right now, I don't think I will have enough time to get exactly what you mentioned, but here is something you can set up in the current beta that is pretty close.
Close down MoI, and then run notepad and open up the moi.ini file in notepad. You can find the moi.ini file at this location: C:\Documents and Settings\<Your login name>\Application Data\Moi\moi.ini
Add these 2 lines under the [Shortcut Keys] section, like this (these should be just two long lines , one line for G= and one line for the H= )
[Shortcut Keys]
G=script:var da = moi.drawingAids; var grid = moi.grid; if ( da.gridSnap && grid.snapSize == 10.0 ) { grid.snapSize = 1.0; da.gridSnap = false; } else { grid.snapSize = 10.0; da.gridSnap = true; }
H=script:var da = moi.drawingAids; var grid = moi.grid; if ( da.gridSnap && grid.snapSize == 100.0 ) { grid.snapSize = 1.0; da.gridSnap = false; } else { grid.snapSize = 100.0; da.gridSnap = true; }
After you save that edited moi.ini file, the next time you run MoI, you will have 2 new keyboard shortcuts available. Typing "G" (not holding it down, just push and release it) will enable a grid snap of 10.0 units. Typing "H" will enable a grid snap of 100.0 units. You can type "G" or "H" a second time to turn the snapping off.
That's not quite exactly what you requested, but it does allow you to set up a quick 10.0 or 100.0 unit snap by using one keypress which you can turn on or off in the middle of drawing things.
I'm planning on overhauling the Options dialog, and there should be a keyboard shortcut section added to it which will let you see the current key assignments and also edit them more easily instead of needing to edit the moi.ini text file.
