Drawing as background image
All  1-9  10-15
6417.10 In reply to 6417.9
Congratulations on finding the Ferrari of modelers Axel.
Handcrafted with infinite patience!
Marc
6417.11 In reply to 6417.8
Hi Brian, yeah you were asking about something similar a while back and I think at that point I had forgotten about this particular limit in MoI's settings, sorry about that.
> So for now my setting is 8,192. Not sure if there are any associated negative effects on model size?
It won't have any effect on 3DM model file size, but it will have an effect on the consumption of video memory on the video card.
Now that I look at the code again, the main reason why MoI has its own default limit of 2048 was to avoid consuming too much video memory, some video cards do not have whole lot of memory available and large texture maps consume an awful lot of memory.
Like for example an 8192x8192 pixel image will take up 256 Megabytes of video memory just to hold that single texture map alone. If your video card only has like 512MB of video ram it's probably not going to be able to allocate a big enough space for that gigantic sized texture map. Your card I think has 1GB of video memory so it can probably handle it ok for just one of them.
6417.12 In reply to 6417.9
Hi Axel, I'm glad that changing that setting helped you too!
> For unfolding I will use Rhino4, I hope the dimensions will be copied from MoI.
Yeah, there is a high degree of compatibility from MoI to Rhino, you can bring in anything you create in MoI into Rhino without disrupting sizes or things like that. You can also use Copy/Paste to move objects back and forth between MoI and Rhino as well.
> For a future update or version 3, would it be possible to show the actual
> length for curves, not only the radius?
There isn't too much room to put a lot of information into the top level properties panel, but in the future I do want to make an "extended properties" dialog box that you could pull up that would then have a lot more details available on it.
And the "UnwrapCurve" script will yield a line with the length of the curve.
6417.14 In reply to 6417.13
You can find UnwrapCurve here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5136.1
6417.15
I usually use http://kyticka.webzdarma.cz/3d/moi/#CurveLength to get a curve length.
Show messages: All  1-9  10-15
