Strange bug with boolean difference in both V2 & 3 Beta
All  1-3  4-6
6406.4 In reply to 6406.1
Hi FDP yeah the problem seemed to be that one particular bad surface shown above.
In the attached file I have deleted that one surface, and built a new one by extruding one of the remaining surface edges over and then joining the pieces together to make a solid again.
With that face fixed the boolean difference now seems to be ok.
If you happen to have a previous version of this object right before that rounded spot was constructed, if you can possibly send that to me at moi@moi3d.com that's the step that did something wrong that would be good to fix up.
6406.5 In reply to 6406.3
Hi FDP,
> Is it possible that this is just an error in the way that MoI reports whether an object is solid or not?
Yeah sort of in a way - basically MoI will label an object as a solid if it has all edges joined between 2 surfaces (or joined across the same surface as a seam edge on a closed surface).
There are various kinds of ways that objects can be malformed that will still fit that basic criteria like with trim boundaries that have little self-intersecting loops, surfaces that intersect themselves, or pieces of the model sticking through each other, or other kinds of malformed boundaries. This particular one with the boundary actually located completely off the surface is not very common.
Unfortunately it would be extremely time consuming for MoI to try and do an intensive in depth analysis of the object to determine these kinds of malformations.
6406.6 In reply to 6406.3
Hi FDP,
> I had noticed the occasional surface void in this project before this problem, but assumed it was
> a viewport error (those seem to occur in V2 on rare occasion).
It's possible for something like that to be a bug in generating the display mesh, but usually it means there's some problem with the trimming boundary.
If you go to export it to a mesh format like OBJ for example, and the export mesher also made a weird looking result in that same spot, that makes it even less likely to be just a display problem.
Show messages: All  1-3  4-6
