How do I loft this?
All  1-9  10-14
6392.10 In reply to 6392.9
Hi Brian:
i've been on Mike's site where is the link
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.43
Thanks Gareth !
6392.11
Hi Gareth,
thank you for the fast answer.
I am glad that you are an experienced builder of aircraft model.
From your point of view you are rigth.
In my past I was a homebuilder of more antik looking lightaircrafts but I like also modern types.
You can see examples of the types I have made and flown with my friends.
Good luck and a funny time of working with your aircraft.
Hans
Size: 57 KB, Downloaded: 54 times, Dimensions: 500x309px
Size: 82.3 KB, Downloaded: 48 times, Dimensions: 600x370px
6392.12
Getting back tho this after the holidays.
I had one last go at the problem with loose loft. I discovered that if you introduce control points into the curves you can get the loft tool to understand what parts of curve A map to what parts of curve B.
1) Use the trim tool to add trim points to the start and end curves. The curves need to be split into the same number of segments.
2) Use the join tool to merge the segments back into one curve. (My guess in the the join tool merges co-located end points into a single 'corner' point that the curves must go through vs. a regular control point)
3) Loft as normal
In this example I made a very small segment right at the apex of the narrow form on the left of the image, breaking the curve into 3 segments. Then I mapped that to the much larger area on the right hand side. So this tells the loft tool that the small area at the apex on the left should be expanded to cover the vertical area of the form on the right. Add a couple of intermediary coppies of those curves, use loose loft and you get this:
This result is not perfect. I had to chop and blend the area where you see the narrow ping band. I used the technique of sweeping a circle along the curve to produce the cuttaway form. My guess is with some messing around with corner point placement I could avoid this altogether.
This result is about 90% of what I'm after and maybe this idea will be useful to someone else. I have more specific control over the flat area where the intake is so I'm going to try a totally different approach next.
@Michael: could we get some visual indication of which points are regular control points and which are 'corner' points. Like maybe a sub menu for 'Show Points' that would set us see just one type and/or different coloration or iconography when all points are shown?
6392.13 In reply to 6392.12
Hi Gareth,
It might be difficult to have a sub menu for 'Show Points' because it currently doesn't have any options stage in it. Like for example right now you can just select a curve, then run Show points, and the command just immediately shows the points and exits.
So there isn't currently any menu to add another option to right now.
In the future I want to have an "extended properties dialog" which might be a good place to add various kinds of specialized show/hide markers on objects.
6392.14
OK, I tried all of the suggestions in the thread but noting was an exact blueprint for this situation. But now I have a result that I'm happy with:
The Magenta area was produced from a rail loft. Simple surface-to-surface blending produced creases at the corners. I used several curves produced by putting lines along the surfaces and joining them with blend.
The Magenta form originally went all the way to tho top of the large shape on the left. I messed around with various operation like Boolean Diff and so on to try and cut part of it away. This always ended in something odd happening. I was getting strange surfaces with edges that didn't meet up! The shapes are so close that I think its running into the precision of the underlying math. I also tried the technique of sweeping a circle along the intersection line to make a solid to cut with. No dice.
So I just made a curve in the Right view and projected it onto the surface with Iso Curve and used that for cutting. That works perfectly. With that done I get 3 resulting edges on 3 faces that I join to make a loft curve. Using the technique I detailed in my previous post I chopped and joined the profile of the gray colored form on the right into 3 pieces to match. Then I used Loose Loft to make the Cay form with 1 intermediate control curve. You can see the results of the chop/join in the paths that the Yellow lines take. If you just loft the curves you won't get a result like that.
I still have to do this on the actual model where things are /slightly/ more complicated but I think I have a workflow that will scale to that complexity.
Thanks for all the help everyone!
I've been hacking at this for 3 weeks and I'm super happy I got a solution!!! :)
Show messages: All  1-9  10-14
