[script] Morph between two curves
 1-15  16-29
6373.16
Good tip, picking the discards was adding unnecessary work!
Thanks Michael!
6373.17
Very cool Max! Thanks for a great script!
Michael T.
6373.18
Wow this script looks awfully useful!
Many thanks for providing this!
6373.19
Great script! However, sometimes a morph between two closed curves yields several intermediate morphed curves that are open instead. Which makes it difficult to use for further lofting, as it is very hard to find the open spot (I know there's a script for that too). Maybe could be improved? Thanks!
6373.20 In reply to 6373.19
I used lines (opened curves) to build morphed curves. But now the script uses different method in situation when both curves are closed. It uses circles instead. :)
Thank you for advice.
Cool plugin but something curious! :)
Line Web: http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.10
So it's you or Michael who have made an inversion! :)
I presume it's you for any secret reason! :)
(not a big deal as the Flip Command exists in Native in Moi : just select a curve(s) and Press Tab then type Flip! :)
I first use CMorph between the 2 yellow curves then LineWeb! Careful! Order of select curves is important for LineWeb!
EDITED: 20 Dec 2013 by PILOU
6373.22
It works, thanks Max! Only thing left now is the flipped curve direction as Pilou mentions.
6373.23 In reply to 6373.21
Ops. Just forgot to check this :)
Found. Fixed. Uploaded.
6373.24 In reply to 6373.23
This is really cool Max, thanks for posting it and updating it!
Cool! ;)
6373.26
Hello Max
in Moi V4 on my Mac I get this error message when I run the script. In V3.1 it's working fine.
cheers
jopo
Size: 45.3 KB, Downloaded: 61 times, Dimensions: 557x320px
6373.27 In reply to 6373.26
Hi Jopo
you need to download a latest version of the script: http://moi.maxsm.net/files/scripts/cMorph.v.1.1.2014.01.19.zip
6373.28 In reply to 6373.27
Hi Max,
thanks a lot! It's working now.
JoPo
6373.29
I'm usually not very active here but I had to tell you: THANK YOU! This helped me save at least an hour of work!
Show messages:  1-15  16-29
