[script] Morph between two curves
 1-9  10-29
Ok with your script + Lineweb you can make some crazzy thing! :)
Line Web: http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.10
6373.11 In reply to 6373.6
""""""""""Does it give the same result that you'd get by lofting a surface between the curves """""""""""
It's pretty close to the same as just lofting the 2 curves, with some slight differences. I guess you'de have to look at the script code to see how he's morphing.
It does give some interesting possibilities to being able to control the output. Like if you needed to tweak the loft in "Very specific areas", you could then re-run the loft on the morph curves with some changes.
I think it's a compliment to the isocurve, but not a replacement. First, it is automated with nice even space between the 2. The iso curve is more for working on an existing surface and staying with it. This is more for generating a surface. I like to think of it as Generating a surface from isocurve, as opposed to an isocurve from a surface. :o
Maybe the isocurve could be beefed up to do an "even spacing" over the entire surface, with a single pick!
6373.12
Okay I get it :P
It's an automated/lazy person Loft then take sections of the Loft at certain increments :)
6373.13 In reply to 6373.12
""""It's an automated/lazy person Loft """"""
Well, in a sense. It allows you to work backwards in that sense. The other thing it can allow is to create a surface with a very specific point structure.... Like needed for "flow".....
The other thing is if you look at it with regard to 2d drawing/artists, you can do some cool stuff/shapes!
6373.14
Great for 2D/3D hatching!
6373.15 In reply to 6373.14
Hi danperk, also for doing that kind of hatching trimming, you can use curve booleans as a shortcut instead of using Edit > Trim which it looks like you're doing there.
Start with all the hatch lines selected:
Run Construct > Boolean > Intersection, then select the closed curve region boundaries. That will then generate a result like this:
The lines will be cut by the boundary and only the parts of the line that are on the active area of the 2D region will be kept.
If you want the other way, use difference instead, that will slice away the stuff inside the active 2D region like this:
You can use Trim too, the booleans just basically automate the picking of which pieces to discard or keep.
6373.16
Good tip, picking the discards was adding unnecessary work!
Thanks Michael!
6373.17
Very cool Max! Thanks for a great script!
Michael T.
6373.18
Wow this script looks awfully useful!
Many thanks for providing this!
6373.19
Great script! However, sometimes a morph between two closed curves yields several intermediate morphed curves that are open instead. Which makes it difficult to use for further lofting, as it is very hard to find the open spot (I know there's a script for that too). Maybe could be improved? Thanks!
6373.20 In reply to 6373.19
I used lines (opened curves) to build morphed curves. But now the script uses different method in situation when both curves are closed. It uses circles instead. :)
Thank you for advice.
Cool plugin but something curious! :)
So it's you or Michael who have made an inversion! :)
I presume it's you for any secret reason! :)
(not a big deal as the Flip Command exists in Native in Moi : just select a curve(s) and Press Tab then type Flip! :)
I first use CMorph between the 2 yellow curves then LineWeb! Careful! Order of select curves is important for LineWeb!
EDITED: 20 Dec 2013 by PILOU
6373.22
It works, thanks Max! Only thing left now is the flipped curve direction as Pilou mentions.
6373.23 In reply to 6373.21
Ops. Just forgot to check this :)
Found. Fixed. Uploaded.
6373.24 In reply to 6373.23
This is really cool Max, thanks for posting it and updating it!
Cool! ;)
6373.26
Hello Max
in Moi V4 on my Mac I get this error message when I run the script. In V3.1 it's working fine.
cheers
jopo
Size: 45.3 KB, Downloaded: 61 times, Dimensions: 557x320px
6373.27 In reply to 6373.26
Hi Jopo
you need to download a latest version of the script: http://moi.maxsm.net/files/scripts/cMorph.v.1.1.2014.01.19.zip
6373.28 In reply to 6373.27
Hi Max,
thanks a lot! It's working now.
JoPo
6373.29
I'm usually not very active here but I had to tell you: THANK YOU! This helped me save at least an hour of work!
Show messages:  1-9  10-29
