extend with apparent intersections
All  1-4  5-9
6371.5 In reply to 6371.4
Not sufficient!
Lines are horizontal, vertical, oblique, perpendicular etc...?
like these two pinky ones ?
Please post image! I have an headache to imagine all possibilities! :)
You want extend a line on its direction so you obtain again a line, or you want obtain a surface?
EDITED: 15 Dec 2013 by PILOU
6371.6 In reply to 6371.5
This situation. I would like to know if it's possible to use Extend even if the lines are not complanar.
EDITED: 15 Dec 2013 by BEMFARMER
6371.8 In reply to 6371.7
If I understand your question right, you can use: Mutual Extend Mode
EDITED: 15 Dec 2013 by RALF-S
Size: 202.9 KB, Downloaded: 28 times, Dimensions: 844x608px
Size: 211.4 KB, Downloaded: 45 times, Dimensions: 725x768px
6371.9 In reply to 6371.6
Hi max,
For that particular situation you show there, you can use Trim which does have an option for "Project intersections" which will do that job.
Extend does not currently have an option for doing apparent intersections, it would make sense for it to have it as well though, I'll take a look at adding it.
Show messages: All  1-4  5-9
