Removing Extra Edges
All  1-8  9-10
Evren -
Have you tried Martin's MoI Thread Script? It works well.
http://moi3d.com/forum/index.php?webtag=MOI&msg=5451.40
Ed
6345.10
Michael,
> There is some of that function currently in boolean union, when doing a union edges between 2 planes or between 2 pieces that are trimmed portions that share the same full "underlying surface" will be removed.
I wasn't aware of that boolean union's feature. Nice one. Thank you!!
> In the future I do also want to extend the Merge command to be able to merge selected faces together. Like I mentioned before though it involves a fusing together of surfaces, not just removal of an edge and it's a bit tricky to make it work well.
Yes, merge faces would be an awesome addition.
ed,
Yes I'm aware of Martin's script as well. It's a useful script but I think it does not do internal threads and you can't simply boolean difference an external thread because internal threads are a little bit different structure like this:
Show messages: All  1-8  9-10
