How to set curve point that will determine the extrusion line
All  1-15  16-19
6327.16 In reply to 6327.15
Hi Danny,
> I was wondering is it possible to make it invisible in MoI
I suppose that could be possible... It would still be there in the actual geometry though and when it comes into play it might kind of make things even more mysterious at that point.
Like if you take a cylinder and boolean a hole that goes through the seam, the edges for the hole will be split up where they ran into the seam. Even if the seam is just cosmetically hidden, that kind of behavior will still happen.
So it's kind of hard to weigh whether hiding the seam would lead to less confusion overall or not in the long run... Maybe in the future I can experiment with it.
6327.17
Hi Michael et al,
Thanks for the elucidations, much appreciated.
The reason for my question was that I figured that having a seam's orientation aligned to the seams of other parts of a 3D model will cause better topology continuity after boolean operations. For example, when I trim a cap of an extruded or lofted curve, I tend to trim it from the seam to the opposite side, and blend the two halves. But if the seam doesn't matter much, then I'll forget this. I did notice that having seams exactly aligned can cause fillets to fail after a boolean union.
6327.18 In reply to 6327.17
Hi Metin, it is true that sometimes the placement of the seam can be significant, especially if it's placed in such a way that causes some short edge fragment to be created, that can then cause problems later on for filleting because fillets won't work if they have to totally consume away an entire current edge.
The worse kind of thing is if the seams are _almost_ aligned to one another but not quite, making a little tiny edge fragment between them.
So yes there are some situations where due to limits and problems in some operations (particularly filleting) where it can be good to pay attention to the seam location, but you don't necessarily have to worry about it with every single extrude either... With the particular example that you posted originally it's not clear to me why you would need to worry about it there.
6327.19 In reply to 6327.18
Thanks Michael,
My example was an isolated shape I would turn into a nose solid, to be boolean-unioned with a sphere that would become the head.
sevensheaven.nl — 3D (print) modeling • animation • characters • icons • illustration • infographics • logos • visualization
Show messages: All  1-15  16-19
