curve point snap on surface
All  1-4  5-6
6326.5 In reply to 6326.4
Thank you Michael.
Regarding moving curve points in the 3D view :
It quite often happens that a point moves jumps far away
in any direction from its original position (no snapping activated),
very different like I am used in Cinema 4D, where I can move and
place points exactly in the 3D. What can I do to avoid these
big jumps ?
6326.6 In reply to 6326.5
Hi Tom, if no snapping is activated, then the mouse will track along the construction plane, shooting a ray out through the mouse point and intersecting it with the construction plane grid.
If you're looking at the grid at such an angle that a small distance of the mouse moves a very far distance along that grid it will have the kind of effect that you describe.
To avoid that, angle your view so you're looking somewhat more downward at the grid instead of having it positioned where it's going way off into the horizon.
Either that or you may need to set the construction plane to better accomodate the kind of thing you want to draw. Basically your mouse will track along that plane.
Show messages: All  1-4  5-6
