MOI future development
 1-6  7-26  27-39
6304.7 In reply to 6304.1
> While I'm at it, there are a few features from 123D Design I'm missing in MOI: the ability to manipulate edges, surfaces and fillets after they've been established. 123D Design has some tools, such as Tweak and Press/Pull, that enable you to adjust the radius of a fillet and move edges and surfaces after a solid has been created. But maybe those options are present in MOI but I just don't know the right tools yet?
MoI has object history feature but it works at basic level. It's not possible to do those tweaks at the moment but Michael mentioned he has some plans of developing advanced history mechanism for non-destructive modeling. I don't know but maybe in v4...
6304.8 In reply to 6304.7
Cool. The more non-destructivity, the better (like in real life ☺).
6304.9 In reply to 6304.1
Here's the latest release notes:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=6297.1
He probably wouldn't make release notes for the beta sessions as they go. The websites actual release notes would be for a "release". Like version 2 released in 2012.
""""""""but I'm a bit concerned after reading that the site has a "Copyright 2010" at the bottom"""""""""
Triple squid software design obtains it's copyright in 2010. It doesn't get renewed every year, or need to. It's good for like 95 years or something.
I would be more concerned about a copyright "November 26, 2013"................................
I think the development stops, when Michael stops.......... Breathing!
6304.10 In reply to 6304.9
☺ Hahaha. Well, let's hope Michael doesn't stop breathing for at least the next 256 years. ☺
6304.11 In reply to 6304.10
"""""for at least the next 256 years"""""""""""
Yes! :)
Or I fear MoI will become very good at modeling and surfacing "Carrot's", for some reason.................. :o
6304.12 In reply to 6304.1
Hi Metin, I never really expected to get a negative impression just by not updating the copyright notice on the web site! ;)
Don't worry though - that isn't a sign that MoI as a whole project is neglected, yes the web site is neglected but that's purely because I put so much work into the software itself and also into answering things here in the forum. You should be able to easily see daily activity in the forum stretching back for years...
Once the V3 final release is out I will probably focus some attention on the web site for a little bit, and I'll try to remember to update the copyright notice at that time as well.
Also as others mentioned, actually the last beta release note posted here on the forum is from the Nov-19-2013 version, just a week old, you can't get any more current than that! :) You were probably looking at the wiki which I have been lax in keeping up to date, sorry about that.
> I don't want to invest in a slowly dying side-project of Rhinoceros development, but please correct me if I'm wrong.
Well, I work on it all day every day, I answer questions here every day in the forum, and I just released a new v3 beta version one week ago... I'm not sure how it's possible to be more active than that...
No these particular features are not available in MoI currently. They are things that I'd like to add in the future but I'm not sure exactly when that will happen. For now if those features are important to your workflow you would need to use 123D Design along with MoI to get that stuff.
6304.13 In reply to 6304.12
Thank you very much for your reply, Michael. By now I'm completely convinced of MoI's ongoing lifespan, and will definitely consider upgrading to the full version, after I've given myself some more trial time to get accustomed to the NURBS approach to modeling, as it's quite a transition for a hardcore poly subdivision modeler like me, who's used to total control over every element.
Keep up the great work.
All the best,
Metin
6304.14 In reply to 6304.12
""From Michael: Well, I work on it all day every day, I answer questions here every day in the forum, and I just released a new v3 beta version one week ago... I'm not sure how it's possible to be more active than that...""
You need to train your body to continue working even in your sleep?
Dream that you are fixing Bugs (that one you could already do it)
Hey Michael, if you need help with the web site, we can help you, if you want the help.
Denis
| CorelDraw Grahics Suite X6 | Moi 3D V2 | Carrara 8.5 Pro | Cinema 4D R15 |
6304.15 In reply to 6304.13
Hi Metin,
> every element.
Yeah the overall strategy for NURBS modeling is very different from poly modeling. One of the biggest things with NURBS modeling is that you want a lot of the 3D edge curves in your model to be produced as a result of booleans rather than by individually positioning things in 3D directly like you do with sub-d modeling.
Basically you want to be doing most of your work with 2D curves, some 2D curves being used to generate stuff and some being used to cut things.
Once you get used to it though, you can form mechanical models with this method very quickly. That's what can make MoI a nice companion modeler for a sub-d artist when you're working on non-organic shapes.
I know it can be frustrating to learn a different workflow. But really it's the different workflow that makes MoI especially useful, because it means it has a different set of strengths and weaknesses compared to sub-d modeling. If it just worked the same as sub-d modeling then there wouldn't as much of a unique value in using it.
Also check out here for some links to discussions and general tips for people who are coming from a sub-d / poly modeling background:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4865.2
6304.16 In reply to 6304.14
Hi Denis,
I appreciate the offer, but from a long term maintenance perspective I think I'd rather wait and do it myself so that I'll be more comfortable with any other future overhauls as well.
I've just been waiting to put any focus on it until after V3 is out. V3 has been a long time in coming partly because there was a big break between V2 and V3 for doing the Mac version development.
And actually to tell you the truth I sort of like to have a pretty minimalistic site anyways. I do want to spruce it up some though.
6304.17 In reply to 6304.16
I, for one, love the way your discussion forum works. Like MoI, it's both simple and effective. It's one of the better ones out there.
My only nit: We "Log ON" and "Log OUT"
I always thought it was:
Log in <> Log out
Log on <> Log off
Wax on <> Wax off --er, not sure about that last one.
6304.18 In reply to 6304.17
Hi Mark, yeah Log "in" makes more sense to me too. I didn't specifically choose "Log on" myself, that's just what the forum software itself had set on it. That might be another thing I can tune up when I'm in web site tuneup mode after v3 is out.
6304.19 In reply to 6304.15
Many thanks for your elucidation and the link. I'm definitely triggered by the workflow of NURBS. Some objects that can be created in a matter of minutes using NURBS can be quite a pain in the butt when using subdivision modeling, especially things like perfectly round shapes with clean cutouts.
The tesselation of MoI polygon exports is very good as well. Imported STLs in Blender look great.
Also, kudos for the sympathetic atmosphere around here. It reflects an admirable love for MoI, from the creator and the users. Something you won't find in large-scale publishing.
6304.20 In reply to 6304.19
Thanks Metin! :)
I am on some numerous forum and I can say that I much appreciate this "Zen" minimalistic aspect!
No pollution of the eyes by some no useful visual gadgets! :)
Small is beautiful !
6304.22 In reply to 6304.13
Just like me. I used to work with 3ds Max, Lightwave, Modo, Maya more than a decade and yes, NURBS approach is quite different. With NURBS modeling there's no pushing/pulling. There's a lot of planning involved and using profile curves everywhere. NURBS is very powerful if you know exactly what you're doing. Spend some time with MoI tools, follow some tutorials and I'm sure you'll get used to it quick.
I wonder what type of models are you planning to create with MoI? NURBS is perfect for industrial/architectural kinds of things but it's not very suitable for organic kinds of models where lots of little tweaks, pushing, pulling involved. If you're doing a lot of changes while modeling, like Michael said you can use 123D/Rhino and your polygon modeler along with MoI. Best of both worlds.
Also check out scripts for MoI. There are tons useful scripts. Some of them are essential.
http://kyticka.webzdarma.cz/3d/moi/
By the way, where are you from Metin?
6304.23 In reply to 6304.22
I'd say Metin is from the Netherlands going by his URL :)
6304.24 In reply to 6304.22
Thank you for your advice, Milkywaif, much appreciated. I will check out a lot of tutorials and practice with MoI the next weeks.
I'm a freelance designer and illustrator from the Netherlands, and have worked with 3ds Max from 1998 to 2012. By then the high pricing and only-once-a-year, relatively minor updates of Max really started to bother me, and I discovered that Blender had surpassed Max in terms of completeness.
By now I know Blender very well, and use poly modeling for just about anything, but I've always been interested in exploring NURBS modeling. My expertise is shifting from illustration to modeling for 3D printing, and I'm falling in love with the accuracy, filleting, easy shelling and more of NURBS. 3ds Max and Blender have NURBS, but the possibilities do not come close to the usefulness of MoI's NURBS tools.
Also, from time to time, customers request a solids file format, such as IGES or STEP, and I always have to excuse myself for only being able to export polygon-based formats, while MoI can export to both NURBS and poly formats.
EDITED: 27 Nov 2013 by SEVENSHEAVEN
6304.25 In reply to 6304.24
I'm glad if I could be of any help.
I asked because you have a Turkish name and surname, unless it was some kind of a resemblance :) Maybe it was your parents who have Turkish origin.
6304.26 In reply to 6304.25
Hi Milkywaif,
You're right, my father came from Turkey, but I had a Dutch mother and was raised in the Netherlands. :)
http://sevensheaven.nl — 3D (print) modeling • animation • characters • icons • illustration • infographics • logos • visualization
Show messages:  1-6  7-26  27-39
