Shell Issue
All  1-3  4-6
6280.4
I suspected that tight area might be the problem. Its probably trying to self intersect in that area.
I also tried to shell it in viacad and it came out with the cryptic message "could not offset surface as requested:Thick Solid_331", so your guess is spot on.
Thanks for the suggestion about offsetting surfaces and breaking it down into more smaller chunks. Its a little more work but should give me the desired results. Will do it that way.
~Kevin~
6280.5
I did what Michael mentioned in his second reply and Separated the surfaces, I then Shelled them (Direction = Flip) and finally Boolean Unioned them.
There are a couple of problems at the front that might be editable, but overall it's not too bad from what I can see.
Martin.
6280.6 In reply to 6280.5
Thanks blowlamp for the tip. That will make it quicker and easier. I never considered that option so glad you suggested it.
In this case I don't need perfect surfaces on the interior so a couple of bad joins here and there won't matter.
~Kevin~
Show messages: All  1-3  4-6
