Relative start
All  1-5  6-9
628.6 In reply to 628.5
> All that works also with a pen graphic?
It does! Just instead of typing in a number to activate distance constraint, go to the "d" (for distance) box in the bottom toolbar and click on it and enter a number with the little pop-up panel. That will work without ever needing to touch the keyboard.
But actually, I guess you do need to use the keyboard for one thing I mentioned above, the "rx,y" relative coordinate method. There isn't currently any non-keyboard replacement for typing in the initial "r" to indicate relative coordinates.
628.7 In reply to 628.6
Maybe a little more keys on the pop up calculator? :)
R = relative, M O I free :)
EDITED: 23 May 2007 by PILOU
628.8 In reply to 628.7
Pretty soon you'll want the whole alphabet in there! :)
So far this hasn't been an issue because relative coordinates just aren't used too frequently. And if you are using them frequently you would generally want to use a keyboard for entering a larger quantity of numbers in anyway...
628.9 In reply to 628.8
I have just forgotten the "," (comma) for use it with the relative entry :)
So just 2 keys :)
Show messages: All  1-5  6-9
