Local Coordinates ?
 1-5  6-25  26-30
6273.6
All the CAD programs I have used have gimbles for transform, scale and rotate.
Some examples that I have used is Autocad, Inventor and ViaCAD so it is not a tool that is something only polygon modellers use.
It is usually an option that the user can turn on or off as required, depending on what they are doing.
There are plenty of things you need to model and transform that does not require precision, only a good eye and transform gimble. To some extent you have this with edit frames but they are not useful for moving objects and they aren't any good for scaling once you have rotated the object a little bit as they only work on the bounds of the object.
Anyway it is something to consider for future versions of MoI.
~Kevin~
6273.7 In reply to 6273.6
Hi Kevin, it is something that I'd like to add in the future, certainly it could be useful in various situations where you just want to eyeball things. Basically that kind of operation just hasn't been as high of a priority as other stuff yet.
I decided to put more emphasis instead on the edit frame, since that lines up well with 2D editing and drawing and editing 2D curves has been more of the focus area in MoI so far.
One thing that's nice about the edit frame instead of a central manipulator is that you can do some kinds of basic accurate scaling with the edit frame that aren't normally possible with a center type manipulator, like for example here I scale a shape using the edit frame and there is a snap available to make the object scaled by the exact amount to fit between 2 other objects:
Because the edit frame works by operating on the object boundary it enables accurate scaling of areas of the object that are on that boundary line.
Then on top of that the other really big plus about the edit frame is that it's much lower profile than a manipulator widget, instead of taking up a bunch of screen real estate right in the center of things, it instead goes totally around the outside of the current selection and is also sparser as well. That helps make it feasible to keep on all the time rather than having to constantly turn it on and off.
Anyway, those are some of the reasons why I decided to do the edit frame initially instead of one of those other central manipulator types. The other kinds of manipulators do have benefits in other kinds of situations so I think it would make sense to eventually have them as well, I just viewed it as a somewhat lower priority item.
I also have some general concept about maybe having a 3D edit frame that also goes around the outside of the object at corners rather than a center one, but I haven't had time yet to experiment with that. A 3D corner frame may possibly give some of the type of exact scaling functions like I show above with the 2D frame and maybe would have a little bit of the "stay out of the way" properties as well (but maybe not too...).
It could be possible that eventually there might be a 3D frame and also a center type manipulator as well, but I'd probably like to try and see if that can be avoided first.
In the meantime the transform tools under the Transform palette can do a lot of things already like rotate a box around one of its faces as shown previously. Since there is a set of flexible tools for doing those kinds of things that has also made it not a big priority to do a 3D manipulator yet as well.
6273.8
Michael,
Don't get me wrong, I'm a big fan of the edit frame but it does have its limitations.
I am often using them to scale cross sections for wings and fuselage for lofting purposes except I am scaling them in the end on direction (trying to scale the red cross sections in the image below to match the wing thickness).
Once I rotate one of those cross sections (eg to match the angle of the wing), I can no longer use the edit frame because it squashes the profile out of shape because the edit frame doesn't work on local coordinates (see attached image).
Your feature request is a million miles long, so I only put it out there that edit frames working on local coordinates of the object would be very useful.
Also having a gimble option that you can turn on and off that works with points and objects would and also works for local coordinates would be very useful, especially for those people doing more organic, freeform type modelling that doesn't require absolute precision.
Size: 33.2 KB, Downloaded: 70 times, Dimensions: 600x460px
6273.9 In reply to 6273.8
Why not use Transform / Orient / Line-Line ?
That works on any orientation!
6273.10
Frenchy,
I start off with thickest wing cross section and copy it multiple times along the length of the wing. I then have to scale each of those cross sections down in size to match the front profile of the wing.
I use scale 1D for this, but if local coordinates worked with edit frame it would be even easier.
This is just an example to make a point about how local coordinates and widgets would be useful to have to speed up the workflow. I can easily find other workarounds within Moi which is what I am currently doing, they are just a little slower.
~Kevin~
6273.11 In reply to 6273.10
And use the View/CPlane temporary don't help ?
6273.12 In reply to 6273.8
Hi Kevin,
I'm not sure if I'm understanding your specific example there - are you in the Top view there and working on profiles which are vertical planar curves?
How does the edit frame end up squashing your profile in that particular case? If you're in the Top view if you either rotate or scale the shape it should still remain a planar vertically oriented curve, no matter what bounding frame it presents...
6273.13 In reply to 6273.12
Michael
I am in front view.
Hopefully this image is clearer than my roughly drawn one.
The edit frame when squashing the cross sections in front view aligns with World Coordinate System rather a local Coordinate system.
@Frenchy
Yes aligning the cplane is another way in MoI.
I think both of you are missing the point. There are otherways you can achieve the same thing in MoI and most software for that matter but having a widget or edit frame that you scale, rotate or move in the Local Coordinate system of the object is quicker and easier than all the otherways which is the reason most 3D software have such an option.
~Kevin~
Size: 34.1 KB, Downloaded: 71 times, Dimensions: 750x532px
6273.14
Is it something similar to this Kevin? http://screencast.com/t/Pz7vK9P0Emk
Clicking the right mouse button on the rotation handle (edit frame turns green) causes that particular software to enter the kind of mode I think you're describing.
Martin.
6273.15 In reply to 6273.13
I must miss something :)
When you rotate something with the Edit Frame it's from the center of rotation of the object so local one for the selected object?
Or any point of the 3D space if you move the little "star"
Can you put an image before / after of what that don't work ? or a little file 3Dm of the result wished
Here in the 3D view (does the circular dashed points + star = a gimble ? )
EDITED: 13 Nov 2013 by PILOU
6273.16 In reply to 6273.13
Hi Kevin,
> I am in front view.
If you use the edit frame to do a uniform scale up or down it's not really particularly relevant which specific orientation the edit frame has right then, it will do a uniform scale from the bounding box center and that should not do anything that I'd term "squashing" to the curve.
It would only get skewed (in rotation, which you can then adjust by grabbing the rotation handle) if you track along one of the x or y directions of the edit frame which does a one-directional scale instead of a uniform scale. But you can solve this by just moving your mouse some distance away from those one-directional scale tracking lines and that will then "shake off" the one directional scaling and do uniform scaling instead.
Here's an example - notice how after I "shake off" the one directional tracking that it then does a uniform scale which should not squash your curve at all:
6273.17 In reply to 6273.16
"Shake off"......... Learn something new every day!
Grandmaster flash and Mellie Mel would be proud.
6273.18 In reply to 6273.17
Hi Burr, yeah so the way the "shake off" works is if you move your mouse far enough away from either of the X or Y tracking lines, when you move your mouse back to that original area it won't attempt to track onto those X or Y lines anymore.
That can help you to do some finer tuned uniform scaling with the edit frame, basically turning off the one-directional scaling for just that handle grab.
6273.19 In reply to 6273.18
I had seen you mention before about getting "away" from it, but always struggled and resorted to lots of "zooming and panning" to keep in the "diagonal drag"......
It was enlightening to realize it could create that second mode. The temporary turn off. the unform scale only. The bees knees.
6273.20
Michael,
Thanks for the tip about shake to scale. I just tried it out and it seems to scale the whole object up and down in size rather than in one direction only (along the normal) like SCALE 1D.
When working in 3D just about everything is placed at weird angles so having the ability to align the edit frame with the objects normal would make it more useful if you just need to scale it in one axis.
If we use a cube as an example. I have rotated it in 3D so it is no longer aligned to the XY plane.
In polygon modellers you can then align the scale widget to the normal of the object and can then grab any of the handles to scale the object in 1D along that axis.
The second image shows how MoI works, when you try to scale along any of the axis you distort your cube.
Hopefully this example explains it better ?
Size: 54.3 KB, Downloaded: 45 times, Dimensions: 691x501px
Size: 49.6 KB, Downloaded: 38 times, Dimensions: 656x423px
6273.21 In reply to 6273.20
For a cube Scale 3D + Button "Center Bounding Box" don't make the trick ?
6273.22
Frenchy
I don't want to scale a cube it just used to illustrate the point that Stav and myself are trying to make.
The cube could be any object from a curve to a weird looking organic solid shape.
~Kevin~
6273.23 In reply to 6273.20
Hi Kevin,
Yup, that's correct - sorry it wasn't clear to me that you were wanting to do a one directional scale, I was thinking you were talking about a uniform scale which does work with the edit frame in that kind of arrangement (viewing straight down on planar objects).
I wonder if I should do something special for planar objects being viewed along their length like that, like always align the edit frame with the object... I worry a bit though about the kinds of edits that would then be actually disabled like mirroring or flattening things to the world axis directions. Maybe I could do something like use right-click on an frame handle to switch bounding box modes from world to object relative.
Yeah I already understand the kinds of situations where it would be useful - I was just showing that in the example that you showed you can actually use the existing edit frame to scale those kinds of planar sections as long as you're talking about a uniform scale.
And again just to be clear for others reading this, it is already possible to scale a non-axis-aligned box the way you want there, you can use the Transform > Scale > Scale1D tool to do that, that allows you to specifically pick the direction of the scaling so you just snap the direction line onto the edges of the box and you'll be able to do that kind of one directional box stretch.
6273.24 In reply to 6273.23
Michael
Thanks, glad it is clear now. In polygon modellers one of the most useful tools is be able to place and rotate your widget where you want.
I currently use two techniques in MoI for getting around the edit frame limitations.
1. Scale 1D
2. Align cplane with object and then use edit frame.
But certainly being able to quickly align the edit frame with the object or even rotate the edit frame where your want would be quicker than the above two options.
Like I said earlier, you have a million feature requests to work on and this is one more for the list. There are currently ways of working around it so its not the biggest issue but just a nice to have request.
The reason I bought this up is because I use Andrei's loft->loose->exact method for the majority of my work and the curves are often not perpendicular to the XYZ axis which makes squishing them to shape with the edit frame problematical because the edit frame can't align with the object, so I use the 2 methods above in those instances. Its a little slower this way but the job still gets done.
~Kevin~
6273.25 In reply to 6273.24
Can you post just a very little example of 3D objects with the sections (or other) that you want to move copy or orient or modify or create?
A very tiny example will be sufficient :)
Show messages:  1-5  6-25  26-30
