STL save as assembly
 1  2-21  22-28
6270.22 In reply to 6270.21
It would just be ambient noise while I focus on what your doing.
Ray Dream was my first 3d modeler.
6270.23
A quick print out of the CreatureBox JellyBean character, I used to paint warhammer figures years ago so I will break out my paints and get him colored up. The figure is about 4"" tall, I had to change the diameters on the arms cylinders and fingers to get them to be rigid enough to clean up...still has the same feel though
6270.24 In reply to 6270.23
That is sure a nice printer you've got there.
6270.25
It shows off your software nicely
6270.26
Hi ,
I am using this handy plugin as well .
I am getting segmented curves in STL at diameters greater than 100mm. I did look in the script and only see angle @ 5
I typically use angle 6 , divide 1 - all and minimum .25 when exporting to get smooth curves
How do I add divide 1 - all and minimum .25 to the script?
6270.27 In reply to 6270.26
Hi DVR,
It would need to set up an options string that looks like this:
NoUI=true;Angle=5;MaxLength=1;MaxLengthApplyTo=all;MinLength=0.25
I've attached a modified version of the script that will do that.
6270.28 In reply to 6270.27
Thank You Michael!
This works brilliant . Do not have to remember the settings anymore
Show messages:  1  2-21  22-28
