AquaRiva
 1-13  14-33  34-43
Message 6236.14 deleted 26 Oct 2013 by ANDREI SAMARDAC
6236.15
Just made tutorial on key features of this modeling process:
Seeing this very cool video, does it possible inside Moi to have somewhere commands used "printed" on the screen
(left top corner in this one)
like
Move
Merge
Blend
etc...
6236.17 In reply to 6236.16
That's an excellent idea Pilou. It can be difficult to follow by looking at the icons.
A special "Tutorial" script to display the name of the active tool in a short, stacked format, so you can pause the video and see a recent history of the commands used.
Ed
6236.18
Hi Andrei,
Excellent job. Thanks for the tutorial.
Carlos
6236.19
Thanx) And rendered one)
Image Hosted by ImageShack.us
6236.20
Looks beautiful with some color on it.
Great work all around.
~Kevin~
6236.21
Andrei... You are my inspiration!
It's very beautiful!
6236.22 In reply to 6236.20
I agree. Excellent model and render.
Next - maybe render in water?
Ed
6236.23 In reply to 6236.19
Excellent renders, well worth adding to your portfolio - Well done Andrei
Martin Spencer-Ford
Very cool result!
Maybe a little more reflecting on the wood's parts ?
EDITED: 5 Nov 2013 by PILOU
6236.25 In reply to 6236.24
Here is a teak table with a soft polished luster. Not far off at all. ;-)
6236.26
Thank you)
Portfolio: www.samardac.tumblr.com
6236.27 In reply to 6236.26
No words to describe the pleasure.
(I'm from Italy, so there'a little bit of pride...=)
Also, as a car modeling fanatic, I invite you to use your skills to show us another wonderful work...
6236.28 In reply to 6236.27
Boja, thank you))
6236.29
Andrei,
I echo all the other compliments on this work. As Mike said, you are an inspiration! May I ask what rendering program you use?
Best,
Ron
6236.30 In reply to 6236.29
I believe that is VRay for C4D ;)
6236.31
Gorgeous!
6236.32 In reply to 6236.29
Ronamodeler (RON_A), No It is just Standart render engine :) It rendered about 1 minute :)
6236.33 In reply to 6236.32
Andrei Awesome!!!
Thanks for the video too bro...
One question....I just dont understand how you got the ends closed on your hull loft, especially the front . I used the same settings as you (loose and exact) but the nose remained open.
Did you loft to a point?
Show messages:  1-13  14-33  34-43
