Working with text option
All  1-10  11-14
622.11 In reply to 622.10
Micheal, your explanations are absolutely superb. Thank you for taking the time and trouble to explain this to me and I hope it benefits other people as well.
I was wrong when I said earlier that my example was not the best. It was absolutely lousy.
The best way I can describe the effect I wanted is to dip your finger in water and draw the letter P on a shiny surface, ( I know, I would have to think of this now, wouldn't I?).
I meant what I said about your explanations, they are superb. I can see this forum turning into some kind of a MoI "WOW"
book if this keeps up.
Thanks again
Peter
P.S. At this stage Artcam is just slightly outside my budget, but I'm working on that.
622.12 In reply to 622.11
On a fixed image : you can make the boolean intersection between your "P" and a "waving surface"
For the "shiny surface" moi can't yet make that :)
Or you want writing on a mirror? :)
But Just "P" is a little short ;)
622.13 In reply to 622.11
Hmmm, so I guess you mean a type of liquidy or bubble type shape?
It might be easier to understand if you had a closer example picture or sketch! :)
If you want something really rounded and liquid like, it won't be easy to manipulate that "P" character from that font into that. That's because that P has a bunch of sharp corners in it.
Smooth/bubbly/liquidy, and sharp crisp corners are not easy to combine together. They're almost like matter and anti-matter... :)
So If you want to create something very smooth and bubbly, you're better off drawing some curves to make a custom "P" form rather than using the crisp sharp letters from a regular text font and trying to produce smooth bubbles from that.
Here is another example - here I drew a couple of curves to form a path of a "P", and used Construct / Sweep to create a kind of tube that sort of drags a profile along that path. Is that closer to what you had in mind?
Another thing you may be interested in is this technique that uses sweeping with 2 rails to make "blob" type forms: http://moi3d.com/forum/index.php?webtag=MOI&msg=415.2
622.14 In reply to 622.13
Got it! That's the type of thing I was after. However I was sort of hoping I'd be able to take a flat letter from a regular font and round it out. But never mind, I'm getting close to what I want to see. Now its just a matter of playing with it. Thanks for all your help Michael. You can be sure I'll be a regular visitor here now.
Jesse, thanks for the link, I'll be looking at that soon.
Just a short note to Pilou:- my "P" is never too short because I stand close and lift the seat as a gentleman should ;o)
Peter
Show messages: All  1-10  11-14
