Oloid script
All  1-7  8-14
6211.8 In reply to 6211.7
I copy pasted an oloid to Geomagic Design, stitched it, and exported to .bip, for keyshot3 (/4).
I would try to do a "gomboc," but there apparently isn't any parametric equation.
One link said it was "Constructive Solid Geometry."
Did locate an .stl reduced version.
There is a US design patent granted April 20, 2010, which lasts for 14 years.
EDITED: 8 Oct 2013 by BEMFARMER
6211.9 In reply to 6211.8
EDITED: 9 Oct 2013 by PILOU
6211.10 In reply to 6211.8
here's an interesting 4 side screenshot from Rhino, of a gomboc. (please scroll down to the end of the page)
Maybe it's useful for reconstructing the shape in MoI...
http://totallyepic.net/mossy.html
Thankyou Pilou and Stephan.
There is supposed to be an infinite number of such shapes, but they are all also
supposed to be within a few percent of spherical.
The torse of the oloid is the unwrapped oloid.
Here is a re-creation of the paper model shown in several papers of Hellmuth Stachel, which I did, based upon the script for the torse
of the oloid, with the glue tabs added on.
http://www.iste-c.net/keynote_speech/inte2016/Hellmuth_Stachel.pdf
The top mirrored curve of the torse script was not quite tangent.
The mirror of the bottom initial quarter torse curve seemed to be smooth and tangent. The two curve formulas are different.
The tabs took quite a lot of time to do in MoI. Max's pattern selection script may have helped, and was used for the 4 "dashed" lines.
Dashed lines usually imply a valley fold, but not in this case. The MoI units was set to inches, and the .3dm converted and scaled to inches,
to fit standard size, thick paper.
The pdf was easy, at 1 to 1, and the 2d printout fit within an 8.5" x 11" size paper.
The scissor outline was printed on an 8.5" x 11" cut out sheet of a manila file folder, which the Brother laserjet printer
was able to print on. Glue has not yet been applied.
The V shape of the glue tabs begins at a point on the curve, but apparently due to pixel display artifact,
the visible tips of the V shape appear to extend past the curve.
that they actually meet at a point on. The pdf also shows this artifact.
(need to buy a 3d printer...)
6211.13 In reply to 6211.12
>> need to buy a 3d printer... <<
Till the try Shapeways. Have received my 3D print from them
last week. Nice quality, affordable price.
6211.14 In reply to 6211.1
Something similar from Tony Wills is a D-Form shape from 2 flat sheets of paper of exactly the same edge lengths
Look at www.cutoutfoldup.com/1602-d-forms.php
Show messages: All  1-7  8-14
