Hidden line removal progress
 1-15  …  56-75  76-95  96-115  116-135  136-155  …  296
6201.96 In reply to 6201.92
Hi Marc,
> Ive notice there is also an alpha black and white image in the pdf file.
Yup, the shaded part of it comes from that image with transparency for the background. The outlines go underneath that so that the shaded image also masks out the inside half of the outline too. One problem that I see now with this though is that the outline will be masked where different objects overlap each other, the outline will only show against the full background not against other objects.
> The layers shows up in Pdf reader and in Xara but not in Illustrator Cs6.
> Not that I mind, I use mostly Xara, but it's a strange phenomena being adobe and all!
Yeah unfortunately Illustrator does not read layers from PDF files. I guess what happened is that the PDF team made layers in PDF to be very flexible and can have all sorts of optional conditions for controlling visibility. They're actually called "Optional Content Groups" in PDF. But then with all that flexibility Optional Content Groups did not necessarily map 100% to the concept of a "layer" in Illustrator. So they seemed to have kind of just gave up on it. It would have been nice if they would recognized Optional Content Groups that were being used in a simple way to map to layers in Illustrator but they didn't.
According to Adobe here, officially it's Acrobat that is the main PDF editing tool and not Illustrator:
http://forums.adobe.com/thread/509192
But you'll be able to get layers to come into Illustrator if you use .ai format instead of .pdf . Can you test loading in this .ai file into both Xara and Illustrator to see if the layers here come in ok to both?
For AI format the shaded image part is in a separate PNG file that is used as a linked image in the .ai file, if you put the PNG file alongside the .ai file when you open it then it ought to be found when the .ai file is opened.
Do the images come in ok to Xara in both PDF and AI formats here?
Thanks, - Michael
6201.97 In reply to 6201.90
Hi Mike,
> I noticed that there was one "group" in Illustrator, which included the bitmap and a clip for the
> exterior of it.
> I can also see where your thicker lines reside lower in order than the bitmap, and the thinner are
> above, but they all reside on the same Illustrator layer.
Yeah this is because Illustrator does not read in layers from PDF files.
But it will read in layers from AI files, so if you want to get layers to go into Illustrator you'll want to use .ai format for the transfer and not PDF.
Can you test the above AI file (download both the .ai and the background image which is a linked image inside the .ai file) and see if the layers come through ok for you using that format instead?
> Could you consider putting the different separate 'layers' of line types within
> actual groups, if it will let you do that?
> Then we could just click on the group of lines and colorize it or whatever if need be.
I may be able to do something with making groups too, but probably having the layers come through using AI format will do what you need as far as making them targetable.
6201.98 In reply to 6201.94
Hi Martin,
> Marc, did you open the PDF directly in AI? I had success by importing
> the PDF. See my previous post.
That's interesting - does using "Open" versus "Import" in Illustrator for PDF files do different things with organizing the PDF content?
Using .ai format should probably work better though, can you test the above AI file and see if it comes in with the expected layer structure ok?
Then only quirk about AI format is that the image is generated separately from the .ai file itself and it's placed as a linked image in the AI file. That was the only way I could find to make an image with alpha come through into Illustrator using the AI v8 format.
So when you save to AI format there will be this "companion file" PNG background image that goes along with it.
6201.99 In reply to 6201.98
Yes it seems so when I open the PDF directly everything is on one layer but when I import the PDF it comes in organized.
It is unfortunately the same mess as opening the PDF directly (Illustrator CS3) but I can select one piece of thin line then go to Select > Same > Stroke Weight and move everything to a new layer or change the stroke width for all selected lines.
A seperate PNG file is not bad because I could treat it seperately in another program e.g. convert it to line art.
6201.100 In reply to 6201.97
Yes, this works great Michael!
I would suggest not only making each type (thick, thin, bitmap) included within a simple group of its own, but then each group placed on separate PDF layers.
This way, the PDF or AI could also be imported into Corel. Or the PDF could be opened into Illustrator right off.
Aside from that, this is very promising! I already have a lot of uses in mind just for regular work, besides the new and wonderful possibility for 3D type.
Also, if you zoom in closer the butted outline caps, which are square are more evident.
To improve the look I'll often make the nib shape of the outline stroke round, but I will also leave a duplicate with the outlines with their original square ends.
This way, the ends and joined areas look smoother, but the corners retain their sharp squares (if they are joined).
The bitmap output, by the way, is simply beautiful... something near 600 dpi on this one.
One question, is the bitmap render quality linked to the Mesh Angle value for the vid card render?
6201.101
I was able to open the .ai file with the linked PNG without a problem on Illustrator CC. Layers are fully intact: Default, Background, Outlines. Once again a really awesome addition to MoI's feature-set! Thanks Michael!
6201.102 In reply to 6201.99
Hi Martin,
> It is unfortunately the same mess as opening the PDF directly (Illustrator CS3) <...>
Hmmm, over here with Illustrator CS2 it seems to be working as expected... Can you please double check that you're opening the .ai file and not the PDF since they have the same name?
Yeah probably some people will like to use this just to harvest the PNG file and use it instead of the .ai file.
6201.103 In reply to 6201.100
Hi Mike,
Great!
Nope, for each surface it generates a new render mesh on the fly, and that mesh gets refined until the screen space projection of it deviates no more than 1/4 of a pixel on the render screen.
So it should always look really smooth regardless of what your display Mesh Angle is set to.
It's easier to do this kind of view dependent mesh generation when doing something like a "full render" where it's ok to take a bit more time to generate something screen related to high quality instead of focusing so much on speed like the regular display does.
6201.104 In reply to 6201.101
Thanks for testing it Fabien!
6201.105
Hello,
I've found it is an additional time saver to just load up the hidden line AI file right back into MoI for minor cleanup using Trim and Blend commands in case things don't line up quite exactly or if there are some little stray line segments that aren't needed. Once that get's put back into AI or Corel It is a bit easier to have those curves closed up. I'm not sure if MoI repositions points on the secondary save or not, but it would be helpful if it didn't. Awesome progress in such a short time.
6201.106 In reply to 6201.102
Sorry I must have been confused. I was now able to open the .ai line drawing and I can see a wonderful clean layer structure! Thank you!!
But I have to ignore the linked PNG file. When I try to open both ai and PNG it just doesn't open. My Illustrator CS3 software on Mountain Lion is behaving very strange at the moment.
6201.107 In reply to 6201.103
>Nope, for each surface it generates a new render mesh on the fly, and that mesh gets refined until the screen space projection of it deviates no more than >1/4 of a pixel on the render screen.
So Michael, this begs an unrelated but burning question for a future request :::
For normal UI Viewport manipulation, would it be someday possible for MoI to wait until the mouse/rotations/etc is idle, then spend a little idle CPU time to render a beautiful, ultra-smooth, virtually anti-aliased UI image that would replace the active card-based image (hopefully near-seamlessly).
I mean, moving around would be the same fluid speed as usual, but wait, don't move.... ahhh. surely the best Viewport image of any 3D modeler on the planet!
Just a thought.
6201.108 In reply to 6201.105
Hi OSTexo,
It shouldn't unless you're exporting it out using the 3D view that has perspective.
On export it has to refit curves that are rational or have a degree higher than 3, curves that are already degree 3 non-rational ones (like you'll have with AI import) should not be modified if they're exported from the Top ortho view.
6201.109 In reply to 6201.106
Hi Martin,
Great!
You should only open the .ai file - the PNG is already inserted into the .ai file as linked placed art, so it should be in place already right when you open up the .ai file only. But you do need to have the PNG file placed in the same folder alongside the .ai file so that Illustrator is able to find it.
6201.110 In reply to 6201.107
Hi Mike,
Maybe in the future someday, but it's unfortunately quite tricky to do a really good job of that.
The hard part is that it would not be very nice if there was any stuttering or lag when you just by chance happened to pause for a moment and actually want to continue to move around right away. It tends to be difficult to get a CPU intensive task to instantaneously stop.
Yeah, but unfortunately it's also very easy for something like that to go more like: move around, stutter, get nice image, run out of memory, ....
6201.111
Looks good Michael! Tested AI file into Illustrator CS5 & CS6 (3 layers). Tried PDF into Inkscape on Linux (Ubuntu), no layer separation but all elements were there and selectable. Nice Work, hope to see a new Beta soon!
6201.112 In reply to 6201.109
sorry I wasn't clear enough. I have both files in a folder. When I double click the .ai file nothing happens. It just doesnt open.
When I delete the .png file and then double click the .ai file I get a warning that a linked file is missing. If I push "Ignore" in that window the .ai file opens and I can see the lines.
I tried this on a second computer with the same setup and same result.
I also can't place the .png file into Illustrator. There seems to be a problem with large png files and/or transparency according to http://forums.adobe.com/thread/478570 or http://forums.adobe.com/thread/668668
This works:
I opened the .png in Photoshop and saved it as .psd file. Then I deleted the original png file. When I double clicked the Illustrator file I chose replace in the missing file warning window and then chose the .psd file. Now it opened fine.
I'm very happy with the result and the extra conversion doesn't bother me.
EDITED: 11 Oct 2013 by MARTIN3D
6201.113 In reply to 6201.112
Hi Martin,
Does the folder happen to be the Temp folder?
Do you get different behavior if you use File > Open inside of Illustrator to open the file rather than double clicking the file itself?
That's also kind of strange, I just tested placing the png over here in CS2 and it works ok for me. Somehow a system specific issue in Illustrator?
6201.114 In reply to 6201.113
No they're in a folder called outline test on the desktop. Isn't the temp folder a Windows thing? Never saw one.
Tried everything. My Illustrator CS3 doesn't like the large PNG file. Although dragging the .png file into Illustrator worked but it came in way too large. We need another one with CS3 for testing.
6201.115
Some feedback, concerning the AI file:
Illustrator CS2 (win7) and CC (Mac OSX 10.8.5): Working nicely. Got 3 layers, stacked in proper order, easily selectable. Can place/import the PNG file. Fantastic!
Illustrator CS4 (Mac OS X 10.8.5): Not working, at all: says it get an error and do nothing, it just ignore it. Also can't place or import the PNG file into. In my personnel case its not important 'cause we don“t use CS4 anymore. Maybe it affect some other user. Its better to let you know. Or maybe its something on my end, don't know.
Concerning the PDF file: It works, in every of the above setups, but don't have layers as it make hard to select. From my experience i got several no layered PDF files from others, but i think its a case of not tick on 'Perserve Illustrator Editing Capabilities' when saving as PDF, otherwise it export with layers.
Concerning the PNG file/render image:
Photoshop CS2 (win7) and CS4 and CC (both Mac OSX 10.8.5): Working nicely, its in 1 layer with transparentcy, but no AntiAliasing, so it's stepped/jagged on the outline.
The AA issue can be solved with a slight Blur Filter in Photoshop. Its a pretty big image, which is good for print work.
Overall, well done. Thanks.
One question concerning the rendered image: Looks the material main color is a Grey. It will be possible to pick 1 different color on export? It could help on the readbility. Anyway i could do it in Photoshop.
Carlos
Show messages:  1-15  …  36-55  56-75  76-95  96-115  116-135  136-155  156-175  …  296
