Hidden line removal progress
 1-12  …  233-252  253-272  273-292  293-296
6201.273
> i'm only able to output the 3D view
I think i've found the reason for this behaviour: It happens when using MilkyWaif UI, the export options window popup that show up its different from the actual (v3 Beta Nov.) and always export only the 3D view.
With the default UI it work nicely. So, i'll stick with the default UI, although i loved MilkyWaif UI.
Thanks.
Carlos
6201.274 In reply to 6201.273
Hi Carlos, yeah you can't really copy old versions of the full UI over top of a new release, when you do you're effectively erasing any changes that were implemented for new features.
Like in this case the AI dialog is pretty different compared to the old version, because there are a lot of new options for it to control.
Instead of copying the entire \ui folder over (which for sure will cause problems), you could instead try to only copy a small number of key files like moi.css and specific images that were changed, that has a better chance at working but even then if the new release has changes to moi.css which happens sometimes you will still run into the same problem.
This problem of trying to incorporate UI changes for new features along with personalized changed to previous UI is a kind of difficult problem to solve, it's one of the reasons why I have not really focused on UI customization so much.
6201.275 In reply to 6201.271
>Does this happen only if you are generating a shaded background image?
It's inconsistent. If turned off, solids will sometimes stop throwing the error but the result is still flipped vertically.
Turn it back on and it continues to NOT throw the error. Orbit the camera, still okay. Orbit the camera some
more and eventually it starts throwing the error again. It's weird, it's almost like the buffer data gets corrupted
at least in regard to Photoshop. And once that happens it keeps throwing the error and doesn't care whether
the background image is on or off.
The previously attached .3dm is curves only and should always paste, albeit flipped, but sometimes curves only
will also throw the error if selected curves match the edges of unselected surfaces.
-Jeff
6201.276
Hi michael
Yes it seems to be mavericks, if i leave on one screen it is more stable. I read that cranking up the canvas mega pixel value gives more detail, and in doing so it does give me a better pic, at 30 it works but at 35 it crashes every time. I have attached two pdfs a MOI version and an Isodraw version to compare. I know its unfair to compare you to such a mature product, what you've done so far is brilliant.
It seems some of the "weak" areas highlighted in pink need more resolution from the pixel grid to work but as i say it won't go above 30 without crashing. . . FYI the size of this part is approx 60cm square if that helps.
Matt
6201.277 In reply to 6201.272
> Damn! That Floyd Rose is so appealing to my eyes I wanna eat it! Nice job. :)
With this new ability, MoI has just increased its street-value many-fold! (er, ya know what I mean)
Martin, those are beautiful, and the new output is amazing!
6201.278 In reply to 6201.277
Thanks wastzzz and Mike.
I wasn't that happy with the export results yesterday. Luckily it was me. Now that I run "Construct > Curve > Isect" before each and every export its like night and day.
Excellent work Michael, MoI has become so much more useful.
6201.279 In reply to 6201.275
Hi Jeff, re: Photoshop copy/paste problems, can you please contact me through e-mail at moi@moi3d.com and I'll set up a test version for you which reverts some of the changes to the header part of the AI file generation. It seems like Photoshop probably has some bugs in its handling of the old AI v8 file format, but if it worked ok previously it should probably be possible to get it to work again if I just avoid writing whatever particular thing triggers the bug from happening.
6201.280 In reply to 6201.276
Hi Matt,
Right now the hidden line export will crash if it runs out of memory in the middle of the calculation. For the next release I'll try to tune this up to try and make it behave better like maybe just giving up on the export rather than crashing. But anyway that's almost certainly what's happening to you with the canvas size above 30 megapixels combined with a highly detailed model.
If you haven't tried this already, go to Options > View > "Meshing parameters", and set the "Mesh angle" parameter to 30 degrees, and uncheck the "Add detail to inflections" parameter right next to it (do this with MoI empty just after startup). That will make for a rougher looking viewport display but it will reduce memory consumption by quite a bit on heavy models like you've got there.
That might allow you to go up higher with the canvas size setting, which can have a max value of 75.
The overall approach of how the hidden line engine works just might not work very well with that kind of object structure where you've got such little tiny sized edges in comparison to the whole overall object size. If you can possibly cut the model up into some smaller sized pieces and only process one of those pieces at a time rather than a big sized chunk like that, that would probably help quite a bit.
Two of the areas where you've circled where there are little things shooting out - those are probably not actually related to canvas pixel size but are more likely to be surface trim problems where there was some problem getting a proper structured trim boundary during the STEP file import. Those particular surfaces will probably have to be repaired by separating them out, untrimming and retrimming them in order to get them fixed up. If you're able to send me a file with just those problem surfaces and the ones immediately surrounding them I can try to show you how to do that. There is an object repair tutorial here that covers some of the techniques involved: http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17 It's also possible that it could be a mesh generation bug rather than an incorrect trim boundary import bug, it's difficult for me to know for sure without examining the actual geometry.
At any rate, the MoI export you show there even with its flaws at least gives you something that you can work with. I'll see about doing some tuneups to try and improve it further.
6201.281
This new feature indeed has great promise!
I was able to export my very complex model by turning off inflections and bringing the mesh angle up to 30.
I also had to delete every non-essential and hidden object as the process seemed to include them in the calculation.
Yes, that is how it works, but I think those objects were gumming up the works even though they were "hidden."
Does the PDF export omit hidden objects from the equation?
Also, I would like to suggest and addition to this feature: Could there be a way to use a blank white or solid-color vector object in place of the bitmap?
Or could there be a way to tell the 'background' bitmap to be white without disappearing and showing the outlines beneath?
The bitmap can be whitened out in Illustrator or Corel, but Photoshop hasn't a way to see these layers when importing PDF's.
Case in point: I'm often interested in making the plain, diagram-style vector pics using no fill color, but still blocking out the larger outside outlines.
I could program in a Lighting Option to make everything white... hmm, easier in AI or Corel.
Here is a cool result:
I brought the PDF into Corel where I made the bitmap white. Then I converted everything in a line-art bitmap where I used Corel's auto-trace feature on it.
That gave me a hand-inked look! Added the type next and brought all that to PhotoShop where I gave it all a realistic look.
Again, I am very pleased with the prospect!
6201.282 In reply to 6201.281
Very cool result Mike!
Dang Mike - that's great!
Hey - speaking of bitmap tracing in Corel Draw.... I use that function almost daily in my work on B&W bitmaps and have never been satisfied even after trying all the settings and tweaking values.
Today, after all the talk of AI on the forum, I traced a B&W bitmap using AI. It came out almost perfect!
Have you compared bitmap trace between Corel Draw and AI?
Ed
6201.284 In reply to 6201.283
Thanks Ed,
Corel made some improvements to the tracing feature after X4, as X3's tracing was just horrible. I'm using X6.
As tracing line-art is a staple of my daily work I religiously use Corel 12's stand-alone TRACE program. It lends itself to hand-drawn art and will take bitmaps of virtually any size.
But for some stinking reason they dropped it at X3. I keep a version 12 CD in store, but I worry that I'll lose it someday.
I prefer AI's trace next to that one, which is a vestigial of Streamline, but since I use Corel as my primary and AI as secondary, I rarely touch AI's tracer.
X6's is not that great on drawing but actually does well with basic logos and simple fonts inside of logos.
There are very few setting offered, but they do allow you now to get stacked objects like the old TRACE as an alternative to the odd cut-out ones.
I've been wishing for an output feature like this for a while, but since this came under my radar, I'm just now grasping the possibilities.
I would like there to be some way to get a filled vector shape instead of the bitmap, but I know that for one, the bitmap is rendered from surface polys - and two; the outer outline silhouettes consist of many broken and oddly overlapped segments. A white bitmap would work fine, but all said, this request can be satisfied with a bit of quick levels and trace work in Corel. I ain't complainin' ;-)
6201.285 In reply to 6201.281
Hi Mike, woah that is awesome, your pic confused me for a second about why you were showing that photo! :)
This is fairly difficult because getting a vector object fill means actually joining together numerous different generated pieces and trying to screen out little fragments of things. I don't really have much hope of getting that done anytime too soon.
This one is possible currently by adjusting some lighting settings, just add another one to your lighting presets. The parameters you would set are shown here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3135.3
Basically if the light intensity is turned up very high it will have full brightness everywhere essentially disabling shading.
6201.286 In reply to 6201.281
Mike.
That is SO convincing, it's just NOT TRUE!!!!
Looks like you've been carrying it around in your wallet for the last forty years.
Absolutely brilliant :-()
Martin.
6201.287
A little icon work & transparency.
Size: 262 KB, Downloaded: 121 times, Dimensions: 1167x792px
6201.288
I noticed few difference in accuracy between MoI's hidden line removal and Rhino's Make2D command.
I am attaching an example of the same 3D model.
MoI output is not bad, but Rhino's one is more accurate (lines are touching and it allows me to use hatching later).
Canvas size was 70. Anyways I'm pretty fine with the MoI output, but could you explain me how the hidden line removal algorithms of MoI and Rhino are different? Are they using a different approach?
Is it possible in the future to improve the hidden line feature to get better results at corners/touching lines?
It's just my own curiosity.
MoI:
Rhino:
Thank you.
M.
6201.289 In reply to 6201.46
Hello Mike K4ICY, beau bee, bee, buzz, balèze (hulk, huge) in the MoI galery.
6201.290 In reply to 6201.288
Hi Max, I think that Rhino's one is based on intersecting curves with one another, while MoI's one is based on following a curve and using a pixel depth buffer to determine whether things are hidden or not.
So yeah they use a different approach and that's part of why they have different abilities too, like Rhino's one does not have any method for generating an outline or silhouette lines out to AI or PDF format like MoI's does.
I think it could be possible for me to increase the accuracy of MoI's one in the future, by incorporating some more detailed analysis of things when a curve is entering or exiting from the hidden state.
6201.291 In reply to 6201.290
Thanks for the explanation.
I like the idea of increasing the accuracy, if possible. Otherwise, for some technical drawings I am sticking to Rhino at the moment. It's not a problem. But the silhouettes+outlines output is really great for presenting a product quickly and clear.
6201.292
Thanks again for this amazing feature!
I also use it to extract renders only, having the alpha channel is a very productive asset.
I'm getting used to the megapixel concept, so for a squarish viewport, 4 mp gives me about 2000px which is often quite enough for my needs.
Marc
Show messages:  1-12  …  213-232  233-252  253-272  273-292  293-296
