Hidden line removal progress
 1-4  …  225-244  245-264  265-284  285-296
6201.265 In reply to 6201.261
Hi danperk, that's a great looking result!
> Did some testing with copy/paste into Illustrator CS6 and it works perfectly!
> If anyone missed it it's here:
A couple of other notes on copy/paste to Illustrator. There was a bug in the previous beta on the Mac for using AI format to copy/paste into Illustrator, that should be fixed now. The main difference with using AI format (instead of PDF) is that the layers come through when using AI format (if the setting for "Paste remembers layers" I think it's called in Illustrator is enabled).
Also, at least on CS2 there is a quirk for the shaded background image when doing AI version copy/paste - the actual image is stored in the temp folder, and it may not initially display in Illustrator for some reason. However, if you select the image and click the "Embed" button on the toolbar to switch it to an embedded image rather than a linked one, then it shows up.
So if you do AI version copy/paste into Illustrator use that embed button to get the background image to behave properly. It's pretty easy to select the background image because it's usually a fair amount bigger than the objects, just click a little away from the objects and it will select and the Embed button shows in the upper toolbar. It's possible this may not be needed anymore in recent Illustrator versions, I'm not sure about that.
6201.266 In reply to 6201.264
quote:
It would be cool to see some nice test results too, not just bad ones!
sure, we just need some time to learn how to get good results. Hows about this :-)
-Martin
6201.267 In reply to 6201.266
Hi Martin,
Tremendous! All the different ingredients (shaded background, silhouettes) just come together so well there.
It's so great to see these cool results, thanks very much for sharing them!
6201.268
Im using the new v3 beta on a mac with Mavericks and its not good. I can drag the moi window from one screen to another and the export function to ai or pdf stops after naming the file . .. anybody else have these problems?
6201.269
Michael,
Something strange is going on with the Illustrator copy buffer in regards to Photoshop.
I know Photoshop hasn't been the direct target for this feature during developement, but it worked flawlessly with it in the previous(Aug 13th) beta.
Which isn't unexpected since copying and pasting curves between Photoshop and Illustrator has been a feature since at least since CS2.
The behavior is somewhat erratic, but most often when you attempt to paste in Photoshop, you'll get the paste UI as expected, but
when you choose 'OK' the following error is thrown, 'Could not complete the Paste command because the source rectangle is empty'
Any assortment of solids in Moi should demonstrate this issue.
Sometimes it will work correctly(not sure why), though if you use the 3D viewport as the source what you get in Photoshop is usually flipped vertically.
I've attached a .3dm that demostrates this last problem. Load it into the latest beta. Don't adjust the camera in any way and select the curves.
Copy it to the Illustrator copy buffer, with 'Projection View' set to '3D'. Paste into a Photoshop document as 'Path' or 'Shape Layer'; it will work but
the result will be flipped vertically. Now orbit the camera to a different position and try another copy/paste, sometimes this fixes things and sometimes it doesn't
This issue isn't a complete roadblock, you can paste to Illustrator then immediately copy and paste into Photoshop and everything works as expected every time,
so more like a construction detour blocking that nice shortcut you just discovered the other day.
-Jeff
6201.270 In reply to 6201.268
Hi Matt, I think there are some problems in Mavericks with trying to move the window to different monitors. If I remember right, it's a general problem like the title bar gets lost or something like that, I'm a little surprised that it would have anything relating specifically to AI export.
But basically don't move the window to different monitors on Mavericks right now - Apple made a lot of changes to how multi monitor things work in Mavericks and it may take a while before fixes for the new problems that it caused trickle down into the libraries that MoI uses.
Does it work ok if you leave MoI on the same monitor instead of moving it to a different one?
6201.271 In reply to 6201.269
Hi Jeff,
re: 'Could not complete the Paste command because the source rectangle is empty'
Does this happen only if you are generating a shaded background image? When the dialog comes up at export time, try unchecking the "Shaded background" checkbox to do a curves only export without any image. Does the problem still repeat when doing curves only or not?
There were also a couple of changes in this new beta to put a bit more assorted information (like hi res bounding box, AI file version number, a couple of things like that) into the header part of the AI file, if you still see the problem without any image then it's probably related to that.
6201.272
Damn! That Floyd Rose is so appealing to my eyes I wanna eat it! Nice job. :)
M.
6201.273
> i'm only able to output the 3D view
I think i've found the reason for this behaviour: It happens when using MilkyWaif UI, the export options window popup that show up its different from the actual (v3 Beta Nov.) and always export only the 3D view.
With the default UI it work nicely. So, i'll stick with the default UI, although i loved MilkyWaif UI.
Carlos
6201.274 In reply to 6201.273
Hi Carlos, yeah you can't really copy old versions of the full UI over top of a new release, when you do you're effectively erasing any changes that were implemented for new features.
Like in this case the AI dialog is pretty different compared to the old version, because there are a lot of new options for it to control.
Instead of copying the entire \ui folder over (which for sure will cause problems), you could instead try to only copy a small number of key files like moi.css and specific images that were changed, that has a better chance at working but even then if the new release has changes to moi.css which happens sometimes you will still run into the same problem.
This problem of trying to incorporate UI changes for new features along with personalized changed to previous UI is a kind of difficult problem to solve, it's one of the reasons why I have not really focused on UI customization so much.
6201.275 In reply to 6201.271
It's inconsistent. If turned off, solids will sometimes stop throwing the error but the result is still flipped vertically.
Turn it back on and it continues to NOT throw the error. Orbit the camera, still okay. Orbit the camera some
more and eventually it starts throwing the error again. It's weird, it's almost like the buffer data gets corrupted
at least in regard to Photoshop. And once that happens it keeps throwing the error and doesn't care whether
the background image is on or off.
The previously attached .3dm is curves only and should always paste, albeit flipped, but sometimes curves only
will also throw the error if selected curves match the edges of unselected surfaces.
-Jeff
6201.276
Hi michael
Yes it seems to be mavericks, if i leave on one screen it is more stable. I read that cranking up the canvas mega pixel value gives more detail, and in doing so it does give me a better pic, at 30 it works but at 35 it crashes every time. I have attached two pdfs a MOI version and an Isodraw version to compare. I know its unfair to compare you to such a mature product, what you've done so far is brilliant.
It seems some of the "weak" areas highlighted in pink need more resolution from the pixel grid to work but as i say it won't go above 30 without crashing. . . FYI the size of this part is approx 60cm square if that helps.
Matt
6201.277 In reply to 6201.272
With this new ability, MoI has just increased its street-value many-fold! (er, ya know what I mean)
Martin, those are beautiful, and the new output is amazing!
6201.278 In reply to 6201.277
Thanks wastzzz and Mike.
I wasn't that happy with the export results yesterday. Luckily it was me. Now that I run "Construct > Curve > Isect" before each and every export its like night and day.
Excellent work Michael, MoI has become so much more useful.
6201.279 In reply to 6201.275
Hi Jeff, re: Photoshop copy/paste problems, can you please contact me through e-mail at moi@moi3d.com and I'll set up a test version for you which reverts some of the changes to the header part of the AI file generation. It seems like Photoshop probably has some bugs in its handling of the old AI v8 file format, but if it worked ok previously it should probably be possible to get it to work again if I just avoid writing whatever particular thing triggers the bug from happening.
6201.280 In reply to 6201.276
Hi Matt,
Right now the hidden line export will crash if it runs out of memory in the middle of the calculation. For the next release I'll try to tune this up to try and make it behave better like maybe just giving up on the export rather than crashing. But anyway that's almost certainly what's happening to you with the canvas size above 30 megapixels combined with a highly detailed model.
If you haven't tried this already, go to Options > View > "Meshing parameters", and set the "Mesh angle" parameter to 30 degrees, and uncheck the "Add detail to inflections" parameter right next to it (do this with MoI empty just after startup). That will make for a rougher looking viewport display but it will reduce memory consumption by quite a bit on heavy models like you've got there.
That might allow you to go up higher with the canvas size setting, which can have a max value of 75.
The overall approach of how the hidden line engine works just might not work very well with that kind of object structure where you've got such little tiny sized edges in comparison to the whole overall object size. If you can possibly cut the model up into some smaller sized pieces and only process one of those pieces at a time rather than a big sized chunk like that, that would probably help quite a bit.
Two of the areas where you've circled where there are little things shooting out - those are probably not actually related to canvas pixel size but are more likely to be surface trim problems where there was some problem getting a proper structured trim boundary during the STEP file import. Those particular surfaces will probably have to be repaired by separating them out, untrimming and retrimming them in order to get them fixed up. If you're able to send me a file with just those problem surfaces and the ones immediately surrounding them I can try to show you how to do that. There is an object repair tutorial here that covers some of the techniques involved: http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17 It's also possible that it could be a mesh generation bug rather than an incorrect trim boundary import bug, it's difficult for me to know for sure without examining the actual geometry.
At any rate, the MoI export you show there even with its flaws at least gives you something that you can work with. I'll see about doing some tuneups to try and improve it further.
6201.281
This new feature indeed has great promise!
I was able to export my very complex model by turning off inflections and bringing the mesh angle up to 30.
I also had to delete every non-essential and hidden object as the process seemed to include them in the calculation.
Yes, that is how it works, but I think those objects were gumming up the works even though they were "hidden."
Does the PDF export omit hidden objects from the equation?
Also, I would like to suggest and addition to this feature: Could there be a way to use a blank white or solid-color vector object in place of the bitmap?
Or could there be a way to tell the 'background' bitmap to be white without disappearing and showing the outlines beneath?
The bitmap can be whitened out in Illustrator or Corel, but Photoshop hasn't a way to see these layers when importing PDF's.
Case in point: I'm often interested in making the plain, diagram-style vector pics using no fill color, but still blocking out the larger outside outlines.
I could program in a Lighting Option to make everything white... hmm, easier in AI or Corel.
Here is a cool result:
I brought the PDF into Corel where I made the bitmap white. Then I converted everything in a line-art bitmap where I used Corel's auto-trace feature on it.
That gave me a hand-inked look! Added the type next and brought all that to PhotoShop where I gave it all a realistic look.
Again, I am very pleased with the prospect!
6201.282 In reply to 6201.281
Very cool result Mike!
Dang Mike - that's great!
Hey - speaking of bitmap tracing in Corel Draw.... I use that function almost daily in my work on B&W bitmaps and have never been satisfied even after trying all the settings and tweaking values.
Today, after all the talk of AI on the forum, I traced a B&W bitmap using AI. It came out almost perfect!
Have you compared bitmap trace between Corel Draw and AI?
Ed
6201.284 In reply to 6201.283
Thanks Ed,
Corel made some improvements to the tracing feature after X4, as X3's tracing was just horrible. I'm using X6.
As tracing line-art is a staple of my daily work I religiously use Corel 12's stand-alone TRACE program. It lends itself to hand-drawn art and will take bitmaps of virtually any size.
But for some stinking reason they dropped it at X3. I keep a version 12 CD in store, but I worry that I'll lose it someday.
I prefer AI's trace next to that one, which is a vestigial of Streamline, but since I use Corel as my primary and AI as secondary, I rarely touch AI's tracer.
X6's is not that great on drawing but actually does well with basic logos and simple fonts inside of logos.
There are very few setting offered, but they do allow you now to get stacked objects like the old TRACE as an alternative to the odd cut-out ones.
I've been wishing for an output feature like this for a while, but since this came under my radar, I'm just now grasping the possibilities.
I would like there to be some way to get a filled vector shape instead of the bitmap, but I know that for one, the bitmap is rendered from surface polys - and two; the outer outline silhouettes consist of many broken and oddly overlapped segments. A white bitmap would work fine, but all said, this request can be satisfied with a bit of quick levels and trace work in Corel. I ain't complainin' ;-)
Show messages:  1-4  …  205-224  225-244  245-264  265-284  285-296
