Hidden line removal progress
 1-15  …  196-215  216-235  236-255  256-275  276-295  296
6201.237
I've seen this phenomena before...
6201.238
Etno...logic! :)
6201.240 In reply to 6201.228
Down to one thing left on the cleanup list!
6201.241
must be one day to go then . . . :-)
Zero things left on the list! I'll see if I can make a build before I fall asleep...
6201.243 In reply to 6201.242
Suspense!
New Nov-19 beta is up: http://moi3d.com/beta.htm
It will take me a bit to assemble the release notes and make the regular main announcement.
The main new thing is hidden line removal when exporting to AI, PDF, and DXF formats.
6201.245 In reply to 6201.244
If you make some nice hidden-line exports to PDF / AI / DXF, it would be cool to see some posted here!
Some quick notes:
Shift while drawing now works for an enhanced straight snap. When you hold down shift straight snap will have priority over object snap, and the current straight snap line will stay locked on for as long as you hold shift. Also when you hold down shift straight snap will activate to the closest straight snap line regardless of how far away it is to the mouse.
AI format for clipboard transfer should work on on OSX.
Some bugs fixed in surface/surface intersection, some cases that didn't work before with things like 2 pipes crossing each other should work better now.
Layers are exported to DXF format
Bug fixes to Blend between 2 edges that touch each other at sharp "pole points", and to order sorting for loft to point.
6201.247 In reply to 6201.245
Thanks Michael! Very cool outcome.
Here's one straight off the bat without delving too much, piece of cake with professional result :)
Just at first glance a couple of things; an option to open the file after generation for PDF I guess don't know about the other two formats they'd have to be associated to a program.
Landscape/Portrait option?
That's all for now.
6201.248 In reply to 6201.247
Thanks Danny - that's a good looking result right off the bat! :)
I think I see a couple of spots where some silhouettes may have been missed, can you please e-mail me that model to moi@moi3d.com so I can test some with it?
Maybe just for PDF only I guess? The other formats are kind of more editing oriented...
Yeah some page setup stuff would probably be good. I'm not entirely sure if I'll get that in quite yet, I am a little burned out on wrestling with PDF. But it would be good to be able to get a final PDF generated straight out.
Thanks for testing it!
@Michael
French version on your Email! ;)
6201.250
The output is amazing. Top quality, even better than top Cad applications i've seen.
There's one question: i'm only able to output the 3D view, even when i choose to output some other view, Moi still output allways the 3D View. Maybe there's a bug or i'm doing something wrong.
Cheers.
Carlos
Attached is a screen shot of my PDF. Works great!
This is a desk-top CNC milling machine I just spent three months modifying to greatly increase its accuracy. I used MoI to help me visualize how the new components and custom-machined parts would integrate into the machine. With MoI I did a lot of design modifications "on screen" before custom-machining several parts. As a result, it worked perfectly the first time.
My choice of colors is weird, but the output is very nice.
Ed
Marysville, Washington
Click images to enlarge:
EDITED: 19 Nov 2013 by EDDYF
Size: 44.5 KB, Downloaded: 97 times, Dimensions: 450x284px
Size: 132.8 KB, Downloaded: 157 times, Dimensions: 450x739px
6201.252 In reply to 6201.251
thanks for making the new Beta available. Here's a quick PDF export of one of my models. If there wheren't some important missing lines it would be perfect. Is this my fault (bad modelling) or are you able to tune the export to avoid this? If you want the 3dm file let me know.
-Martin
6201.253
Tried it, and it works good! Just one thing, that maybe its my fault, but lets say, for example, I make a cylinder, and export the front view in dxf. It should be a rectangle, and indeed it is, but at some corners the lines are not touching exactly. Am I doing something wrong?
Awesome Michael,
here are two simple model of mine, as .pdf output with standard settings.
Best regards
6201.255
Yep, i was doing it wrong, so no worries. I was saving instead of exporting it.
The control of the output is perfect. Thanks.
Carlos
Show messages:  1-15  …  176-195  196-215  216-235  236-255  256-275  276-295  296
