Hidden line removal progress
 1-9  …  190-209  210-229  230-249  250-269  270-289  290-296
6201.230 In reply to 6201.229
Yep ... big smile here too.
eric
6201.231
Any more surprises than the PDF in the next beta ? :)
6201.233 In reply to 6201.232
The PDF/AI/DXF export is the main thing, there are a few other minor new things as well.
6201.234
you're just teasing us now . . .:-)
6201.235 In reply to 6201.234
... and probably tucked up in bed whilst leaving us to stew overnight ;-)
Martin.
6201.237
I've seen this phenomena before...
6201.238
Etno...logic! :)
6201.240 In reply to 6201.228
Down to one thing left on the cleanup list!
6201.241
must be one day to go then . . . :-)
Zero things left on the list! I'll see if I can make a build before I fall asleep...
6201.243 In reply to 6201.242
Suspense!
New Nov-19 beta is up: http://moi3d.com/beta.htm
It will take me a bit to assemble the release notes and make the regular main announcement.
The main new thing is hidden line removal when exporting to AI, PDF, and DXF formats.
6201.245 In reply to 6201.244
If you make some nice hidden-line exports to PDF / AI / DXF, it would be cool to see some posted here!
Some quick notes:
Shift while drawing now works for an enhanced straight snap. When you hold down shift straight snap will have priority over object snap, and the current straight snap line will stay locked on for as long as you hold shift. Also when you hold down shift straight snap will activate to the closest straight snap line regardless of how far away it is to the mouse.
AI format for clipboard transfer should work on on OSX.
Some bugs fixed in surface/surface intersection, some cases that didn't work before with things like 2 pipes crossing each other should work better now.
Layers are exported to DXF format
Bug fixes to Blend between 2 edges that touch each other at sharp "pole points", and to order sorting for loft to point.
6201.247 In reply to 6201.245
Thanks Michael! Very cool outcome.
Here's one straight off the bat without delving too much, piece of cake with professional result :)
Just at first glance a couple of things; an option to open the file after generation for PDF I guess don't know about the other two formats they'd have to be associated to a program.
Landscape/Portrait option?
That's all for now.
6201.248 In reply to 6201.247
Thanks Danny - that's a good looking result right off the bat! :)
I think I see a couple of spots where some silhouettes may have been missed, can you please e-mail me that model to moi@moi3d.com so I can test some with it?
Maybe just for PDF only I guess? The other formats are kind of more editing oriented...
Yeah some page setup stuff would probably be good. I'm not entirely sure if I'll get that in quite yet, I am a little burned out on wrestling with PDF. But it would be good to be able to get a final PDF generated straight out.
Thanks for testing it!
@Michael
French version on your Email! ;)
Show messages:  1-9  …  170-189  190-209  210-229  230-249  250-269  270-289  290-296
