Hidden line removal progress
 1-3  …  164-183  184-203  204-223  224-243  244-263  …  284-296
6201.204
Any chance of getting 4 tick boxes for each Projecton Views, and export all ticked at the same time, with the same scale, appending one sufix on each file like FileName-FRONT, FileName-3D, and so on?
Otherwise have to export 4 times the very same file. Its doable, or does it make sense to you?
Carlos
6201.205 In reply to 6201.204
Hi Carlos, right now I just don't have things set up to export multiple views like that, I think I'm going to focus for the first release of this just on getting one single view at a time and try to make sure that's working ok to begin with.
Then in the future maybe I could add in a option for "All" under the "Projection view" option that would then put in 4 views into the same file... Is it important to you for the views to remain in separate files rather than arranged in a grid on one single page?
6201.206
4 Views in the same file is even better, actually with 4 separate Files/Views i'll end up gathering the 4 in 1 file/drawing.
Carlos
6201.207 In reply to 6201.206
Hi Carlos, one other question - with 4 views in the same file do you expect the page to be oriented as "landscape" type mode or still "portrait" type display mode?
6201.208 In reply to 6201.203
""""""""""""""""""""''The way it works is the actual specific image resolution is fit to go around the objects being exported""""""""""""""""""
That's how I understood it, the numbers displayed would be that custom resolution.
It's not worth the trouble if it's too complicated, I'm sure I will quickly get used to estimate resolutions in that fashion.
Marc
6201.209
Landscape, please ; )
6201.210 In reply to 6201.208
Hi Marc,
Yeah unfortunately it's not currently easy for the dialog code to know that resolution at the point that the dialog will be displayed, it's something that's calculated by the hidden line removal engine after it receives those parameters to use...
It could be possible to recode that, but it can be somewhat inconvenient in general for UI code to interact back and forth with low level engine code.
That same resolution will control not only the shaded image resolution, but also the resolution of the depth map that's used for hidden/visible determination. So if you are getting some smaller size details not coming through that will be a parameter you can increase to make the depth map more fine grained too.
6201.211
hi michael
What you suggested with setting the units to say .2 is perfect - didn't think it would work like that! Thats why you're the programmer and I'm the illustrator ;-)
Great work, can't wait to give it a test drive - I have lots of big STEP files waiting.
Matt
6201.212
Will the dxf export support layers in the next beta?
6201.213 In reply to 6201.212
Hi Max,
It's on my list of things I'd like to get done with this hidden line removal work but I have not got to the DXF part of the work quite yet.
6201.214 In reply to 6201.212
Hi Max, also I'm not really sure if the DXF export should have all these exact same options as the AI/PDF export like for generating outlines and silhouettes in addition to just hidden/visible lines.
For one thing I'm not sure if I'll be able to put in an embedded bitmap in the DXF file like I can for AI and PDF files.
So the DXF export may be a bit more simplified, with just options for whether to generate hidden lines or not.
6201.215 In reply to 6201.213
Please, I really need the DXF format to export layers (styles).
Because: if I export MoI > AI it has layers, then ok, I convert from AI > DXF\DWG, and import into AutoCAD. The imported drawing is not precise. It has slightly overlapping lines and makes it impossible to hatch.
If I export MoI > DXF and import in AutoCAD, the lines are perfect. But no layers. :(
EDITED: 30 Oct 2013 by BEMFARMER
6201.217 In reply to 6201.215
Hi, wouldn't it be easy to select by linetype in Autocad with quick select?
You could then assign your selection to another layer.
Marc
6201.218
If you are on a mac a free alternative (for the moment) is exporting from rhino. Thats what I do, but the direct MoI to AutoCAD workflow is ideal.
6201.219 In reply to 6201.218
Also because I need a dxf output with the upcoming hidden line feature.. And layers
6201.220 In reply to 6201.1
Ok, this is getting pretty close to being finished up... I think that probably tomorrow I'll have the hidden line removal stuff wrapped up and then I have a short list of some other things to look at and then I'll be ready for a new beta. So not too much longer.
6201.221 In reply to 6201.220
6201.222 In reply to 6201.221
"Australia steps to the line.... Their looking pretty fit and chipper today Al"......America has not been a contender for some time now...... The French have a good shot at it this release.... I'm on pins and needles..... The edge of my seat.... Loosing hair as we speak... This is as good as it gets....... You were born to be modelers. This is YOUR time......
Maxi mini Lego! :)
Show messages:  1-3  …  144-163  164-183  184-203  204-223  224-243  244-263  264-283  284-296
