| Hi Marc,
 > Maybe adding a bitmap option in the export dialog would be nice?
 > Those who don't know the viewport export scripts or can't work with PDF might find it handy.
 You mean something like a "PNG Image (*.png)" just directly listed in the file dialog for Export or Save As?
 That would certainly be easiest for someone to find. But yeah (as you mention) the downside is if other image formats were also added there it would start to make the file dialog dropdown get clogged up and after some point it gets difficult to find things in it.
 For direct image saving I'd been thinking that there would be something like a Render command that would generate an image and the image would be displayed on its own new window. Then there would be a file menu on that window where you could save the image to PNG/TIFF/JPG/etc...  That would probably be something for v4 since I'm hoping to wrap up v3 fairly soon here.
 > An idea would be to separate export types; Solids, Polygonal, 2d.
 Yeah having image saving under some kind of Render function (probably with a Render tab on the pane for accessing it) would help to put 2D bitmap images into one kind of separate category.
 It's kind of hard to introduce categories into the regular export without making things take extra steps, like it probably wouldn't be nice to have a separate dialog pop up before the file name one that made you pick between Solids, Polygonal, or 2D type exports before you got to put in the file name.
 -  Michael
