Hidden line removal progress
 1-9  …  70-89  90-109  110-129  130-149  150-169  …  290-296
6201.110 In reply to 6201.107
Hi Mike,
> For normal UI Viewport manipulation, would it be someday possible for MoI to wait until
> the mouse/rotations/etc is idle, then spend a little idle CPU time to render a beautiful,
> ultra-smooth, virtually anti-aliased UI image that would replace the active card-based
> image (hopefully near-seamlessly).
Maybe in the future someday, but it's unfortunately quite tricky to do a really good job of that.
The hard part is that it would not be very nice if there was any stuttering or lag when you just by chance happened to pause for a moment and actually want to continue to move around right away. It tends to be difficult to get a CPU intensive task to instantaneously stop.
> I mean, moving around would be the same fluid speed as usual, but wait, don't
> move.... ahhh. surely the best Viewport image of any 3D modeler on the planet!
Yeah, but unfortunately it's also very easy for something like that to go more like: move around, stutter, get nice image, run out of memory, ....
6201.111
Looks good Michael! Tested AI file into Illustrator CS5 & CS6 (3 layers). Tried PDF into Inkscape on Linux (Ubuntu), no layer separation but all elements were there and selectable. Nice Work, hope to see a new Beta soon!
6201.112 In reply to 6201.109
>You should only open the .ai file
sorry I wasn't clear enough. I have both files in a folder. When I double click the .ai file nothing happens. It just doesnt open.
When I delete the .png file and then double click the .ai file I get a warning that a linked file is missing. If I push "Ignore" in that window the .ai file opens and I can see the lines.
I tried this on a second computer with the same setup and same result.
I also can't place the .png file into Illustrator. There seems to be a problem with large png files and/or transparency according to http://forums.adobe.com/thread/478570 or http://forums.adobe.com/thread/668668
This works:
I opened the .png in Photoshop and saved it as .psd file. Then I deleted the original png file. When I double clicked the Illustrator file I chose replace in the missing file warning window and then chose the .psd file. Now it opened fine.
I'm very happy with the result and the extra conversion doesn't bother me.
EDITED: 11 Oct 2013 by MARTIN3D
6201.113 In reply to 6201.112
Hi Martin,
Does the folder happen to be the Temp folder?
Do you get different behavior if you use File > Open inside of Illustrator to open the file rather than double clicking the file itself?
That's also kind of strange, I just tested placing the png over here in CS2 and it works ok for me. Somehow a system specific issue in Illustrator?
6201.114 In reply to 6201.113
No they're in a folder called outline test on the desktop. Isn't the temp folder a Windows thing? Never saw one.
Tried everything. My Illustrator CS3 doesn't like the large PNG file. Although dragging the .png file into Illustrator worked but it came in way too large. We need another one with CS3 for testing.
6201.115
Some feedback, concerning the AI file:
Illustrator CS2 (win7) and CC (Mac OSX 10.8.5): Working nicely. Got 3 layers, stacked in proper order, easily selectable. Can place/import the PNG file. Fantastic!
Illustrator CS4 (Mac OS X 10.8.5): Not working, at all: says it get an error and do nothing, it just ignore it. Also can't place or import the PNG file into. In my personnel case its not important 'cause we don“t use CS4 anymore. Maybe it affect some other user. Its better to let you know. Or maybe its something on my end, don't know.
Concerning the PDF file: It works, in every of the above setups, but don't have layers as it make hard to select. From my experience i got several no layered PDF files from others, but i think its a case of not tick on 'Perserve Illustrator Editing Capabilities' when saving as PDF, otherwise it export with layers.
Concerning the PNG file/render image:
Photoshop CS2 (win7) and CS4 and CC (both Mac OSX 10.8.5): Working nicely, its in 1 layer with transparentcy, but no AntiAliasing, so it's stepped/jagged on the outline.
The AA issue can be solved with a slight Blur Filter in Photoshop. Its a pretty big image, which is good for print work.
Overall, well done. Thanks.
One question concerning the rendered image: Looks the material main color is a Grey. It will be possible to pick 1 different color on export? It could help on the readbility. Anyway i could do it in Photoshop.
Carlos
6201.116 In reply to 6201.115
Thanks for all the feedback Carlos!
> export with layers.
That "Preserve Illustrator Editing Capabilities" thing makes Illustrator save a big chunk of private undocumented information in the PDF file that contains illustrator specific data. Illustrator uses that method for making layers come in through PDFs but it only works for PDFs saved by Illustrator itself, not from any other method of PDF file generation.
Since that Illustrator specific data is not documented there isn't really any way for a separate program (like MoI for example) to get layers into Illustrator by PDF import only since Illustrator does not read them in from the regular PDF data.
But it does read them in from the AI v8 format, so that's the format you'll want to use for the transfer if you want layers to come over.
That's pretty weird that CS4 does not work. That's good to know though.
It just happened to be in this case since all the objects were using the default style. The shaded colors will come from the style assignment and look the same as they do in the regular MoI viewport display.
6201.117
That is is great, it will be very helpfull to have different colors on different parts, visually communicating some functions or how something have to be constructed.
Its great to comunicate with others.
Carlos
6201.118 In reply to 6201.96
Hi Michael, the AI file works great in Illustrator CS6 64bit.
The bitmap doesn't import in Xara but I don't care since it works so well with a layered PDF.
Maybe adding a bitmap option in the export dialog would be nice?
Those who don't know the viewport export scripts or can't work with PDF might find it handy.
On the other hand the export dropdown list will start to be crowded.
Some programs have 75 choice in the dropdown, having to search each time for the right one is somewhat annoying.
An idea would be to separate export types; Solids, Polygonal, 2d.
Marc
6201.119
For me, it's exactly what I need. Thanks michael
6201.120
Hello,
That's great news that it keeps the points as is. On a related note, does MoI have a curve extrapolation function? In the areas where the hidden line generation doesn't completely close off the area or it gets a bit wobbly I import that portion of the AI into Rhino and VSR has a very handy extrapolation function to extend the line so it can be trimmed. Another handy tool that is free for AI to connect lines with curves is SubScribe from Astute Graphics if you don't want to pay for the other plugins.
6201.121 In reply to 6201.118
Hi Marc,
I've got Xara 8 & 9 (Photo & Graphics Designer versions) & everything imported just fine.
See attachments.
6201.122 In reply to 6201.118
Hi Marc,
You mean something like a "PNG Image (*.png)" just directly listed in the file dialog for Export or Save As?
That would certainly be easiest for someone to find. But yeah (as you mention) the downside is if other image formats were also added there it would start to make the file dialog dropdown get clogged up and after some point it gets difficult to find things in it.
For direct image saving I'd been thinking that there would be something like a Render command that would generate an image and the image would be displayed on its own new window. Then there would be a file menu on that window where you could save the image to PNG/TIFF/JPG/etc... That would probably be something for v4 since I'm hoping to wrap up v3 fairly soon here.
Yeah having image saving under some kind of Render function (probably with a Render tab on the pane for accessing it) would help to put 2D bitmap images into one kind of separate category.
It's kind of hard to introduce categories into the regular export without making things take extra steps, like it probably wouldn't be nice to have a separate dialog pop up before the file name one that made you pick between Solids, Polygonal, or 2D type exports before you got to put in the file name.
6201.123 In reply to 6201.120
Hi OSTexo,
There is a curve extension function under Edit > Extend. If you want 2 curves to meet, you can select both of them, then run Edit > Extend, then at the prompt to select boundary objects you just right-click or push Done at that point to tell it you want to do a "mutual extend" where they extend to each other, rather than extending them to a third boundary line.
6201.124 In reply to 6201.121
Wow there seems to be a lot of variation in program support for these various things. Kind of a lot more differences maybe between Mac and PC versions and even between different versions of the same program than I would have expected.
6201.125 In reply to 6201.121
"""""""""""""""""""""""I've got Xara 8 & 9 (Photo & Graphics Designer versions) & everything imported just fine.
See attachments."""""""""""""""""""
Hi Colin,
Yeah PDF works great in Xara! I'm surprised to see other Xara users here.
I was referring to the AI test file import in Xara, it didnt import background file.
As said it works with PDF so no problem there.
Marc
6201.126 In reply to 6201.122
""""""""""""""""""""""" I'd been thinking that there would be something like a Render command that would generate an image and the image would be displayed on its own new window"""""""""""""""""""""
That's a great plan!
Marc
6201.127 In reply to 6201.125
Hi Marc,
So for Xara it will be use the PDF import - that brings in the image and also layer assignments.
Illustrator won't read in the layer assignments in PDF so if you want layers to come through you'd use .ai format for Illustrator instead.
And it seems that certain versions of Illustrator (seems to be around CS3 or CS4) have some problems with the images but the current versions seem to be behaving ok.
Don't forget the free Xara Xtrem5 ! ;)
http://www.xara.com/eu/specialoffers/designer/
6201.129 In reply to 6201.128
quote:
The offer will only last until 20th May 2013, so don't hesitate!
Show messages:  1-9  …  50-69  70-89  90-109  110-129  130-149  150-169  170-189  …  290-296
