Additional Commands: Merge
All  1-5  6-11
6195.6 In reply to 6195.5
Ah damned so my exemple above is false!
I have not tested it! :)
6195.7 In reply to 6195.5
Thank you, Michael. Like Pilou I use Sketchup, too, and I was simply confused. The term "edge" is used in a different way there. A simple standalone straight line is an edge there, too.
> I still have some hope to possibly incorporate that as an option of some type in the Join command
In Sketchup everybody uses a plugin called "weld". Maybe there could simply be a "weld to join inseparable" option for the join command?
6195.8 In reply to 6195.7
Hi Strube,
Yeah that's one possibility. One difficulty is that currently the Join command doesn't have any options in it at all, it just does its job and exits. So that's a pretty significant change in its workflow to make it wait to have options.
6195.9 In reply to 6195.8
That's true. Another possibility I simply have to suggest is
Left click = Join
Right click = Separate
Left click + Ctrl = Weld
Even a command button less, giving some space for the rebuild and reconstruct button. :-)
6195.10 In reply to 6195.9
Hi Strube,
> Left click = Join
The issue with that is that then the Separate and Weld functions become fairly hidden away and a lot of people will not end up knowing about them at all...
For some kinds of things it's not so bad for things to be semi hidden and just as you become more advanced and learn more things you find out about them. But separate might be just a bit too important to do that with, it's needed frequently in surface modeling.
6195.11 In reply to 6195.10
That's true, too. Although personally I think at the end of the day I am one of "a lot of people" and I still found Rebuild and Reconstruct.
Show messages: All  1-5  6-11
