Begginner needs help
All  1-5  6
6192.6 In reply to 6192.4
Also if your profile curve you sweep is planar, Sweep itself has an option in it to cap off the ends, that makes a solid right from the first sweep.
When your profile curves are not planar curves then you won't get automatic caps generated on the ends, you have to then form the end caps yourself basically.
Show messages: All  1-5  6
